    Padrão Postfix+Mysql
    bom dia galera, gostaria de saber se vcs ja compilaram o postfix, com suporte ao mysql, se ja postem ae o resultado pois estou com dificuldades. Uso o CL10
    Acho que a Conectiva disponibiliza pacotes pré-compilados com suporte à MySQL, mas de qualquer jeito, é só ler o Makefile...
    Abraços!
    Código :
    make -f Makefile.init makefiles 'CCARGS=-DHAS_MYSQL -I/usr/include/mysql -DUSE_SASL_AUTH -I/usr/include/sasl' 'AUXLIBS=/usr/lib/mysql/libmysqlclient.so -lm -L/usr/lib -lsasl2'
    Para compliar com suporte a MySQL e SASL.
    bom colega ja tentei com este comamdo, e vejam o erro depois com o comando make.
    dict_db.c:63:16: db.h: Arquivo ou diretório não encontrado
    dict_db.c:111: error: parse error before "DB"
    dict_db.c:111: warning: no semicolon at end of struct or union
    dict_db.c:117: error: parse error before '}' token
    dict_db.c:117: warning: data definition has no type or storage class
    dict_db.c: In function `dict_db_lookup':
    dict_db.c:170: error: `dict_db' undeclared (first use in this function)
    dict_db.c:170: error: (Each undeclared identifier is reported only once
    dict_db.c:170: error: for each function it appears in.)
    dict_db.c:170: error: parse error before ')' token
    dict_db.c:171: error: `DB' undeclared (first use in this function)
    dict_db.c:171: error: `db' undeclared (first use in this function)
    dict_db.c:172: error: `DBT' undeclared (first use in this function)
    dict_db.c:172: error: parse error before "db_key"
    dict_db.c:184: error: `db_key' undeclared (first use in this function)
    dict_db.c:185: error: `db_value' undeclared (first use in this function)
    dict_db.c: In function `dict_db_update':
    dict_db.c:238: error: `dict_db' undeclared (first use in this function)
    dict_db.c:238: error: parse error before ')' token
    dict_db.c:239: error: `DB' undeclared (first use in this function)
    dict_db.c:239: error: `db' undeclared (first use in this function)
    dict_db.c:240: error: `DBT' undeclared (first use in this function)
    dict_db.c:240: error: parse error before "db_key"
    dict_db.c:250: error: `db_key' undeclared (first use in this function)
    dict_db.c:251: error: `db_value' undeclared (first use in this function)
    dict_db.c:288: error: `R_NOOVERWRITE' undeclared (first use in this function)
    dict_db.c: In function `dict_db_delete':
    dict_db.c:315: error: `dict_db' undeclared (first use in this function)
    dict_db.c:315: error: parse error before ')' token
    dict_db.c:316: error: `DB' undeclared (first use in this function)
    dict_db.c:316: error: `db' undeclared (first use in this function)
    dict_db.c:317: error: `DBT' undeclared (first use in this function)
    dict_db.c:317: error: parse error before "db_key"
    dict_db.c:327: error: `db_key' undeclared (first use in this function)
    dict_db.c: In function `dict_db_sequence':
    dict_db.c:381: error: `dict_db' undeclared (first use in this function)
    dict_db.c:381: error: parse error before ')' token
    dict_db.c:382: error: `DB' undeclared (first use in this function)
    dict_db.c:382: error: `db' undeclared (first use in this function)
    dict_db.c:383: error: `DBT' undeclared (first use in this function)
    dict_db.c:383: error: parse error before "db_key"
    dict_db.c:453: error: `R_FIRST' undeclared (first use in this function)
    dict_db.c:456: error: `R_NEXT' undeclared (first use in this function)
    dict_db.c:469: error: `db_key' undeclared (first use in this function)
    dict_db.c:469: error: `db_value' undeclared (first use in this function)
    dict_db.c: In function `dict_db_close':
    dict_db.c:495: error: `dict_db' undeclared (first use in this function)
    dict_db.c:495: error: parse error before ')' token
    dict_db.c: In function `dict_db_open':
    dict_db.c:517: error: `dict_db' undeclared (first use in this function)
    dict_db.c:519: error: `DB' undeclared (first use in this function)
    dict_db.c:519: error: `db' undeclared (first use in this function)
    dict_db.c:639: error: parse error before ')' token
    dict_db.c: In function `dict_hash_open':
    dict_db.c:682: error: `HASHINFO' undeclared (first use in this function)
    dict_db.c:682: error: parse error before "tweak"
    dict_db.c:684: error: `tweak' undeclared (first use in this function)
    dict_db.c:700: error: `DB_HASH' undeclared (first use in this function)
    dict_db.c: In function `dict_btree_open':
    dict_db.c:709: error: `BTREEINFO' undeclared (first use in this function)
    dict_db.c:709: error: parse error before "tweak"
    dict_db.c:711: error: `tweak' undeclared (first use in this function)
    dict_db.c:726: error: `DB_BTREE' undeclared (first use in this function)
    make: ** [dict_db.o] Erro 1
    make: ** [update] Erro 1
    Procure o tuto do marco maximo ele e otimo, coloquei aqui o postfix+mysql no conectiva 10 e infelizmente nao tem pacotes compilados no cl 10. a proposito este erro ocorre por dependencia na lib do db que nao foram resolvidas, coloquei os pacotes para resolver as dependencia no post que vc colocou no grupo serv. email. Faca o procedimento e coloque o resultado que obteve.
    Padrão Nem to consiguindo
    Citação Postado originalmente por oyama
    pois colega, tentei fazer o que vc disse, mas qdo sou o apt-get com os arq. ele me retornam que ja estão na versão atualizada, se puder dar mais ajuda ae agradeço.
    Vamos la novamente, dando uma lida no tuto do marco as dependencia para compilar o postfix e:
    libdbtcl3.3
    libdb3.3-devel
    apt-get install db4-*
    libmysql12-devel
    apt-get install libmysql*
    urpmi libpcre0-devel
    apt-get install pcre pcre-devel*
    libsasl2-devel
    apt-get install sasl2-devel*
    pela sua msg, vc deve esta unsando o cl 10 exatamente a mesma que uso. se der erro posta o mardito!!
    whinston
    Padrão acompanhando..
    soh de zoio :roll:
    libdbtcl3.3
    libdb3.3-devel
    libmysql12-devel
    libsasl2-devel
    Vlw, deu certo colega, unica coisa que tinha dado era problema de caminho, mais isto eu resolvi e consegui compilar, bacana, vlw. pela ajuda.
    Ae vai outra pergunta, ja conf alguma vpn.
