    Reedemer
    Padrão Acesso negado Slackware 10.0 kernel 2.6.11
    Caros colegas
    Estou tentando acessar o servidor de nome s1, mas está me retornando as mensagens permissão negada e depois 3 nomes, o que pode estar errado ?
    Sou iniciante no assunto SSH....
    qual arquivo devo
    [email protected]:~# ssh s1
    Permission denied, please try again.
    Permission denied (publickey,password,keyboard-interactive).
    tenta ssh [email protected]
    Reedemer
    Não funfou..
    [email protected]:~# ssh [email protected]
    ele ta pedindo a senha pra vc se conectar?
    nosferatusmg
    Less, SSH, man and other programs stopped working after upgrading to kernel 2.6.x.
    I've just installed a clean Slackware 10.0 and compliled a brand new 2.6.10 kernel for it. Using it for 2 days I've encountered several problems:
    First of all, I couldn't read man pages. eg: [email protected]:~# man links
    Error executing formatting or display command.
    System command /bin/bzip2 -c -d /usr/man/cat1/links.1.bz2 | /usr/bin/less -is exited with status 256.
    Second I tried less:
    Nothing happens, just returns to the command prompt.
    And when I tried ssh: [email protected]:~# ssh [email protected]
    ssh_askpass: exec(/usr/libexec/ssh-askpass): No such file or directory
    After a bit of googling, I found the following solution on LinuxQuestions.org:
    Open the file: /etc/udev/rules.d/udev.rules and change the line
    KERNEL="tty[p-za-e][0-9a-f]*", NAME="tty/s%n", SYMLINK="%k"
    to:
    KERNEL="tty[p-za-e][0-9a-f]*", NAME="pty/s%n", SYMLINK="%k"
    now run /etc/rc.d/rc.udev it should give output like:
    Initializing udev dynamic device directory.
    All should be good now. :-).. Hey what's that, gnome-terminal and rxvt won't start... well, a good old reboot worked for me
    meu deus o slack ta me decepcionando....... ainda nao arrumar o suporte a 2.6 sem dar pau????????
    antes o udev nao pegava as permissoes dos devices direito, agora mais essa =/
    Reedemer
    Vou tentar....imaginei que fosse algum problema com kernel 2.6
    Reedemer
    Padrão Esclarecimento
    Caro IceMan
    O senhor poderia me esclarecer o que o nosferatu fez ? o que seria aquele procedimento que ele escreveu ali ?
    Reedemer
    Padrão PERFEITO !!!
    FUNCIONOU PERFEITAMENTE SRS. NOSFERATU E ICE MAN
    JÓIA !!!!
    MAS MESMO ASSIM GOSTARIA DE SABER O QUE AQUELE ARQUIVO CONTROLA...???
    MUITO OBRIGADO PELA AJUDA, FICO MAIS GRATO AINDA SE PUDEREM ME RESPONDER O QUE É AQUELE ARQUIVO ?
