    michigan
    Padrão kde.
    Alo..
    Tenho este arquivo...
    "kdebase-3.4.1.tar.bz2"
    Como faço para atualizar o meu sistema KDE., quales passos tenho que fazer.???
    O meu sistema KDE e 3.2.3 rolando no conectiva 10.1
    michigan
    Padrão ...
    thanks brother[size=24px][/size]
    michigan
    Padrão kde.
    Ja desempakei o arquivo, ta num diretorio dentro do /home.
    Cuando do o "./configure" dentro do mesmo diretorio onde ta o arquivo me sai isto:
    [[email protected] kdebase-3.4.1]# ./configure
    checking build system type... i686-pc-linux-gnuoldld
    checking host system type... i686-pc-linux-gnuoldld
    checking target system type... i686-pc-linux-gnuoldld
    checking for a BSD-compatible install... /usr/bin/install -c
    checking for -p flag to install... yes
    checking whether build environment is sane... yes
    checking for gawk... gawk
    checking whether make sets $(MAKE)... no
    checking for kde-config... /usr/lib/kde3/bin/kde-config
    kde-config: Opción desconocida '--libsuffix'.
    kde-config: Use --help para obtener una lista de las opciones disponibles en la línea de comandos.
    checking where to install... /usr/lib/kde3 (as returned by kde-config)
    checking for style of include used by make... none
    checking for gcc... no
    checking for cc... no
    checking for cl... no
    configure: error: no acceptable C compiler found in $PATH
    See `config.log' for more details.
    a pergunta minha e... que eu vejo no "CONFIG.LOG"???
    michigan
    Padrão kde.
    ESTE E O DETALHE DO "CONFIG.LOG"
    This file contains any messages produced by compilers while
    running configure, to aid debugging if configure makes a mistake.
    It was created by configure, which was
    generated by GNU Autoconf 2.59. Invocation command line was
    $ ./configure
    ## Platform. ##
    hostname = ozzy
    uname -m = i686
    uname -r = 2.6.5-63077cl
    uname -s = Linux
    uname -v = #1 Thu Jun 17 21:29:07 BRT 2004
    /usr/bin/uname -p = unknown
    /bin/uname -X = unknown
    /bin/arch = i686
    /usr/bin/arch -k = unknown
    /usr/convex/getsysinfo = unknown
    hostinfo = unknown
    /bin/machine = unknown
    /usr/bin/oslevel = unknown
    /bin/universe = unknown
    PATH: /usr/lib/kde3/bin
    PATH: /sbin
    PATH: /usr/sbin
    PATH: /bin
    PATH: /usr/bin
    PATH: /usr/X11R6/bin
    PATH: /usr/local/bin
    PATH: /usr/bin/X11
    PATH: /usr/games
    PATH: /usr/lib/java2/bin
    PATH: /usr/lib/java2/jre/bin
    PATH: /usr/lib/qt3/bin
    ## Core tests. ##
    configure:1586: checking build system type
    configure:1604: result: i686-pc-linux-gnuoldld
    configure:1612: checking host system type
    configure:1626: result: i686-pc-linux-gnuoldld
    configure:1634: checking target system type
    configure:1648: result: i686-pc-linux-gnuoldld
    configure:1695: checking for a BSD-compatible install
    configure:1750: result: /usr/bin/install -c
    configure:1765: checking for -p flag to install
    configure:1778: result: yes
    configure:1789: checking whether build environment is sane
    configure:1832: result: yes
    configure:1884: checking for gawk
    configure:1900: found /bin/gawk
    configure:1910: result: gawk
    configure:1920: checking whether make sets $(MAKE)
    configure:1944: result: no
    configure:2126: checking for kde-config
    configure:2188: result: /usr/lib/kde3/bin/kde-config
    configure:2284: checking where to install
    configure:2288: result: /usr/lib/kde3 (as returned by kde-config)
    configure:2343: checking for style of include used by make
    configure:2371: result: none
    configure:2519: checking for gcc
    configure:2548: result: no
    configure:2599: checking for cc
    configure:2628: result: no
    configure:2641: checking for cc
    configure:2687: result: no
    configure:2740: checking for cl
    configure:2769: result: no
    configure:2783: error: no acceptable C compiler found in $PATH
    ## Cache variables. ##
    ac_cv_build=i686-pc-linux-gnuoldld
    ac_cv_build_alias=i686-pc-linux-gnuoldld
    ac_cv_env_CC_set=
    ac_cv_env_CC_value=
    ac_cv_env_CFLAGS_set=
    ac_cv_env_CFLAGS_value=
    ac_cv_env_CPPFLAGS_set=
    ac_cv_env_CPPFLAGS_value=
    ac_cv_env_CPP_set=
    ac_cv_env_CPP_value=
    ac_cv_env_CXXCPP_set=
    ac_cv_env_CXXCPP_value=
    ac_cv_env_CXXFLAGS_set=
    ac_cv_env_CXXFLAGS_value=
    ac_cv_env_CXX_set=
    ac_cv_env_CXX_value=
    ac_cv_env_F77_set=
    ac_cv_env_F77_value=
    ac_cv_env_FFLAGS_set=
    ac_cv_env_FFLAGS_value=
    ac_cv_env_LDFLAGS_set=
    ac_cv_env_LDFLAGS_value=
    ac_cv_env_build_alias_set=
    ac_cv_env_build_alias_value=
    ac_cv_env_host_alias_set=
    ac_cv_env_host_alias_value=
    ac_cv_env_target_alias_set=
    ac_cv_env_target_alias_value=
    ac_cv_host=i686-pc-linux-gnuoldld
    ac_cv_host_alias=i686-pc-linux-gnuoldld
    ac_cv_path_install='/usr/bin/install -c'
    ac_cv_prog_AWK=gawk
    ac_cv_prog_make_make_set=no
    ac_cv_target=i686-pc-linux-gnuoldld
    ac_cv_target_alias=i686-pc-linux-gnuoldld
    kde_cv_path=/usr/lib/kde3/bin/kde-config
    kde_cv_path_kde_config=/usr/lib/kde3/bin/kde-config
    ## Output variables. ##
    ACLOCAL='${SHELL} /home/ozzy/install/kdebase-3.4.1/admin/missing --run aclocal-1.9'
    AMDEPBACKSLASH='\'
    AMDEP_FALSE='#'
    AMDEP_TRUE=''
    AMTAR='${SHELL} /home/ozzy/install/kdebase-3.4.1/admin/missing --run tar'
    AR=''
    ARTSCCONFIG=''
    AUTOCONF='${SHELL} /home/ozzy/install/kdebase-3.4.1/admin/missing --run autoconf'
    AUTODIRS=''
    AUTOHEADER='${SHELL} /home/ozzy/install/kdebase-3.4.1/admin/missing --run autoheader'
    AUTOMAKE='${SHELL} /home/ozzy/install/kdebase-3.4.1/admin/missing --run automake-1.9'
    AWK='gawk'
    CC=''
    CCDEPMODE=''
    CFLAGS=' '
    COMPILE_GL_INFO_FALSE=''
    COMPILE_GL_INFO_TRUE=''
    CONF_FILES=' $(top_srcdir)/./admin/configure.in.min $(top_srcdir)/configure.in.in $(top_srcdir)/./kappfinder/configure.in.in $(top_srcdir)/./kcontrol/access/configure.in.in $(top_srcdir)/./kcontrol/accessibility/configure.in.in $(top_srcdir)/./kcontrol/crypto/configure.in.in $(top_srcdir)/./kcontrol/energy/configure.in.in $(top_srcdir)/./kcontrol/fonts/configure.in.in $(top_srcdir)/./kcontrol/info/configure.in.bot $(top_srcdir)/./kcontrol/info/configure.in.in $(top_srcdir)/./kcontrol/input/configure.in.bot $(top_srcdir)/./kcontrol/input/configure.in.in $(top_srcdir)/./kcontrol/joystick/configure.in.in $(top_srcdir)/./kcontrol/kfontinst/configure.in.bot $(top_srcdir)/./kcontrol/kfontinst/configure.in.in $(top_srcdir)/./kcontrol/nics/configure.in.in $(top_srcdir)/./kcontrol/randr/configure.in.in $(top_srcdir)/./kcontrol/smartcard/configure.in.in $(top_srcdir)/./kcontrol/usbview/configure.in.in $(top_srcdir)/./kcontrol/view1394/configure.in.in $(top_srcdir)/./kdeprint/configure.in.in $(top_srcdir)/./kdeprint/kprinter/configure.in.in $(top_srcdir)/./kdesktop/configure.in.in $(top_srcdir)/./kdesktop/lock/configure.in.in $(top_srcdir)/./kdesu/configure.in.in $(top_srcdir)/./kdm/configure.in.in $(top_srcdir)/./khotkeys/configure.in.in $(top_srcdir)/./kicker/applets/naughty/configure.in.in $(top_srcdir)/./kicker/extensions/kasbar/configure.in.in $(top_srcdir)/./kioslave/configure.in.bot $(top_srcdir)/./kioslave/configure.in.in $(top_srcdir)/./kioslave/filter/configure.in.in $(top_srcdir)/./kioslave/fish/configure.in.in $(top_srcdir)/./kioslave/ldap/configure.in.in $(top_srcdir)/./kioslave/media/configure.in.in $(top_srcdir)/./kioslave/smb/configure.in.bot $(top_srcdir)/./kioslave/smb/configure.in.in $(top_srcdir)/./kioslave/thumbnail/configure.in.in $(top_srcdir)/./konqueror/preloader/configure.in.in $(top_srcdir)/./konsole/configure.in.in $(top_srcdir)/./ksmserver/configure.in.in $(top_srcdir)/./ksplashml/themeengine/simple/configure.in.in $(top_srcdir)/./ksysguard/configure.in.in $(top_srcdir)/./kwin/kompmgr/configure.in.in $(top_srcdir)/./kxkb/configure.in.in $(top_srcdir)/configure.in.bot'
    CPP=''
    CPPFLAGS=''
    CXX=''
    CXXCPP=''
    CXXDEPMODE=''
    CXXFLAGS=''
    CYGPATH_W='echo'
    DBUSQT_INCS=''
    DBUSQT_LIBS=''
    DBUS_INCS=''
    DBUS_LIBS=''
    DCOPIDL2CPP=''
    DCOPIDL=''
    DCOPIDLNG=''
    DCOP_DEPENDENCIES=''
    DEFS=''
    DEPDIR='.deps'
    DOXYGEN=''
    DOXYGEN_PROJECT_NAME=''
    DOXYGEN_PROJECT_NUMBER=''
    DPMSINC=''
    DPMSLIB=''
    ECHO='echo'
    ECHO_C=''
    ECHO_N='-n'
    ECHO_T=''
    EGREP=''
    ENABLE_PERMISSIVE_FLAG=''
    EXEEXT=''
    EXR_FLAGS=''
    F77=''
    FFLAGS=''
    FRAMEWORK_COREAUDIO=''
    GLINC=''
    GLLIB=''
    GMSGFMT=''
    HALBACKEND=''
    HAL_INCS=''
    HAL_LIBS=''
    HAVE_GCC_VISIBILITY=''
    INSTALL_DATA='${INSTALL} -m 644'
    INSTALL_PROGRAM='${INSTALL} $(INSTALL_STRIP_FLAG)'
    INSTALL_SCRIPT='${INSTALL}'
    INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s'
    JAR=''
    JAVAC=''
    JAVAH=''
    JVMLIBS=''
    KCFG_DEPENDENCIES=''
    KCHECKPASS_PAM_SERVICE=''
    KCONFIG_COMPILER=''
    KDECONFIG='/usr/lib/kde3/bin/kde-config'
    KDE_BINDIR=''
    KDE_EXTRA_RPATH=''
    KDE_HAS_DOXYGEN=''
    KDE_HAVE_DOT=''
    KDE_INCLUDES=''
    KDE_LDFLAGS=''
    KDE_MT_LDFLAGS=''
    KDE_MT_LIBS=''
    KDE_NO_UNDEFINED=''
    KDE_PLUGIN=''
    KDE_RPATH=''
    KDE_USE_CLOSURE_FALSE=''
    KDE_USE_CLOSURE_TRUE=''
    KDE_USE_FINAL_FALSE=''
    KDE_USE_FINAL_TRUE=''
    KDE_USE_NMCHECK_FALSE=''
    KDE_USE_NMCHECK_TRUE=''
    KDE_XSL_STYLESHEET=''
    KDM_PAM_SERVICE=''
    KRB4_INCS=''
    KRB4_LIBS=''
    KRB4_RPATH=''
    KRB5_INCS=''
    KRB5_LIBS=''
    KRB5_RPATH=''
    KSCREENSAVER_PAM_SERVICE=''
    LDAP_INCS=''
    LDAP_LIBS=''
    LDAP_RPATH=''
    LDFLAGS=''
    LDFLAGS_AS_NEEDED=''
    LDFLAGS_NEW_DTAGS=''
    LIBALIB=''
    LIBART_CFLAGS=''
    LIBART_LIBS=''
    LIBART_RPATH=''
    LIBBZ2=''
    LIBCFG=''
    LIBCOMPAT=''
    LIBCRYPT=''
    LIBCURSES=''
    LIBDEVINFO=''
    LIBDL=''
    LIBFONTCONFIG_CFLAGS=''
    LIBFONTCONFIG_LIBS=''
    LIBFONTCONFIG_RPATH=''
    LIBFREETYPE_CFLAGS=''
    LIBFREETYPE_LIBS=''
    LIBFREETYPE_RPATH=''
    LIBGEN=''
    LIBHOSTS=''
    LIBJPEG=''
    LIBKSTAT=''
    LIBMALLOC=''
    LIBOBJS=''
    LIBODM=''
    LIBOSSAUDIO=''
    LIBPNG=''
    LIBPOSIX4=''
    LIBPTHREAD=''
    LIBRESOLV=''
    LIBRPC=''
    LIBS=''
    LIBSENSORS=''
    LIBSHADOW=''
    LIBSM=''
    LIBSOCKET=''
    LIBSSL=''
    LIBTOOL=''
    LIBUCB=''
    LIBUSBCONFIG=''
    LIBUTEMPTER=''
    LIBUTIL=''
    LIBXDMCP=''
    LIBXFT_LIB=''
    LIBZ=''
    LIB_EXR=''
    LIB_FONT_ENC=''
    LIB_KAB=''
    LIB_KABC=''
    LIB_KDECORE=''
    LIB_KDEPIM=''
    LIB_KDEPRINT=''
    LIB_KDEUI=''
    LIB_KDNSSD=''
    LIB_KFILE=''
    LIB_KFM=''
    LIB_KHTML=''
    LIB_KIMPROXY=''
    LIB_KIO=''
    LIB_KJS=''
    LIB_KNEWSTUFF=''
    LIB_KPARTS=''
    LIB_KSPELL=''
    LIB_KSYCOCA=''
    LIB_KUTILS=''
    LIB_KVM=''
    LIB_LIBS=''
    LIB_POLL=''
    LIB_QPE=''
    LIB_QT=''
    LIB_SMB=''
    LIB_TRU64_MACH=''
    LIB_X11=''
    LIB_XCURSOR=''
    LIB_XEXT=''
    LIB_XF86MISC=''
    LIB_XINERAMA=''
    LIB_XRANDR=''
    LIB_XRENDER=''
    LIB_XSS=''
    LINUXCDPOLLING=''
    LN_S=''
    LTLIBOBJS=''
    MAKEINFO='${SHELL} /home/ozzy/install/kdebase-3.4.1/admin/missing --run makeinfo'
    MAKEKDEWIDGETS=''
    MCOPIDL=''
    MD5SUM=''
    MD5SUM_CUT=''
    MEINPROC=''
    MOC=''
    MSGFMT=''
    NOOPT_CFLAGS=''
    NOOPT_CXXFLAGS=''
    OBJEXT=''
    PACKAGE='kdebase'
    PACKAGE_BUGREPORT=''
    PACKAGE_NAME=''
    PACKAGE_STRING=''
    PACKAGE_TARNAME=''
    PACKAGE_VERSION=''
    PAMLIBS=''
    PASSWDLIBS=''
    PATH_SEPARATOR=':'
    PERL=''
    PKG_CONFIG=''
    QTDOCDIR=''
    QTE_NORTTI=''
    QT_INCLUDES=''
    QT_LDFLAGS=''
    RANLIB=''
    RUN_KAPPFINDER=''
    SASL2_LIBS=''
    SETUIDFLAGS=''
    SET_MAKE='MAKE=make'
    SHELL='/bin/sh'
    SMBCLIENT_EXTRA_LIBS=''
    SSL_INCLUDES=''
    SSL_LDFLAGS=''
    STRIP=''
    TOPSUBDIRS=''
    UIC=''
    UIC_TR=''
    UNAME=''
    USB_CFLAGS=''
    USB_LIBS=''
    USER_INCLUDES=''
    USER_LDFLAGS=''
    USE_EXCEPTIONS=''
    USE_RTTI=''
    USE_THREADS=''
    VERSION='3.4.1'
    WOVERLOADED_VIRTUAL=''
    XGETTEXT=''
    XMLLINT=''
    XTESTLIB=''
    X_EXTRA_LIBS=''
    X_INCLUDES=''
    X_LDFLAGS=''
    X_PRE_LIBS=''
    X_RPATH=''
    ac_ct_AR=''
    ac_ct_CC=''
    ac_ct_CXX=''
    ac_ct_F77=''
    ac_ct_RANLIB=''
    ac_ct_STRIP=''
    all_includes=''
    all_libraries=''
    am__fastdepCC_FALSE=''
    am__fastdepCC_TRUE=''
    am__fastdepCXX_FALSE=''
    am__fastdepCXX_TRUE=''
    am__include='#'
    am__leading_dot='.'
    am__quote=''
    am__tar='${AMTAR} chof - "$$tardir"'
    am__untar='${AMTAR} xf -'
    applnk_SUBDIR_included_FALSE=''
    applnk_SUBDIR_included_TRUE=''
    bindir='${exec_prefix}/bin'
    build='i686-pc-linux-gnuoldld'
    build_alias=''
    build_cpu='i686'
    build_os='linux-gnuoldld'
    build_vendor='pc'
    datadir='${prefix}/share'
    doc_SUBDIR_included_FALSE=''
    doc_SUBDIR_included_TRUE=''
    drkonqi_SUBDIR_included_FALSE=''
    drkonqi_SUBDIR_included_TRUE=''
    exec_prefix='NONE'
    have_xcursor_FALSE=''
    have_xcursor_TRUE=''
    host='i686-pc-linux-gnuoldld'
    host_alias=''
    host_cpu='i686'
    host_os='linux-gnuoldld'
    host_vendor='pc'
    include_ARTS_FALSE=''
    include_ARTS_TRUE=''
    include_BZIP2_FALSE=''
    include_BZIP2_TRUE=''
    include_EXR_MODULES_FALSE=''
    include_EXR_MODULES_TRUE=''
    include_fontinst_tn_FALSE=''
    include_fontinst_tn_TRUE=''
    include_kcontrol_access_FALSE=''
    include_kcontrol_access_TRUE=''
    include_kcontrol_accessibility_FALSE=''
    include_kcontrol_accessibility_TRUE=''
    include_kcontrol_joystick_FALSE=''
    include_kcontrol_joystick_TRUE=''
    include_kcontrol_kfontinst_FALSE=''
    include_kcontrol_kfontinst_TRUE=''
    include_kcontrol_randr_FALSE=''
    include_kcontrol_randr_TRUE=''
    include_kcontrol_smartcard_FALSE=''
    include_kcontrol_smartcard_TRUE=''
    include_kcontrol_usbview_FALSE=''
    include_kcontrol_usbview_TRUE=''
    include_kcontrol_view1394_FALSE=''
    include_kcontrol_view1394_TRUE=''
    include_kioslave_ldap_FALSE=''
    include_kioslave_ldap_TRUE=''
    include_kioslave_smb_FALSE=''
    include_kioslave_smb_TRUE=''
    include_kompmgr_FALSE=''
    include_kompmgr_TRUE=''
    include_ksysguardd_FALSE=''
    include_ksysguardd_TRUE=''
    include_ksysguardd_freebsd_FALSE=''
    include_ksysguardd_freebsd_TRUE=''
    include_ksysguardd_irix_FALSE=''
    include_ksysguardd_irix_TRUE=''
    include_ksysguardd_linux_FALSE=''
    include_ksysguardd_linux_TRUE=''
    include_ksysguardd_netbsd_FALSE=''
    include_ksysguardd_netbsd_TRUE=''
    include_ksysguardd_openbsd_FALSE=''
    include_ksysguardd_openbsd_TRUE=''
    include_ksysguardd_solaris_FALSE=''
    include_ksysguardd_solaris_TRUE=''
    include_ksysguardd_tru64_FALSE=''
    include_ksysguardd_tru64_TRUE=''
    include_media_halbackend_FALSE=''
    include_media_halbackend_TRUE=''
    include_media_linuxcdpolling_FALSE=''
    include_media_linuxcdpolling_TRUE=''
    include_x11_FALSE=''
    include_x11_TRUE=''
    includedir='${prefix}/include'
    infodir='${prefix}/info'
    install_sh='/home/ozzy/install/kdebase-3.4.1/admin/install-sh'
    jni_includes=''
    kappfinder_SUBDIR_included_FALSE=''
    kappfinder_SUBDIR_included_TRUE=''
    kate_SUBDIR_included_FALSE=''
    kate_SUBDIR_included_TRUE=''
    kcheckpass_SUBDIR_included_FALSE=''
    kcheckpass_SUBDIR_included_TRUE=''
    kcminit_SUBDIR_included_FALSE=''
    kcminit_SUBDIR_included_TRUE=''
    kcontrol_SUBDIR_included_FALSE=''
    kcontrol_SUBDIR_included_TRUE=''
    kdcop_SUBDIR_included_FALSE=''
    kdcop_SUBDIR_included_TRUE=''
    kde_appsdir=''
    kde_bindir=''
    kde_confdir=''
    kde_datadir=''
    kde_htmldir=''
    kde_icondir=''
    kde_includes=''
    kde_kcfgdir=''
    kde_libraries=''
    kde_libs_htmldir='/usr/lib/kde3/share/doc/HTML'
    kde_libs_prefix='/usr/lib/kde3'
    kde_locale=''
    kde_mimedir=''
    kde_moduledir=''
    kde_qtver=''
    kde_servicesdir=''
    kde_servicetypesdir=''
    kde_sounddir=''
    kde_styledir=''
    kde_templatesdir=''
    kde_wallpaperdir=''
    kde_widgetdir=''
    kdebugdialog_SUBDIR_included_FALSE=''
    kdebugdialog_SUBDIR_included_TRUE=''
    kdeinitdir=''
    kdepasswd_SUBDIR_included_FALSE=''
    kdepasswd_SUBDIR_included_TRUE=''
    kdeprint_SUBDIR_included_FALSE=''
    kdeprint_SUBDIR_included_TRUE=''
    kdesktop_SUBDIR_included_FALSE=''
    kdesktop_SUBDIR_included_TRUE=''
    kdesu_SUBDIR_included_FALSE=''
    kdesu_SUBDIR_included_TRUE=''
    kdialog_SUBDIR_included_FALSE=''
    kdialog_SUBDIR_included_TRUE=''
    kdm_SUBDIR_included_FALSE=''
    kdm_SUBDIR_included_TRUE=''
    kdmlib_SUBDIR_included_FALSE=''
    kdmlib_SUBDIR_included_TRUE=''
    kfind_SUBDIR_included_FALSE=''
    kfind_SUBDIR_included_TRUE=''
    khelpcenter_SUBDIR_included_FALSE=''
    khelpcenter_SUBDIR_included_TRUE=''
    khotkeys_SUBDIR_included_FALSE=''
    khotkeys_SUBDIR_included_TRUE=''
    kicker_SUBDIR_included_FALSE=''
    kicker_SUBDIR_included_TRUE=''
    kioslave_SUBDIR_included_FALSE=''
    kioslave_SUBDIR_included_TRUE=''
    klipper_SUBDIR_included_FALSE=''
    klipper_SUBDIR_included_TRUE=''
    kmenuedit_SUBDIR_included_FALSE=''
    kmenuedit_SUBDIR_included_TRUE=''
    knetattach_SUBDIR_included_FALSE=''
    knetattach_SUBDIR_included_TRUE=''
    konqueror_SUBDIR_included_FALSE=''
    konqueror_SUBDIR_included_TRUE=''
    konsole_SUBDIR_included_FALSE=''
    konsole_SUBDIR_included_TRUE=''
    kpager_SUBDIR_included_FALSE=''
    kpager_SUBDIR_included_TRUE=''
    kpersonalizer_SUBDIR_included_FALSE=''
    kpersonalizer_SUBDIR_included_TRUE=''
    kreadconfig_SUBDIR_included_FALSE=''
    kreadconfig_SUBDIR_included_TRUE=''
    kscreensaver_SUBDIR_included_FALSE=''
    kscreensaver_SUBDIR_included_TRUE=''
    ksmserver_SUBDIR_included_FALSE=''
    ksmserver_SUBDIR_included_TRUE=''
    ksplashml_SUBDIR_included_FALSE=''
    ksplashml_SUBDIR_included_TRUE=''
    kstart_SUBDIR_included_FALSE=''
    kstart_SUBDIR_included_TRUE=''
    ksysguard_SUBDIR_included_FALSE=''
    ksysguard_SUBDIR_included_TRUE=''
    ksystraycmd_SUBDIR_included_FALSE=''
    ksystraycmd_SUBDIR_included_TRUE=''
    ktip_SUBDIR_included_FALSE=''
    ktip_SUBDIR_included_TRUE=''
    kwin_SUBDIR_included_FALSE=''
    kwin_SUBDIR_included_TRUE=''
    kxkb_SUBDIR_included_FALSE=''
    kxkb_SUBDIR_included_TRUE=''
    l10n_SUBDIR_included_FALSE=''
    l10n_SUBDIR_included_TRUE=''
    libdir='${exec_prefix}/lib'
    libexecdir='${exec_prefix}/libexec'
    libkonq_SUBDIR_included_FALSE=''
    libkonq_SUBDIR_included_TRUE=''
    localstatedir='${prefix}/var'
    mandir='${prefix}/man'
    mkdir_p='mkdir -p --'
    nogroup=''
    nsplugins_SUBDIR_included_FALSE=''
    nsplugins_SUBDIR_included_TRUE=''
    oldincludedir='/usr/include'
    pics_SUBDIR_included_FALSE=''
    pics_SUBDIR_included_TRUE=''
    program_transform_name='s,x,x,'
    qt_includes=''
    qt_libraries=''
    sbindir='${exec_prefix}/sbin'
    sharedstatedir='${prefix}/com'
    supports_i8k_FALSE=''
    supports_i8k_TRUE=''
    sysconfdir='${prefix}/etc'
    target='i686-pc-linux-gnuoldld'
    target_alias=''
    target_cpu='i686'
    target_os='linux-gnuoldld'
    target_vendor='pc'
    unsermake_enable_pch_FALSE=''
    unsermake_enable_pch_TRUE=''
    x_includes='NONE'
    x_libraries='NONE'
    xdg_appsdir=''
    xdg_directorydir=''
    xdg_menudir=''
    ## confdefs.h. ##
    #define PACKAGE "kdebase"
    #define PACKAGE_BUGREPORT ""
    #define PACKAGE_NAME ""
    #define PACKAGE_STRING ""
    #define PACKAGE_TARNAME ""
    #define PACKAGE_VERSION ""
    #define VERSION "3.4.1"
    configure: exit 1
    Padrão kde.
    Código :
    Vc tem gcc? Se tiver verifique se ele está na variável $PATH.
    # echo $PATH
    michigan
    Padrão kde.
    nao tenho.
    Padrão kde.
    Citação Postado originalmente por michigan
    nao tenho.
    Então demoro pra vc instalar. Sem o compilador C não vai ter como mesmo.
