    mstr_dos_magos
    Super_Diaulas,
    valeu meu nobre, fico aguardando um contato seu.
  2. #12
    Super_Diaulas
    O Q DIZ OS LOGS?
  3. #13
    mstr_dos_magos
    Não achei os arquivos de log do ltsp, andei olhando os logs do sistema principal, encontrei algo do tipo:
    root@server:/opt/ltsp/i386# tail /var/log/syslog
    Jun 28 01:42:16 server rpc.mountd: Caught signal 15, un-registering and exiting.
    Jun 28 01:42:17 server kernel: nfsd: last server has exited
    Jun 28 01:42:17 server kernel: nfsd: unexporting all filesystems
    Jun 28 04:44:07 server in.tftpd[20029]: tftp: client does not accept options
    Jun 28 04:45:40 server in.tftpd[20066]: tftp: client does not accept options
    Jun 28 04:47:24 server in.tftpd[20122]: tftp: client does not accept options
    Jun 28 04:49:26 server in.tftpd[20167]: tftp: client does not accept options
    Jun 28 04:50:39 server in.tftpd[20197]: tftp: client does not accept options
    Jun 28 04:53:05 server in.tftpd[20241]: tftp: client does not accept options
    Jun 28 04:55:17 server in.tftpd[20281]: tftp: client does not accept options
    no /var/log/messenger
    root@server:/opt/ltsp/i386# tail /var/log/messages
    Jun 28 01:55:14 server dhcpd: DHCPDISCOVER from 00:04:3c:10:4c:44 via eth1
    Jun 28 01:55:14 server dhcpd: DHCPOFFER on 192.168.2.5 to 00:04:3c:10:4c:44 via eth1
    Jun 28 01:55:17 server dhcpd: DHCPREQUEST for 192.168.2.5 (192.168.10.100) from 00:04:3c:10:4c:44 via eth1
    Jun 28 01:55:17 server dhcpd: DHCPACK on 192.168.2.5 to 00:04:3c:10:4c:44 via eth1
    Jun 28 01:55:20 server dhcpd: DHCPDISCOVER from 00:04:3c:10:4c:44 via eth1
    Jun 28 01:55:20 server dhcpd: DHCPOFFER on 192.168.2.5 to 00:04:3c:10:4c:44 via eth1
    Jun 28 01:55:22 server dhcpd: DHCPREQUEST for 192.168.2.5 (192.168.10.100) from 00:04:3c:10:4c:44 via eth1
    Jun 28 01:55:22 server dhcpd: DHCPACK on 192.168.2.5 to 00:04:3c:10:4c:44 via eth1
    Jun 28 01:55:23 server rpc.mountd: authenticated mount request from ws002:688 for /opt/ltsp/i386 (/opt/ltsp/i386)
    Jun 28 01:56:46 server rpc.mountd: export request from 192.168.10.100
    e no comando dmesg, isso: "ACEESO TS é uma msg personalizada"
    ACESSO TS IN=eth1 OUT=ppp0 SRC=192.168.0.30 DST=200.164.26.175 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=5441 DF PROTO=TCP SPT=1079 DPT=3389 WINDOW=65535 RES=0x00 SYN URGP=0
    ACESSO TS IN=eth1 OUT=ppp0 SRC=192.168.0.30 DST=200.164.26.175 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=5442 DF PROTO=TCP SPT=1079 DPT=3389 WINDOW=65535 RES=0x00 SYN URGP=0
    ISO 9660 Extensions: Microsoft Joliet Level 3
    ISO 9660 Extensions: RRIP_1991A
  4. #14
    mstr_dos_magos
    Tem um outro detalhe nisso tudo,
    eu resolvi rastrear o boot do client com o iptraf só pra saber se ele ao menos iria tentar chamar o server win2k3, nada ! ele sequer chamou o IP do servidor.
    Atualizei ontem mesmo o ltsp para a versão 4.1, e percebi que tem um glic que necessita ser instalada para o rdesktop, pois bem, a instalei, e ao chamá-lo pela linha de comando o, mesmo respondeu perfeitamente exibindo o help, agora tenho certeza de ter o rdesktop funcionando perfeitamente.
    Retirei o firewall do windows só por segurança
  5. #15
    Super_Diaulas
    procura nos logs do xorg
    se eu não me engano cada micro tem seu próprio arquivo de log
  1. LTSP no Slack 10.1 problemas infinitos?
    Por georgemattos no fórum Servidores de Rede
    Último Post: 08-07-2005, 11:09
  2. Problemas com o LTSP 4.0 no Slack 10.1
    Último Post: 10-06-2005, 22:15
  3. DVD e VCD no slack 10
    Por c0dek no fórum Servidores de Rede
    Último Post: 29-07-2004, 11:29
  4. VMWARE no SLACK 10.
    Por luccosta no fórum Servidores de Rede
    Último Post: 23-07-2004, 08:12
  5. Salvando configurações no slack 10....
    Por flipeexpl no fórum Servidores de Rede
    Último Post: 03-07-2004, 11:07
