Página 6 de 8 PrimeiroPrimeiro ... 2345678 ÚltimoÚltimo
    tmenace
    no começo dos hhtps_access tem um allow all
    olha como q tah o meu squid.conf agora.
    http_port 3128
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl minharede src 100.100.100.0/255.255.255.0
    acl CONNECT method CONNECT
    http_access allow all
    http_access deny manager
    http_access deny !Safe_ports
    http_access allow localhost
    http_access allow minharede
    http_access deny all
    icp_access allow all
    visible_hostname dominio.com.br
    :toim:
    to ateh com vergonha já.
  2. pelo amor de deus e pelo seu servidor tire aquele allow all de lah (a num ser q vc esteja bloqueando via iptables)
    inicia o squid com
    squid -d 6
    tenta acessar o proxy
    e cola tudo q aparecer na tela aki
  3. #28
    tmenace
    [root@gatewaycairu root]# squid -d 6
    2005/04/14 18:52:52| Starting Squid Cache version 2.4.STABLE7 for i686-pc-linux-gnu...
    2005/04/14 18:52:52| Process ID 7089
    2005/04/14 18:52:52| With 1024 file descriptors available
    2005/04/14 18:52:52| Performing DNS Tests...
    [root@gatewaycairu root]# 2005/04/14 18:52:52| Successful DNS name lookup tests...
    2005/04/14 18:52:52| DNS Socket created on FD 4
    2005/04/14 18:52:52| Adding nameserver 200.175.5.139 from /etc/resolv.conf
    2005/04/14 18:52:52| Adding nameserver 200.175.89.139 from /etc/resolv.conf
    2005/04/14 18:52:52| Unlinkd pipe opened on FD 9
    2005/04/14 18:52:52| Swap maxSize 102400 KB, estimated 7876 objects
    2005/04/14 18:52:52| Target number of buckets: 393
    2005/04/14 18:52:52| Using 8192 Store buckets
    2005/04/14 18:52:52| Max Mem size: 8192 KB
    2005/04/14 18:52:52| Max Swap size: 102400 KB
    2005/04/14 18:52:52| Rebuilding storage in /var/spool/squid (CLEAN)
    2005/04/14 18:52:52| Using Least Load store dir selection
    2005/04/14 18:52:52| Set Current Directory to /var/spool/squid
    2005/04/14 18:52:52| Loaded Icons.
    2005/04/14 18:52:52| Accepting HTTP connections at 0.0.0.0, port 3128, FD 10.
    2005/04/14 18:52:52| Accepting ICP messages at 0.0.0.0, port 3130, FD 11.
    2005/04/14 18:52:52| WCCP Disabled.
    2005/04/14 18:52:52| Ready to serve requests.
    2005/04/14 18:52:52| Done scanning /var/spool/squid swaplog (0 entries)
    2005/04/14 18:52:52| Finished rebuilding storage from disk.
    2005/04/14 18:52:52| 0 Entries scanned
    2005/04/14 18:52:52| 0 Invalid entries.
    2005/04/14 18:52:52| 0 With invalid flags.
    2005/04/14 18:52:52| 0 Objects loaded.
    2005/04/14 18:52:52| 0 Objects expired.
    2005/04/14 18:52:52| 0 Objects cancelled.
    2005/04/14 18:52:52| 0 Duplicate URLs purged.
    2005/04/14 18:52:52| 0 Swapfile clashes avoided.
    2005/04/14 18:52:52| Took 0.6 seconds ( 0.0 objects/sec).
    2005/04/14 18:52:52| Beginning Validation Procedure
    2005/04/14 18:52:52| Completed Validation Procedure
    2005/04/14 18:52:52| Validated 0 Entries
    2005/04/14 18:52:52| store_swap_size = 84k
    2005/04/14 18:52:53| storeLateRelease: released 0 objects
    kramba, q dor de kbeça
    :toim:
  4. bom ele ta rodando mesmo:
    agora resta saber pq tua rede nao ta acessando, qdo ocliente tenta acessar num aparace nada no error_log?
    e olha se o fw nao ta bloqueando, se for o fw... :@:
  5. #30
    tmenace
    droga, era o firewall. pode ficar puto da kra comigo!
    :good:
    agora vou tentar funfar o proxy transparente. valew!
  1. Preciso de um servidor de cache que seja funcional
    Por elvisjunior no fórum Servidores de Rede
    Respostas: 40
    Último Post: 21-03-2014, 18:00
  2. Ajuda para montar um squid - iptables - QUE FUNCIONE
    Por robsonccav no fórum Servidores de Rede
    Último Post: 10-10-2013, 13:27
  3. Respostas: 19
    Último Post: 10-10-2011, 06:39
  4. Preciso de um Webmaster (Curitiba)
    Por Perdigao no fórum Linguagens de Programação
    Último Post: 14-08-2003, 08:53
  5. Preciso de um manual do Squid
    Por Honda no fórum Servidores de Rede
    Último Post: 23-06-2003, 12:37
