    Leo_Tech
    Segue abaixo meu rc.firewall
    #!/bin/bash
    # Flush
    iptables -F
    iptables -X
    iptables -t nat -F
    iptables -t nat -X
    # Variaveis do firewall
    nosso_ip=. XXX.XXX.XXX.XXX
    ext_ip=`ifconfig eth1 | grep inet | awk '{ print $3 }'`
    int_ip=`cat /root/tab_ip | grep VNC | awk '{ print $2 }'`
    REDEMASQ=192.168.X.X/24
    iptables -A INPUT -s $REDEMASQ -p tcp --dport 3128 -j ACCEPT
    iptables -A INPUT -s $nosso_ip -p tcp --dport 5900 -j ACCEPT
    # Politica de acesso
    iptables -P INPUT DROP
    iptables -P FORWARD DROP
    iptables -P OUTPUT ACCEPT
    # Habilitando a protecoes contra "TCP SYN Cookie"
    echo 1 > /proc/sys/net/ipv4/tcp_syncookies
    # Ocultando a rota de origem dos pacotes (evita spoof)
    for f in /proc/sys/net/ipv4/conf/*/accept_source_route; do
    echo 0 > $f
    done
    # Evita ataques de spoof (na rede interna)
    # Em casos de roteamento esta linha devera ser desativada
    for f in /proc/sys/net/ipv4/conf/*/rp_filter; do
    echo 1 > $f
    done
    # Permissoes de acesso ao firewall
    iptables -A INPUT -i lo -j ACCEPT
    iptables -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
    # Trocando o intervalo de portas locais
    PORT_INI=61000
    PORT_FIM=65095
    echo $PORT_INI $PORT_FIM > /proc/sys/net/ipv4/ip_local_port_range
    iptables -A FORWARD -s $nosso_ip -d $int_ip -j ACCEPT
    # Criando perfil de acesso administrativo (apenas por ssh)
    iptables -N ADMIN
    iptables -A ADMIN -i eth1 -p tcp --dport 22 --syn -j LOG --log-level info --log-prefix "--->ACESSO SSH EXTERNO: "
    iptables -A ADMIN -i eth1 -p tcp --dport 5900 --syn -j LOG --log-level info --log-prefix "--->ACESSO VNC: "
    iptables -A ADMIN -i eth0 -p tcp --dport 22 --syn -j ACCEPT
    iptables -A ADMIN -i eth1 -p tcp --dport 22 --syn -j ACCEPT
    iptables -A ADMIN -i eth1 -p tcp --dport 5900 --syn -j ACCEPT
    # Aplicando a permissao de acesso ssh a CONFIAVEL1 e CONFIAVEL2
    iptables -A INPUT -i eth0 -s $REDEMASQ -j ADMIN
    iptables -A INPUT -i eth1 -s $nosso_ip -j ADMIN
    # Para tratar as quedas dos roteadores ADSL
    GW=`ifconfig eth1 | grep inet | awk '{ print $3 }'`
    iptables -A INPUT -i eth1 -s $GW -p tcp ! --syn -j ACCEPT
    # Compartilhando o acesso a internet
    iptables -t nat -A PREROUTING -s $REDEMASQ -i eth0 -p tcp -m tcp --dport 80 -j DNAT --to-destination 192.168.X.X:3128
    iptables -t nat -A POSTROUTING -o eth1 -j MASQUERADE
    iptables -t nat -A POSTROUTING -s $REDEMASQ -o eth1 -j MASQUERADE
    iptables -t mangle -A PREROUTING -p tcp -m tcp --dport 22 -j TOS --set-tos 0x10
    iptables -t mangle -A PREROUTING -s $REDEMASQ -p tcp -m tcp --sport 80 -j TOS --set-tos 0x08
    iptables -t nat -A PREROUTING -p tcp -s $nosso_ip -d $ext_ip --dport 5900 -j DNAT --to $int_ip
    iptables -t nat -A POSTROUTING -p tcp -d $nosso_ip -s $int_ip --sport 5900 -j SNAT --to $ext_ip
    # Permitindo requisicoes de DNS
    #iptables -A FORWARD -o eth1 -s $REDEMASQ -p tcp --dport 53 -j ACCEPT
    iptables -A FORWARD -o eth1 -s $REDEMASQ -p udp --dport 53 -j ACCEPT
    # Bloquear pacotes com estado "novo/invalido" que saiam pela eth1
    # Permitir pacotes com estado "estabelecido/reincidente"
    iptables -A FORWARD -o eth0 -m state --state NEW,INVALID -j DROP
    iptables -A FORWARD -o eth0 -m state --state ESTABLISHED,RELATED -j ACCEPT
    # Permitindo qualquer solicitacao de Internet que parta da rede 192.168.1.0/24
    iptables -A FORWARD -i eth0 -s $REDEMASQ -j ACCEPT
    # Bloqueia qualquer pacote (forward) que nao liberado por regras anteriores
    iptables -A FORWARD -j DROP
    # Bloqueando e logando sinais de ping ao firewall
    #iptables -N LPI
    #iptables -A LPI -m limit --limit 5/hour --limit-burst 3 -p icmp --icmp-type echo-request -j LOG --log-level info --log-prefix "--->TENTATIVA DE PING: "
    #iptables -A LPI -j REJECT --reject-with icmp-port-unreachable
    #iptables -A INPUT -p icmp --icmp-type echo-request -j LPI
    iptables -A INPUT -p icmp -j DROP
    # Bloqueia qualquer pacote (input) que nao liberado por regras anteriores
    iptables -A INPUT -j DROP
  2. #12
    X-LOGAN
    Estou usando o seguinte firewall.
    #!/bin/bash
    # SCRIPT FIREWALL *
    # CRIADO POR FABIO LIMA DE OLIVIERA *
    # DATA: 28/06/2005 *
    iptables -F #
    modprobe iptable_nat #
    #Ativando o repasse dos pacotes
    iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE #
    #Protecao contra Syn-Floods iptables -A INPUT -p tcp --syn -m limit --limit 1/s -j ACCEPT
    #Protecao contra scanners ocultos
    iptables -A INPUT -p tcp --tcp-flags SYN,ACK,FIN,RST RST -m limit --limit 1/s -j ACCEPT
    #Ping da Morte iptables -A INPUT -p icmp --icmp-type echo-request -m limit --limit 1/s -j ACCEPT #
    iptables -A FORWARD -p tcp --dport 110 -j ACCEPT
    iptables -A FORWARD -p tcp --dport 25 -j ACCEPT
    iptables -A OUTPUT -o lo -j ACCEPT
    iptables -A FORWARD -o eth0 -s 100.100.100.0/24 -d 0/0 -j ACCEPT
  3. #13
    X-LOGAN
    O unico problema que estou tendo com ele é quanto ao envie ao recebimento de arquivos pelo messenger, mas ainda não tive tempo de testar isso, tente usar ele e ai vc pode incrementar regras, essas que estão postadas são um perfil que se encaixa nesta empresa!!!
  4. #14
    X-LOGAN
  5. #15
    Leo_Tech
    mas no meu rc.firewall...
    como é como se ele nao inicializasse...
    qual a melhor forma de eu resolver isso...???
    uso o Red Hat 9.0
  1. RC Firewall da projectfiles.com
    Por jadirorza no fórum Servidores de Rede
    Último Post: 04-04-2006, 12:23
  2. Erro "bad argument ppp0" ao startar o rc.firewall
    Por PRISCILASCHU no fórum Servidores de Rede
    Último Post: 02-03-2006, 09:20
  3. Não consigo configurar firewall
    Por buosinet no fórum Servidores de Rede
    Respostas: 5
    Último Post: 29-11-2004, 19:09
  4. firewall x webmail ou firewall x php?
    Por eclaudin no fórum Segurança
    Último Post: 23-08-2002, 04:14
  5. Não consigo configurar firewall
    Último Post: 28-03-2002, 21:44
