  1. se alguem ler o artigo vai ver q isso ta lah...............
    LEIAM
    ler faz bem
  2. Citação Postado originalmente por gatoseco
    Entao coloca essa regra no final so seu script de firewall e pede pra alguem scanear seu micro e ver quantas portas aparecem abertas !!!
    Dai volta ao topico e me conta!!!
    soh pra provar,se nao for o teu modem que ta bloqueando:
    Código :
    root@[lfs]:~# nmap -n -vv -sF -P0 -O 200.19X.XX.48
    Starting nmap 3.81 ( http://www.insecure.org/nmap/ ) at 2005-04-17 21:35 BRT
    Initiating FIN Scan against 200.19X.XX.48 [1663 ports] at 21:35
    FIN Scan Timing: About 26.14% done; ETC: 21:37 (0:01:25 remaining)
    FIN Scan Timing: About 71.50% done; ETC: 21:38 (0:00:46 remaining)
    The FIN Scan took 184.50s to scan 1663 total ports.
    Warning:  OS detection will be MUCH less reliable because we did not find at least 1 open and 1 closed TCP port
    Host 200.19X.XX.48 appears to be up ... good.
    Interesting ports on 200.19X.XX.48:
    (The 1662 ports scanned but not shown below are in state: closed)
    PORT   STATE         SERVICE
    80/tcp open|filtered http
    Too many fingerprints match this host to give specific OS details
    TCP/IP fingerprint:
    SInfo(V=3.81%P=i686-pc-linux-gnu%D=4/17%Tm=426301A4%O=-1%C=1)
    T5(Resp=Y%DF=N%W=0%ACK=S++%Flags=AR%Ops=)
    T6(Resp=Y%DF=N%W=0%ACK=O%Flags=R%Ops=)
    T7(Resp=Y%DF=N%W=0%ACK=S++%Flags=AR%Ops=)
    PU(Resp=Y%DF=N%TOS=0%IPLEN=38%RIPTL=148%RID=E%RIPCK=E%UCK=E%ULEN=134%DAT=E)
    Nmap finished: 1 IP address (1 host up) scanned in 193.075 seconds
                   Raw packets sent: 1714 (68.7KB) | Rcvd: 3275 (151KB)
    e esse do wrochal
    Código :
    root@[lfs]:~# nmap -n -vv -sF -P0 -O 200.16X.XX.176
    Starting nmap 3.81 ( http://www.insecure.org/nmap/ ) at 2005-04-17 21:43 BRT
    Initiating FIN Scan against 200.16X.XX.176 [1663 ports] at 21:43
    The FIN Scan took 22.87s to scan 1663 total ports.
    Host 200.16X.XX.176 appears to be up ... good.
    Interesting ports on 200.16X.XX.176:
    (The 1646 ports scanned but not shown below are in state: closed)
    PORT      STATE         SERVICE
    21/tcp    open|filtered ftp
    25/tcp    open|filtered smtp
    81/tcp    open|filtered hosts2-ns
    135/tcp   open|filtered msrpc
    139/tcp   open|filtered netbios-ssn
    443/tcp   open|filtered https
    445/tcp   open|filtered microsoft-ds
    593/tcp   open|filtered http-rpc-epmap
    1080/tcp  open|filtered socks
    3128/tcp  open|filtered squid-http
    4444/tcp  open|filtered krb524
    4480/tcp  open|filtered proxy-plus
    6588/tcp  open|filtered analogx
    8000/tcp  open|filtered http-alt
    8080/tcp  open|filtered http-proxy
    19150/tcp open|filtered gkrellmd
    TCP/IP fingerprint:
    SInfo(V=3.81%P=i686-pc-linux-gnu%D=4/17%Tm=426302CF%O=-1%C=1)
    T5(Resp=Y%DF=Y%W=0%ACK=S++%Flags=AR%Ops=)
    T6(Resp=Y%DF=Y%W=0%ACK=O%Flags=R%Ops=)
    T7(Resp=Y%DF=Y%W=0%ACK=S++%Flags=AR%Ops=)
    PU(Resp=Y%DF=N%TOS=C0%IPLEN=164%RIPTL=148%RID=E%RIPCK=E%UCK=E%ULEN=134%DAT=E)
    Nmap finished: 1 IP address (1 host up) scanned in 27.757 seconds
                   Raw packets sent: 1723 (69.1KB) | Rcvd: 3088 (143KB)
  3. Pois e 1c3_m4n ja que ler faz bem e eu concordo com vc da uma olhada nesse artigo que tenho escrito com cerca de 120 linhas confiavel e robusto
    da uma analisada pra mim, so pra ver se esse ta bom se nao tiver me da um toque que dai vou continuar lendo artigos que fazem referencias a cinco linhas de comando !!! hehehe
    E lembre-se que quem criticou foi vc quando passei regras que poderiam ajudar nosso amigo aqui do forum , facil de aplicar e tambem de entender regras essas muito usadas por Carlos E. Morimoto por muito tempo considerado a personalidade do ano no mundo do software livre homem de poucas criticas e muitas contribuiçoes !!!
    http://www.linuxit.com.br/section-viewarticle-714.html
    Valeu galera espero mais uma vez ter ajudado!!!
  4. #14
    wrochal
    Melhor este
    iptables -A INPUT -j DROP
  5. Citação Postado originalmente por wrochal2002
    Melhor este
    Isso sim fecha tudo, como ESTA no artigo
    e gatoseco, como tb esta no artigo existem zilhoes de maneiras de se aplicar um firewall, tudo depende de como vc faz, e com foi feito aki neste topico se encaixa exatamente no aritgo q eu passei
    e no artigo q vc passou esta:
    # Politica de acesso
    iptables -P INPUT DROP
    Exatamente como eu recomendo no artigo q eu passei, ai eu concordo q fecha tudo
    mas iptables -A INPUT --syn -j DROP
    NUNCA VAI FECHAR TUDO
    Mais um detalhe tamanho num eh porra nenhuma em iptables....... basta 1 linha pra fechar tudo,
  1. Problemas com regras de Firewall
    Por Felipe_ no fórum Servidores de Rede
    Respostas: 9
    Último Post: 24-08-2004, 18:54
  2. Vejam as minhas regras de firewall
    Por Abutre no fórum Servidores de Rede
    Último Post: 12-09-2003, 14:33
  3. regras de firewall
    Por roggy no fórum Servidores de Rede
    Último Post: 17-05-2003, 10:47
  4. Respostas: 3
    Último Post: 27-03-2003, 12:17
  5. Regras de firewall
    Por Skill no fórum Servidores de Rede
    Último Post: 26-02-2003, 10:49
