    ocire
    poste seu dns pois acho q tem algo errado ... :good:
  2. #7
    perdiga
    qual arquivo você, precisa, desculpe mas não sei muita coisa ainda, mas deve ser o named.conf isso
  3. #8
    ocire
    tambem e nos q vc fez no /var/named .. ok
  4. #9
    perdiga
    named.conf esse é o arquivo cara
    options {
    directory "/var/cache/bind";
    version "fuck off";
    // If there is a firewall between you and nameservers you want
    // to talk to, you might need to uncomment the query-source
    // directive below. Previous versions of BIND always asked
    // questions using port 53, but BIND 8.1 and later use an unprivileged
    // port by default.
    query-source address * port 53;
    // If your ISP provided one or more IP addresses for stable
    // nameservers, you probably want to use them as forwarders.
    // Uncomment the following block, and insert the addresses replacing
    // the all-0's placeholder.
    // forwarders {
    // 0.0.0.0;
    auth-nxdomain no; # conform to RFC1035
    // prime the server with knowledge of the root servers
    zone "." {
    type hint;
    file "/etc/bind/db.root";
    // be authoritative for the localhost forward and reverse zones, and for
    // broadcast zones as per RFC 1912
    zone "localhost" {
    type master;
    file "/etc/bind/db.local";
    zone "127.in-addr.arpa" {
    type master;
    file "/etc/bind/db.127";
    zone "0.in-addr.arpa" {
    type master;
    file "/etc/bind/db.0";
    zone "255.in-addr.arpa" {
    type master;
    file "/etc/bind/db.255";
    // add entries for other zones below here
    zone "quantumrs.com.br" {
    notify no;
    allow-transfer { 200.203.12.214; 192.168.100.254; 10.0.0.139; };
    type master;
    file "/etc/bind/db.quantumrs.com.br";
    zone "ditutto.com.br" {
    notify no;
    type master;
    file "/etc/bind/db.ditutto.com.br";
    zone "neukamp.com.br" {
    notify no;
    type master;
    file "/etc/bind/db.neukamp.com.br";
  5. #10
    ocire
    vc não setou nada no /var/named ... acho q esta faltando coisa ...
    pelo q vi não tem nenhuma entrada reversa ... de uma olhada aqui no site tem uns tutor de dns a compare com o seu ... valeu :good:
  1. Dúvida Amavis e Clamav???
    Por c4f0f0 no fórum Servidores de Rede
    Último Post: 20-03-2004, 21:39
  2. ERRO Clamav - Me Ajudem
    Último Post: 01-03-2004, 08:54
  3. sendmail + clamav
    Por mcclaudio no fórum Servidores de Rede
    Último Post: 26-02-2004, 14:50
  4. Compilar ClamAV
    Por doliveira no fórum Linguagens de Programação
    Último Post: 20-02-2004, 13:34
  5. Postfix + Amavis0.3.12 + Clamav
    Por paradadura no fórum Servidores de Rede
    Último Post: 14-02-2004, 11:39
