    capgaiotto
    ok
    pilantrox
    Ok ,, valeu ,,, acho q naum vou precisar por enquanto....
    Citação Postado originalmente por Benatto
    na boa cara
    faz assim remove o squid em rpm
    e instala ele pelo codigo fonte
    te garanto que vai funcionar
    pilantrox Enviada: Sex Abr 22, 2005 3:55 pm Assunto:
    ai velho ,,, vc pode me dizer pra que serve essa linha que esta naquele squid.conf
    "coredump_dir /var/cache/squid"
    seguinte se eu naum me engano este linha é para que se o cache estourar ele use outro diretorio
    pilantrox
    Aproveitando a deixa do squid,,,, naum sei se jah postaram aqui no forum sobre isso mas tah aparecendo umas linhas no meu cache.log q naum consegui descobrir onde tah o erro,,, instalei o squid em dois servidores estaum basicamente identicos , e apenas em um server dah esse erro ,,,,
    2005/04/22 04:09:02| sslReadServer: FD 83: read failure: (104) Connection reset by peer
    2005/04/22 04:09:03| sslReadServer: FD 113: read failure: (104) Connection reset by peer
    2005/04/22 04:09:04| sslReadServer: FD 61: read failure: (104) Connection reset by peer
    2005/04/22 04:09:06| sslReadServer: FD 59: read failure: (104) Connection reset by peer
    2005/04/22 04:09:08| sslReadServer: FD 56: read failure: (104) Connection reset by peer
    2005/04/22 04:09:30| sslReadServer: FD 62: read failure: (104) Connection reset by peer
    2005/04/22 04:09:51| sslReadServer: FD 62: read failure: (104) Connection reset by peer
    2005/04/22 04:09:56| sslReadServer: FD 38: read failure: (104) Connection reset by peer
    2005/04/22 04:09:57| sslReadServer: FD 55: read failure: (104) Connection reset by peer
    2005/04/22 04:10:00| sslReadServer: FD 52: read failure: (104) Connection reset by peer
    2005/04/22 04:10:01| sslReadServer: FD 64: read failure: (104) Connection reset by peer
    2005/04/22 04:10:04| sslReadServer: FD 40: read failure: (104) Connection reset by peer
    2005/04/22 04:10:04| sslReadServer: FD 73: read failure: (104) Connection reset by peer
    2005/04/22 04:10:07| sslReadServer: FD 56: read failure: (104) Connection reset by peer
    2005/04/22 04:10:10| sslReadServer: FD 63: read failure: (104) Connection reset by peer
    2005/04/22 04:10:11| sslReadServer: FD 69: read failure: (104) Connection reset by peer
    2005/04/22 04:10:14| sslReadServer: FD 31: read failure: (104) Connection reset by peer
    2005/04/22 04:10:14| sslReadServer: FD 63: read failure: (104) Connection reset by peer
    E tem horas que o trafego tah baxinho e o navegador demora pra encontra o site , to achando que eh por esse erro !! alguem pode me dah uma ajuda....
  4. fala ai pilantrox
    posta ai seu squid.conf
    pilantrox
    fala ai pilantrox
    Ai Benatto....... tah na mão,,,,,desculpa ai a demora ,,,mas eu estava com uns problemas fds.
    http_port 192.168.15.1:3128
    #esvazia o cache:
    cache_swap_low 90
    cache_swap_high 93
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    # memoria usada:
    cache_mem 32 MB
    maximum_object_size 6144 KB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 32 KB
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 93
    cache_replacement_policy lru
    memory_replacement_policy lru
    cache_dir ufs /var/spool/squid 7000 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    acl rede src 192.168.0.0/255.255.255.0
    acl rede1 src 10.10.10.0/255.255.255.0
    acl rede2 src 20.20.20.0/255.255.255.0
    acl rede3 src 30.30.30.0/255.255.255.0
    acl rede4 src 90.90.90.0/255.255.255.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    http_access allow localhost
    http_access allow rede
    http_access allow rede1
    http_access allow rede2
    http_access allow rede3
    http_access allow rede4
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
    cache_effective_user squid
    cache_effective_group squid
    ele tah lento pra resolver as solicitacoes....
  1. Squid não inicia
    Último Post: 10-10-2004, 17:14
  2. Compilação Squid - Não inicia !!!
    Por Beto no fórum Servidores de Rede
    Respostas: 6
    Último Post: 01-06-2004, 20:35
  3. Squid não inicia
    Por guardian_metal no fórum Servidores de Rede
    Respostas: 17
    Último Post: 29-09-2003, 16:11
  4. Squid não inicia
    Último Post: 11-06-2003, 14:02
  5. Squid não inicia
    Último Post: 11-06-2003, 12:27
