  1. vc não possue esse arquivo em nenhum lugar ?? da um locate libiptc.h e ve se ele existe...
    Vc pegou o pacote tbz do iptables e copiou io contuedo do include para /usr/include/iptables ???
  2. esta nos includes do iptables
  3. #8
    vejam o erro que acontece aqui:
    make
    make -C iptables
    make[1]: Entering directory `/home/backup/iptables-p2p-0.3.0a/iptables'
    gcc -O2 -Wall -DIPTABLES_VERSION=\"1.3.1\" -I../common -c -o libipt_p2p.o libip
    t_p2p.c
    In file included from /usr/include/iptables/iptables.h:5,
    from libipt_p2p.c:23:
    /usr/include/iptables/libiptc/libiptc.h:5:70: /usr/include/iptables/libiptc/libi
    ptc/ipt_kernel_headers.h: No such file or directory
    In file included from /usr/include/linux/netfilter_ipv4/ip_tables.h:25,
    from /usr/include/iptables/libiptc/libiptc.h:6,
    /usr/include/linux/netfilter_ipv4.h:53: error: `INT_MIN' undeclared here (not in
    a function)
    /usr/include/linux/netfilter_ipv4.h:53: error: enumerator value for `NF_IP_PRI_F
    IRST' not integer constant
    /usr/include/linux/netfilter_ipv4.h:59: error: `INT_MAX' undeclared here (not in
    a function)
    /usr/include/linux/netfilter_ipv4.h:59: error: enumerator value for `NF_IP_PRI_L
    AST' not integer constant
    In file included from /usr/include/iptables/libiptc/libiptc.h:6,
    /usr/include/linux/netfilter_ipv4/ip_tables.h:33: error: field `src' has incompl
    ete type
    /usr/include/linux/netfilter_ipv4/ip_tables.h:33: error: field `dst' has incompl
    ete type
    /usr/include/linux/netfilter_ipv4/ip_tables.h:35: error: field `smsk' has incomp
    lete type
    /usr/include/linux/netfilter_ipv4/ip_tables.h:35: error: field `dmsk' has incomp
    lete type
    /usr/include/linux/netfilter_ipv4/ip_tables.h:36: error: `IFNAMSIZ' undeclared h
    ere (not in a function)
    /usr/include/linux/netfilter_ipv4/ip_tables.h:37: error: `IFNAMSIZ' undeclared h
    libipt_p2p.c:73: warning: initialization makes integer from pointer without a ca
    st
    libipt_p2p.c:73: error: initializer element is not computable at load time
    libipt_p2p.c:73: error: (near initialization for `p2p.revision')
    libipt_p2p.c:74: warning: initialization makes pointer from integer without a ca
    st
    libipt_p2p.c:76: warning: initialization makes integer from pointer without a ca
    st
    libipt_p2p.c:77: warning: initialization from incompatible pointer type
    libipt_p2p.c:78: warning: initialization from incompatible pointer type
    libipt_p2p.c:79: warning: initialization from incompatible pointer type
    libipt_p2p.c:80: warning: initialization from incompatible pointer type
    libipt_p2p.c:81: warning: initialization from incompatible pointer type
    libipt_p2p.c:83: warning: initialization from incompatible pointer type
    /usr/include/linux/netfilter_ipv4/ip_tables.h:339: warning: `DECLARE_MUTEX' decl
    ared `static' but never defined
    make[1]: *** [libipt_p2p.o] Error 1
    make[1]: Leaving directory `/home/backup/iptables-p2p-0.3.0a/iptables'
    make: *** [linux-2.4] Error 2
    O que pode ser?? :@: :@:
  4. jah q vc vai ter q recompilar de qq jeito, eh melhor usar o l7 do que o p2p
    https://under-linux.org/noticia4799.html
  1. iptables-p2p!!!
    Por ecbr no fórum Servidores de Rede
    Respostas: 9
    Último Post: 15-02-2005, 08:05
  2. Problema na compilação do iptables-p2p
    Por Daniels no fórum Servidores de Rede
    Último Post: 21-10-2004, 16:39
  3. iptables-p2p
    Por vandemberg no fórum Servidores de Rede
    Último Post: 12-07-2004, 09:05
  4. Iptables-p2p problemas na instalação
    Por Thon no fórum Servidores de Rede
    Respostas: 23
    Último Post: 11-07-2004, 11:10
  5. compilar iptables-p2p
    Por fabmotcam no fórum Servidores de Rede
    Último Post: 03-04-2004, 19:04
