Estou usando o Squid e o Sarg para monitoriamento de acessos. Quando desvio a porta 80 para 3128 não funciona.
A configuração do squid esta ai abaixo.
http_port 3128
hierarchy_stoplist cgi-bin ?
no_cache deny QUERY
hosts_file /etc/hosts
refresh_pattern ftp: 1440 20% 10080
refresh_pattern gopher: 1440 0% 1440
refresh_pattern 0 20% 4320
#------------- Autenticar ----------------------
#para criar um novo usuario digite "usuarios"
auth_param basic program /usr/lib/squid/ncsa_auth /etc/squid/controle/senhas.txt
auth_param basic children 5
auth_param basic realm :::: Favor consultar o suporte tecnico para fazer um novo cadastro :::: Digite o seu login :
#------------- Minhas ACLs --------------------
acl rede_interna src 192.168.8.0/24
acl auto proxy_auth "/etc/squid/controle/usuarios_auto.txt"
acl nauto proxy_auth "/etc/squid/controle/usuarios_nauto.txt"
acl autenticar proxy_auth REQUIRED rede_interna
#acl blockedsites url_regex -i "/etc/squid/controle/bloqueados.txt"
#acl unblockedsites url_regex -i "/etc/squid/controle/liberados.txt"
acl bloqueados url_regex -i "/etc/squid/controle/bloqueados.txt"
acl liberados url_regex -i "/etc/squid/controle/liberados.txt"
#acl bloq_manha time SMTWHFA 00:00-07:29
#acl bloq_noite time SMTWHFA 20:00-23:59
acl atu_antivirus time SMTWHFA 11:55-12:05
acl arquivos urlpath_regex .mp3$ .mpeg$ .mpg$ .mov$ .avi$ .src$ .pif$
acl SSL_ports port 443 563
# https, snews
acl SSL_ports port 873# rsync
acl Safe_ports port 80
# http
acl Safe_ports port 21
# ftp
acl Safe_ports port 443 563
# https, snews
acl Safe_ports port 70
# gopher
acl Safe_ports port 210
# wais
acl Safe_ports port 1025-65535
# unregistered ports
acl Safe_ports port 280
# http-mgmt
acl Safe_ports port 488
# gss-http
acl Safe_ports port 591
# filemaker
acl Safe_ports port 777
# multiling http
acl Safe_ports port 631
# cups
acl Safe_ports port 873
# rsync
acl Safe_ports port 901
# SWAT
acl purge method PURGE
acl CONNECT method CONNECT
#--------- Regras Padraum -----------------------
http_acess deny manager
http_access deny purge
http_access deny !Safe_ports
http_access allow localhost
#--------- Minhas Regras ------------------------
http_access allow atu_antivirus
http_access allow auto !nauto
http_access deny arquivos
#http_access deny bloq_manha
#http_access deny bloq_noite
#http_access deny bloqueados !liberados
#http_access allow autenticar
#http_access deny all
#-------- Mensagem de erro ---------------------
#deny_info ERR_HORARIO bloqueados
cache_mgr ti@microtest.ind.br
http_reply_access allow all
icp_access allow all
coredump_dir /var/spool/squid
httpd_accel_host virtual
httpd_accel_port 80
httpd_accel_with_proxy on
