    robsonzornitta
    ai achei vários erros no teu named.conf, ai vai um named.conf preparadu pra vc amigo:
    // secret must be the same as in /etc/rndc.conf
    key key_rndc {
    algorithm hmac-md5;
    secret "oriCelUSbPMypSjImBsiTHMauOumRPMkdBjoxVINAx0vxJZNRKGWzFCKibad";
    controls {
    inet 127.0.0.1 port 953
    allow { 127.0.0.1; } keys { key_rndc; };
    options {
    directory "/var/named/";
    pid-file "/var/run/named/named.pid"; // Put pid file in working dir
    auth-nxdomain yes;
    zone "." {
    type hint;
    file "named.ca";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    // workaround stupid stuff... (OE: Wed 17 Sep 2003)
    zone "ac" { type delegation-only; };
    zone "cc" { type delegation-only; };
    zone "com" { type delegation-only; };
    zone "cx" { type delegation-only; };
    zone "museum" { type delegation-only; };
    zone "net" { type delegation-only; };
    zone "nu" { type delegation-only; };
    zone "ph" { type delegation-only; };
    zone "sh" { type delegation-only; };
    zone "tm" { type delegation-only; };
    zone "ws" { type delegation-only; };
    zone "synapse.com.br" {
    type master;
    file "synapse.com.br.hosts";
    allow-update { key key_rndc; };
    zone "0.168.192.in-addr.arpa" {
    type master;
    file "synapse.com.br.rev";
    e o teu resolv.con deve ficar assim:
    seach synapse.com.br
    nameserver 192.168.0.254
    nameserver 200.165.132.148
    nameserver 200.165.132.155
    soh issu qualquer coisa como jah disse antes manda todos os aqruivos pra mim corrigiih se estiver algum erro nos achamos!!!!
    :good:
  2. Citação Postado originalmente por robsonzornitta
    key key_rndc {
    algorithm hmac-md5;
    controls {
    options {
    auth-nxdomain yes;
    zone "." {
    type hint;
    file "named.ca";
    type master;
    file "named.local";
    type master;
    type master;
    :good:
    Pô cara valeu mesmo vou colocar ele lá pra ver o que dá
  3. Citação Postado originalmente por robsonzornitta
    key key_rndc {
    algorithm hmac-md5;
    controls {
    options {
    auth-nxdomain yes;
    zone "." {
    type hint;
    file "named.ca";
    type master;
    file "named.local";
    type master;
    type master;
    :good:
    Eu fiz lá ele restartou legal mas ainga não encontra www.synapse.com.br
    só pinga para lablinux.synapse.com.br
    eu dei um named -g e deu isso:
    [root@lablinux sysop]# /usr/sbin/named -g
    May 16 09:44:12.306 starting BIND 9.2.3 -g
    May 16 09:44:12.306 using 1 CPU
    May 16 09:44:12.308 loading configuration from '/etc/named.conf'
    May 16 09:44:12.328 no IPv6 interfaces found
    May 16 09:44:12.328 listening on IPv4 interface lo, 127.0.0.1#53
    May 16 09:44:12.329 binding TCP socket: address in use
    May 16 09:44:12.329 listening on IPv4 interface eth0, 192.168.0.254#53
    May 16 09:44:12.329 listening on IPv4 interface eth1, 192.168.0.100#53
    May 16 09:44:12.349 dns_master_load: named.ca:83: isc_lex_gettoken() failed: unexpected end of i nput
    May 16 09:44:12.349 dns_master_load: named.ca:83: unexpected end of input
    May 16 09:44:12.349 could not configure root hints from 'named.ca': unexpected end of input
    May 16 09:44:12.350 loading configuration: unexpected end of input
    May 16 09:44:12.350 exiting (due to fatal error)
  4. #69
    fpmazzi
    Posta ae o arquivos so synapse.com.br.hosts pra darmos uma olhada .. talvez o problema estaja la, ja ke o www nao resolve, o lablinux.synapse.com.br resolve, pois o mesmo esta no /etc/hosts, agora precisamos dar uma olhada no seu synapse.com.br.hosts...
    qualquer coisa entra em contato .. blz ...
    :good:
  5. Citação Postado originalmente por fpmazzi
    :good:
    tá assim:
    $ttl 38400
    synapse.com.br. IN SOA lablinux.synapse.com.br. root.lablinux.synapse.com.br. (
    1051034896
    10800
    36000
    604800
    38400 )
    synapse.com.br. IN A 192.168.0.254
    synapse.com.br. IN NS lablinux.synapse.com.br.
    synapse.com.br. IN MX 5 lablinux.synapse.com.br.
    www A 192.168.0.254
  1. problema ao iniciar o guardian
    Por daniell no fórum Servidores de Rede
    Respostas: 13
    Último Post: 22-12-2005, 20:40
  2. Problema ao Iniciar Modo Grafico
    Por marcosgteixeira no fórum Servidores de Rede
    Último Post: 21-03-2005, 14:52
  3. Problemas ao iniciar o linux
    Por Wronieri no fórum Servidores de Rede
    Último Post: 21-07-2004, 21:35
  4. Problema ao iniciar o squid!!!
    Por bestwest no fórum Servidores de Rede
    Último Post: 29-02-2004, 11:35
  5. Problemas ao iniciar servidor X
    Por Sirius no fórum Servidores de Rede
    Último Post: 30-10-2003, 09:47
