    capgaiotto
    Padrão Squid não inicia
    ok
    pilantrox
    Ok ,, valeu ,,, acho q naum vou precisar por enquanto....
    Citação Postado originalmente por Benatto
    na boa cara
    faz assim remove o squid em rpm
    e instala ele pelo codigo fonte
    te garanto que vai funcionar
    pilantrox Enviada: Sex Abr 22, 2005 3:55 pm Assunto:
    ai velho ,,, vc pode me dizer pra que serve essa linha que esta naquele squid.conf
    "coredump_dir /var/cache/squid"
    seguinte se eu naum me engano este linha é para que se o cache estourar ele use outro diretorio
    pilantrox
    Aproveitando a deixa do squid,,,, naum sei se jah postaram aqui no forum sobre isso mas tah aparecendo umas linhas no meu cache.log q naum consegui descobrir onde tah o erro,,, instalei o squid em dois servidores estaum basicamente identicos , e apenas em um server dah esse erro ,,,,
    2005/04/22 04:09:02| sslReadServer: FD 83: read failure: (104) Connection reset by peer
    2005/04/22 04:09:03| sslReadServer: FD 113: read failure: (104) Connection reset by peer
    2005/04/22 04:09:04| sslReadServer: FD 61: read failure: (104) Connection reset by peer
    2005/04/22 04:09:06| sslReadServer: FD 59: read failure: (104) Connection reset by peer
    2005/04/22 04:09:08| sslReadServer: FD 56: read failure: (104) Connection reset by peer
    2005/04/22 04:09:30| sslReadServer: FD 62: read failure: (104) Connection reset by peer
    2005/04/22 04:09:51| sslReadServer: FD 62: read failure: (104) Connection reset by peer
    2005/04/22 04:09:56| sslReadServer: FD 38: read failure: (104) Connection reset by peer
    2005/04/22 04:09:57| sslReadServer: FD 55: read failure: (104) Connection reset by peer
    2005/04/22 04:10:00| sslReadServer: FD 52: read failure: (104) Connection reset by peer
    2005/04/22 04:10:01| sslReadServer: FD 64: read failure: (104) Connection reset by peer
    2005/04/22 04:10:04| sslReadServer: FD 40: read failure: (104) Connection reset by peer
    2005/04/22 04:10:04| sslReadServer: FD 73: read failure: (104) Connection reset by peer
    2005/04/22 04:10:07| sslReadServer: FD 56: read failure: (104) Connection reset by peer
    2005/04/22 04:10:10| sslReadServer: FD 63: read failure: (104) Connection reset by peer
    2005/04/22 04:10:11| sslReadServer: FD 69: read failure: (104) Connection reset by peer
    2005/04/22 04:10:14| sslReadServer: FD 31: read failure: (104) Connection reset by peer
    2005/04/22 04:10:14| sslReadServer: FD 63: read failure: (104) Connection reset by peer
    E tem horas que o trafego tah baxinho e o navegador demora pra encontra o site , to achando que eh por esse erro !! alguem pode me dah uma ajuda....
    Moderador Avatar de Bruno
    Nov 2002
    Guarapuava-PR
    fala ai pilantrox
    posta ai seu squid.conf
    pilantrox
    fala ai pilantrox
    Ai Benatto....... tah na mão,,,,,desculpa ai a demora ,,,mas eu estava com uns problemas fds.
    http_port 192.168.15.1:3128
    #esvazia o cache:
    cache_swap_low 90
    cache_swap_high 93
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    # memoria usada:
    cache_mem 32 MB
    maximum_object_size 6144 KB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 32 KB
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 93
    cache_replacement_policy lru
    memory_replacement_policy lru
    cache_dir ufs /var/spool/squid 7000 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    acl rede src 192.168.0.0/255.255.255.0
    acl rede1 src 10.10.10.0/255.255.255.0
    acl rede2 src 20.20.20.0/255.255.255.0
    acl rede3 src 30.30.30.0/255.255.255.0
    acl rede4 src 90.90.90.0/255.255.255.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    http_access allow localhost
    http_access allow rede
    http_access allow rede1
    http_access allow rede2
    http_access allow rede3
    http_access allow rede4
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
    cache_effective_user squid
    cache_effective_group squid
    ele tah lento pra resolver as solicitacoes....
    capgaiotto
    Fala ae pessoal!
    Achei a fonte do meu problema. Estava no arquivo ifcfg-eth0 referente a placa que comunicava com o Speedy. NETMASK não era 255.255.255.0 e sim 255.255.255.194 ops:
    Valeu pela ajuda pessoal!
    Falou!
    Gaiotto
