    ja tentei na eth1 e nao deu certo
  2. vc colocou sua regra de masquerade antes dessa regra?
  3. #13
    sim coloquei
  4. Tá usando a porta 3128 mesmo pro squid?
    Postas suas regras de firewall e seu squid.conf...
  5. #15
    nao to usando firewall, meu squid ta assim:
    http_port 192.168.1.3:3128
    no_cache deny QUERY
    cache_mem 32 MB
    cache_swap_low 90
    cache_swap_high 95
    maximum_object_size 16000 KB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 18 KB
    cache_dir ufs /usr/local/squid/var/cache 1000 16 256
    cache_access_log /usr/local/squid/var/logs/access.log
    cache_log /usr/local/squid/var/logs/cache.log
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    auth_param basic casesensitive off
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 113 # ident
    acl CONNECT method CONNECT
    acl sitesnegados url_regex "/usr/local/squid/etc/conf/negados"
    acl sitespermitidos url_regex "/usr/local/squid/etc/conf/permitidos"
    acl permissao ident "/usr/local/squid/etc/conf/usuarios"
    acl cottolengo src 192.168.1.0/24
    http_access allow sitespermitidos
    http_access deny sitesnegados
    http_access deny !permissao
    http_access allow permissao
    http_access allow cottolengo
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    httpd_accel_pot 80
    httpd_accel_host virtual
    httpd_accel_with_proxy on
    httpd accel users host header on
    esse ai eh o meu squid.conf se puderem me ajudar
  1. Bridge + Iptables + Squid Remoto
    Por Machado no fórum Servidores de Rede
    Último Post: 26-08-2003, 09:04
  2. Limitaçao de banda por interface, iptables.
    Por vandemberg no fórum Servidores de Rede
    Último Post: 29-07-2002, 14:12
  3. IPTABLES (problemas c DHCP)
    Por redrum_pp no fórum Servidores de Rede
    Último Post: 16-07-2002, 08:17
  4. IpTables e CheckPoint VPN
    Por chedid no fórum Servidores de Rede
    Último Post: 26-06-2002, 21:10
  5. problemas iptables
    Por cyberrato no fórum Servidores de Rede
    Último Post: 07-06-2002, 10:47
