    Padrão Apache nao inicia!
    boas !!!
    Gostaria de saber o moditvo do meu Apache nao inciciar faxo /etc/ini.d/httpd start e da este erro.
    A iniciar o httpd: [Thu Jul 14 13:10:30 2005] [warn] NameVirtualHost 217.129.212.227:0 has no VirtualHosts
    [FALHOU]
    gostaria qeue me ensinasse pois eu sou novasso em linux
    executa o seguinte como root:
    # apachectl -S
    e posta o resultado
    Padrão resultado!
    aki vai o resultado!!
    [[email protected] install]# apachectl -S
    [Thu Jul 14 13:44:22 2005] [warn] NameVirtualHost 217.129.212.227:0 has no VirtualHosts
    VirtualHost configuration:
    wildcard NameVirtualHosts and _default_ servers:
    _default_:443 sm-217-129-212-227.netvisao.pt (/etc/httpd/conf.d/ssl.conf:88)
    *:80 is a NameVirtualHost
    default server atleta-digital.no-ip.com (/etc/httpd/conf/httpd.conf:1060)
    port 80 namevhost atleta-digital.no-ip.com (/etc/httpd/conf/httpd.conf:1060)
    port 80 namevhost atleta-digital.com (/etc/httpd/conf/httpd.conf:1065)
    port 80 namevhost www.atleta-digital.com (/etc/httpd/conf/httpd.conf:1070)
    port 80 namevhost design.atleta-digital.com (/etc/httpd/conf/httpd.conf:1075)
    port 80 namevhost atleta-digital-users.no-ip.com (/etc/httpd/conf/httpd.conf:1080)
    port 80 namevhost fccesarense.com (/etc/httpd/conf/httpd.conf:1085)
    port 80 namevhost www.fccesarense.com (/etc/httpd/conf/httpd.conf:1090)
    port 80 namevhost villacesari.no-ip.com (/etc/httpd/conf/httpd.conf:1095)
    port 80 namevhost digisport.no-ip.org (/etc/httpd/conf/httpd.conf:1100)
    port 80 namevhost www.belamodashop.com (/etc/httpd/conf/httpd.conf:1105)
    port 80 namevhost www.vitor-rodrigues.com (/etc/httpd/conf/httpd.conf:1110)
    Syntax OK
    eita, que estranho, la no primeiro post ele fala que o problema eh de virtual host, mas esse comando nao falou nada....tenta executar apachectl start
    Padrão REsposta
    [[email protected] install]# apachectl start
    [Thu Jul 14 14:03:24 2005] [warn] NameVirtualHost 217.129.212.227:0 has no VirtualHosts
    aki ta o k vc pediu !!
    Padrão Re: REsposta
    Citação Postado originalmente por olifile
    [[email protected]227 install]# apachectl start
    eh....cara, da uma olhada na configuracao do teu apache, no virtualhost 217.129.212.227:0, ou na declaracao dele....pq o erro ta la
    Padrão ok
    mas onde é k eu vejo isso. pois komo disse sou novasso em Linux. se vc me poder indicar. eu uso o Fedora Core 4.
    Padrão Re: ok
    hehhee...foi mal...a configuracao do apache fica (nesse caso) em /etc/http/httpd.conf, eu soh nao sei se vo poder ti ajudar muito, pq pelos logs q vc mostro o apache ta com uma configuracao grande pra virtual hosts, foi vc quem configuro??
    Padrão sim
    sim foi eu k configuerei os virtuais host. atleta-digital.com .... etc. mas pk k vc nao me vai poder ajudar????
    nao, calma, nao eh pq eu nao quero, eh q se vc quizer q eu (ou qq um do Under) ajude, vc vai precisar postar sua configuracao dos virtualhosts.....se vc quizer, eh soh postar
    Padrão Re: REsposta
    todo o conf nao precisa pq deve ser bem extenso, mas posta o virtual host desse cara ai em cima
