Página 4 de 9 PrimeiroPrimeiro 12345678 ... ÚltimoÚltimo
  1. Se puder manda o named.conf também....
  2. #17
    fpmazzi
    aki vai um trecho do /var/log/messages
    Aug 30 23:40:03 mclaren kernel: parport0: irq 7 detected
    Aug 30 23:40:03 mclaren kernel: lp0: using parport0 (polling).
    Aug 30 23:40:03 mclaren kernel: lp0: console ready
    Aug 30 23:40:05 mclaren cups: início de cupsd succeeded
    Aug 31 02:40:06 mclaren named[1933]: starting BIND 9.2.3 -u named -t /var/named/chroot
    Aug 31 02:40:06 mclaren named[1933]: using 1 CPU
    Aug 31 02:40:06 mclaren named[1933]: loading configuration from '/etc/named.conf'
    Aug 31 02:40:06 mclaren named[1933]: listening on IPv4 interface lo, 127.0.0.1#53
    Aug 31 02:40:06 mclaren named[1933]: listening on IPv4 interface eth0, 192.168.0.200#53
    Aug 31 02:40:06 mclaren named[1933]: couldn't add command channel 127.0.0.1#953: not found
    Aug 31 02:40:06 mclaren named[1933]: couldn't add command channel ::1#953: not found
    Aug 31 02:40:06 mclaren named[1933]: zone people.salto.br/IN: loading master file people.salto.br.zone: file not found
    Aug 31 02:40:06 mclaren named[1933]: running
    Aug 30 23:40:06 mclaren named: início de named succeeded
    Aug 30 23:40:06 mclaren sshd: succeeded
    Aug 30 23:40:06 mclaren xinetd: início de xinetd succeeded
    Aug 30 23:40:07 mclaren xinetd[1961]: xinetd Version 2.3.13 started with libwrap loadavg options compiled in.
    Aug 30 23:40:07 mclaren xinetd[1961]: Started working: 1 available service
    Aug 30 23:40:07 mclaren sendmail: início de sendmail succeeded
    Aug 30 23:40:07 mclaren sendmail: início de sm-client succeeded
    Aug 30 23:40:08 mclaren gpm[2020]: *** info [startup.c(95)]:
    Aug 30 23:40:08 mclaren gpm[2020]: Started gpm successfully. Entered daemon mode.
    Aug 30 23:40:08 mclaren gpm[2020]: *** info [mice.c(1766)]:
    Aug 30 23:40:08 mclaren gpm[2020]: imps2: Auto-detected intellimouse PS/2
    Aug 30 23:40:08 mclaren gpm: início de gpm succeeded
    Aug 30 23:40:08 mclaren crond: início de crond succeeded
    Aug 30 23:40:09 mclaren xfs: início de xfs succeeded
    Aug 30 23:40:09 mclaren anacron: início de anacron succeeded
    Aug 30 23:40:09 mclaren atd: início de atd succeeded
    Aug 30 23:40:09 mclaren readahead: Iniciando leitura adiantada em segundo plano:
    Aug 30 23:40:09 mclaren rc: Starting readahead: succeeded
    Aug 30 23:40:10 mclaren messagebus: início de messagebus succeeded
    Aug 30 23:40:10 mclaren mdmonitor: mdadm succeeded
    Aug 30 23:40:11 mclaren mdmpd: mdmpd failed
    Aug 30 23:40:11 mclaren init: open(/dev/pts/0): No such file or directory
    Aug 30 23:48:46 mclaren sshd(pam_unix)[2413]: session opened for user root by (uid=0)
  3. #18
    fpmazzi
    Pessoal aki esta o named.conf
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    // a caching only nameserver config
    controls {
    inet 127.0.0.1 allow { localhost; } keys { rndckey; };
    zone "." IN {
    type hint;
    file "named.ca";
    zone "localhost" IN {
    type master;
    file "localhost.zone";
    allow-update { none; };
    zone "0.0.127.in-addr.arpa" IN {
    type master;
    file "named.local";
    include "/etc/rndc.key";
  4. #19
    robsonzornitta
    cara tu vai me desculpar mas no log acima diz qua tah faltandu uns arquivos e tals teu named.conf tah todo desreguladu
    gostaria de saber algumas informações pra mim montah os arquivos prontos pra tu copiar e fazer rodar issu ai pode ser?
    1: ip interno de lan da tua maquina linux ex: 192.168.0.2
    2: dominio que tu quer colocar ex: seila.com.br
    3: qual a verssaum do teu bind? eh a 9?
    4? vc vai querer o que como apelido? ex: www.seila.com.br, ftp.seila.com.br, irc.seila.com.br
    se vc me passar issu eu monto pra vc copiar
    :good:
  5. #20
    fpmazzi
    Citação Postado originalmente por robsonzornitta
    :good:
    aki vai ser o ip interno: 192.168.100.1
    dominio: people.salto.br
    bind 9.2.3-13
    apelido: www.people.salto.br
    :good:
  1. Respostas: 2
    Último Post: 24-12-2010, 10:49
  2. Problemas com YUM no fedora 3!!! public.gpg.key
    Por rafaeljoselitu no fórum Sistemas Operacionais
    Último Post: 14-03-2007, 09:57
  3. Problemas com foreign key no MYSQL...
    Por kallunga no fórum Servidores de Rede
    Respostas: 6
    Último Post: 09-03-2005, 15:50
  4. Problema com o ssh pelo windows !!!
    Por embbr no fórum Servidores de Rede
    Último Post: 01-07-2002, 18:10
  5. problemas com o IMP
    Por marlonfuchs no fórum Servidores de Rede
    Último Post: 27-06-2002, 08:13
