    Padrão Proxy Transparente
    Pessoal ja quebrei a cabeça e não consigo achar onde esta o erro (ou estou muito cego hehehe :toim: ).
    A situação é a seguinte:
    Não consigo usar proxy transparente as páginas simplesmente não abrem em nenhum cliente. Mas se marcar as configurações de proxy no browser ai funciona perfeitamente. Segue abaixo meu squid.conf e meu firewall.
    Squid.conf
    Código :
    http_port 8080
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    cache_dir ufs /var/spool/squid 7000 16 256
    cache_log /var/log/squid/cache.log
    pid_filename /var/run/squid.pid
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    program /usr/lib/squid/ncsa_auth /etc/squid/squid_passwd
    refresh_pattern ^ftp:		1440	20%	10080
    refresh_pattern ^gopher:	1440	0%	1440
    refresh_pattern .		0	20%	4320
    acl all src 0.0.0.0/0.0.0.0
    acl mynet src 192.168.1.0/255.255.255.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80		# http
    acl Safe_ports port 21		# ftp
    acl Safe_ports port 443 563	# https, snews
    acl Safe_ports port 70		# gopher
    acl Safe_ports port 210		# wais
    acl Safe_ports port 1025-65535	# unregistered ports
    acl Safe_ports port 280		# http-mgmt
    acl Safe_ports port 488		# gss-http
    acl Safe_ports port 591		# filemaker
    acl Safe_ports port 777		# multiling http
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny !Safe_ports
    http_access allow mynet
    http_access allow localhost
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    cache_mgr [email][email protected][/email]
    cache_effective_user squid
    cache_effective_group squid
    httpd_accel_port 80
    httpd_accel_port 21
    httpd_accel_host virtual
    httpd_accel_with_proxy on
    visible_hostname ns.meuhost.com
    error_directory /etc/squid/errors
    coredump_dir /var/spool/squid
    Firewall
    Código :
    #!/bin/bash
    # Variaveis
    iptables=/sbin/iptables
    IF_EXTERNA=ppp0
    IF_INTERNA=eth0
    echo "Variaveis OK!"
    # Ativa modulos
    /sbin/modprobe iptable_nat
    /sbin/modprobe ip_conntrack
    /sbin/modprobe ip_conntrack_ftp
    /sbin/modprobe ip_nat_ftp
    /sbin/modprobe ipt_LOG
    /sbin/modprobe ipt_REJECT
    /sbin/modprobe ipt_MASQUERADE
    echo "Carga dos Modulos OK!"
    # Ativa roteamento no kernel
    echo "1" > /proc/sys/net/ipv4/ip_forward
    echo "Roteamento OK!"
    # Protecao contra IP spoofing
    echo "1" > /proc/sys/net/ipv4/conf/all/rp_filter
    echo "Protecao contra IP Spoofing OK!"
    # Zera regras
    $iptables -F
    $iptables -X
    $iptables -F -t nat
    $iptables -X -t nat
    $iptables -F -t mangle
    $iptables -X -t mangle
    echo "Flush das regras OK!"
    # Determina a politica padrao
    $iptables -P INPUT DROP
    $iptables -P OUTPUT DROP
    $iptables -P FORWARD DROP
    echo "Politica padrao OK!"
    # Dropa pacotes TCP indesejaveis
    $iptables -A FORWARD -p tcp ! --syn -m state --state NEW -j LOG --log-level 6 --log-prefix "FIREWALL: NEW sem syn: "
    $iptables -A FORWARD -p tcp ! --syn -m state --state NEW -j DROP
    # Dropa pacotes mal formados
    #$iptables -A INPUT -i $IF_EXTERNA -m unclean -j LOG --log-level 6 --log-prefix "FIREWALL: Pac. Mal Formado: "
    #$iptables -A INPUT -i $IF_EXTERNA -m unclean -j DROP
    # Protecao contra worms
    $iptables -A FORWARD -p tcp --dport 135 -i $IF_INTERNA -j REJECT
    # Aceita os pacotes que realmente devem entrar
    $iptables -A INPUT -i ! $IF_EXTERNA -j ACCEPT
    $iptables -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
    $iptables -A OUTPUT -m state --state ESTABLISHED,RELATED,NEW -j ACCEPT
    $iptables -A FORWARD -m state --state ESTABLISHED,RELATED,NEW -j ACCEPT
    echo "Pacotes IN/OUT OK!"
    # Protecao contra trinoo
    $iptables -N TRINOO
    $iptables -A TRINOO -m limit --limit 15/m -j LOG --log-level 6 --log-prefix "FIREWALL: trinoo: "
    $iptables -A TRINOO -j DROP
    $iptables -A INPUT -p tcp -i $IF_EXTERNA --dport 27444 -j TRINOO
    $iptables -A INPUT -p tcp -i $IF_EXTERNA --dport 27665 -j TRINOO
    $iptables -A INPUT -p tcp -i $IF_EXTERNA --dport 31335 -j TRINOO
    $iptables -A INPUT -p tcp -i $IF_EXTERNA --dport 34555 -j TRINOO
    $iptables -A INPUT -p tcp -i $IF_EXTERNA --dport 35555 -j TRINOO
    echo "Protecao contra TRINOO OK!"
    # Protecao contra tronjans
    $iptables -N TROJAN
    $iptables -A TROJAN -m limit --limit 15/m -j LOG --log-level 6 --log-prefix "FIREWALL: trojan: "
    $iptables -A TROJAN -j DROP
    $iptables -A INPUT -p tcp -i $IF_EXTERNA --dport 666 -j TROJAN
    $iptables -A INPUT -p tcp -i $IF_EXTERNA --dport 4000 -j TROJAN
    $iptables -A INPUT -p tcp -i $IF_EXTERNA --dport 6000 -j TROJAN
    $iptables -A INPUT -p tcp -i $IF_EXTERNA --dport 6006 -j TROJAN
    $iptables -A INPUT -p tcp -i $IF_EXTERNA --dport 16660 -j TROJAN
    echo "Protecao contra TROJANS OK!"
    # Protecao contra syn-flood
    $iptables -A FORWARD -p tcp --syn -m limit --limit 2/s -j ACCEPT
    $iptables -A FORWARD -p tcp -j DROP
    echo "Protecao contra SYN-FLOOD OK!"
    # Protecao contra ping da morte
    $iptables -A FORWARD -p icmp --icmp-type echo-request -m limit --limit 1/s -j ACCEPT
    $iptables -A FORWARD -p icmp -j DROP
    echo "Protecao contra Ping-Of-Death OK!"
    # Protecao contra port scanners
    $iptables -N SCANNER
    $iptables -A SCANNER -m limit --limit 15/m -j LOG --log-level 6 --log-prefix "FIREWALL: port scanner: "
    $iptables -A SCANNER -j DROP
    $iptables -A INPUT -p tcp --tcp-flags ALL FIN,URG,PSH -i $IF_EXTERNA -j SCANNER
    $iptables -A INPUT -p tcp --tcp-flags ALL NONE -i $IF_EXTERNA -j SCANNER
    $iptables -A INPUT -p tcp --tcp-flags ALL ALL -i $IF_EXTERNA -j SCANNER
    $iptables -A INPUT -p tcp --tcp-flags ALL FIN,SYN -i $IF_EXTERNA -j SCANNER
    $iptables -A INPUT -p tcp --tcp-flags ALL SYN,RST,ACK,FIN,URG -i $IF_EXTERNA -j SCANNER
    $iptables -A INPUT -p tcp --tcp-flags SYN,RST SYN,RST -i $IF_EXTERNA -j SCANNER
    $iptables -A INPUT -p tcp --tcp-flags SYN,FIN SYN,FIN -i $IF_EXTERNA -j SCANNER
    echo "Protecao contra Port-Scanners OK!"
    # Loga tentativa de acesso a determinadas portas
    $iptables -A INPUT -p tcp --dport 21 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: ftp: "
    $iptables -A INPUT -p tcp --dport 22 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: ssh: "
    $iptables -A INPUT -p tcp --dport 23 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: telnet: "
    $iptables -A INPUT -p tcp --dport 25 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: smtp: "
    $iptables -A INPUT -p tcp --dport 80 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: http: "
    $iptables -A INPUT -p tcp --dport 110 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: pop3: "
    $iptables -A INPUT -p udp --dport 111 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: rpc: "
    $iptables -A INPUT -p tcp --dport 113 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: identd: "
    $iptables -A INPUT -p tcp --dport 137:139 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: samba: "
    $iptables -A INPUT -p udp --dport 137:139 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: samba: "
    $iptables -A INPUT -p tcp --dport 143 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: IMAP: "
    $iptables -A INPUT -p tcp --dport 161:162 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: snmp: "
    $iptables -A INPUT -p tcp --dport 6667:6668 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: irc: "
    $iptables -A INPUT -p tcp --dport 3128 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: squid: "
    $iptables -A INPUT -p tcp --dport 8080 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: squid: "
    echo "Logs OK!"
    # Habilitando acesso a determinadas portas
    $iptables -A INPUT -p tcp --dport 21 -i $IF_EXTERNA -j ACCEPT
    $iptables -A INPUT -p tcp --dport 22 -i $IF_EXTERNA -j ACCEPT
    $iptables -A INPUT -p tcp --dport 25 -i $IF_EXTERNA -j ACCEPT
    $iptables -A INPUT -p udp --dport 53 -i $IF_EXTERNA -j ACCEPT
    $iptables -A INPUT -p tcp --dport 80 -i $IF_EXTERNA -j ACCEPT
    $iptables -A INPUT -p tcp --dport 110 -i $IF_EXTERNA -j ACCEPT
    $iptables -A INPUT -p tcp --dport 143 -i $IF_EXTERNA -j ACCEPT
    $iptables -A INPUT -p tcp --dport 443 -i $IF_EXTERNA -j ACCEPT
    echo "Acesso a determinadas portas OK!"
    # Proxy transparente
    $iptables -t nat -A PREROUTING -i $IF_INTERNA -p tcp --dport 80 -j REDIRECT --to-port 8080
    $iptables -t nat -A PREROUTING -i $IF_INTERNA -p tcp --dport 3128 -j REDIRECT --to-port 8080
    :cry: Pessoal li várias vz esses scripts e não consigo achar o problema, por favor
    Cara, acrescenta e corrige seu squid.conf:
    Código :
    httpd_accel_port 80
    visible_hostname nome_do_host
    hierarchy_stoplist cgi-bin \?
    http_port 127.0.0.1:8080
    icp_port 3130
    Outra, pq está redirecinando a porta 3128 se vc não tem ela setada em lugar nenhum? não é uma porta padrão do sistema, somos nós que temos que redirecionar para lá...
    Pode tirar do iptables.
    Espero que tenha te ajudado...
    Amigo a unica diferença entre o que vc citou e meu squid.conf é:
    Código :
    icp_port 3130
    Isso é a diferença, é o que esta faltando no meu?
    Há outra coisinha faz diferença em qual ordem esses httpd_accel estejam?
    Citação Postado originalmente por CFRInformatica
    Código :
    icp_port 3130
    se vc colocar 127.0.0.1:8080 sua rede nunca irá conseguir se conectar ao seu proxy.... deixe somente assim: http_port 8080
    e autenticação não funciona com proxy transparente......
    o iptables não esta barrando suas conexões na porta 8080? não achei onde vc esta liberando ela...
    Citação Postado originalmente por PiTsA
    Código :
    :roll: Ja to ficando maluco com isso
    E então pessoal ninguém se habilita?
    eskeci de te falar, vc jah tentou limpar o fw e deixar soh as regras de masquerade e o redir pra testar? to achando q tem alguma regra ai no meio q ta bloqueando o redir
    Ja consegui resolver, o problema todo estava nessas duas coisinhas:
    Código :
    httpd_accel_port 80
    httpd_accel_port 21
    Com elas o proxy transparente não funciona (pelo menos para mim);
    Mas agora lhes pergunto outra coisinha. As páginas de erro não aparecem quando se está usando proxy transparente? Tipo aquelas que aparecem quando usamos no squid.conf:
    Código :
    https://under-linux.org/images/forum/subject/icon5.gif
    Então alguem sabe pq não aparecem as mensagens de erro do squid?
