Página 5 de 5 PrimeiroPrimeiro 12345
    ice_box
    smvda
    todas as contribuiçoes são validas
    mas com conteudo
    tem de ver que nem toda a gente esta no mesmo nivel técnico
    em todas as áreas
    se vc descrever a sua solução de uma forma consintente
    ela ser sim bem vinda
    Abraço
    Citação Postado originalmente por ice_box
    firewall sem as regras do Jim
    pois elas deixam o ruindows todo tété
    #!/bin/sh
    # DECLARA VARIAVEIS
    IPT=/sbin/iptables
    MACLIST=/etc/rc.d/maclist
    PROGRAMA=/etc/rc.d/firewallmac
    NET_IFACE=eth0
    LAN_IFACE=eth1
    # APAGA TODAS AS REGRAS
    $IPT -F
    $IPT -t nat -F
    $IPT -t filter -F
    $IPT -t mangle -F
    # APAGA TODAS AS CHAINS
    $IPT -X
    $IPT -t nat -X
    $IPT -t filter -X
    $IPT -t mangle -X
    # CARREGA MODULOS
    modprobe ip_tables
    modprobe iptable_nat
    case $1 in
    # START CONTROLO REGRAS MAC-IP -- MAC / IP
    start)
    # FECHAS TODAS AS RESTANTES PORTAS - CANCELA O FORWARD NO SERVIDOR
    $IPT -t filter -P INPUT DROP
    $IPT -t filter -P FORWARD DROP
    # PERMITE LOOPBACK
    $IPT -t filter -A INPUT -i lo -j ACCEPT
    $IPT -t filter -A OUTPUT -o lo -j ACCEPT
    # LIBERA CONEXÕES PARA FORA
    $IPT -t filter -A OUTPUT -m state --state NEW,ESTABLISHED,RELATED -j ACCEPT
    # LIBERA CONEXÕES DO EXTERIOR INICIADAS DO INTERIOR DA REDE. O RESTO É CANCELADO
    $IPT -t filter -A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
    $IPT -t filter -A INPUT -i eth1 -s 172.16.0.0/24 -j ACCEPT
    $IPT -t filter -A INPUT -i eth1 -s 172.16.1.0/24 -j ACCEPT
    # INTERPRERTAÇAO DO FICHEIRO MACLIST
    for i in `cat $MACLIST`; do
    STATUS=`echo $i | cut -d ';' -f 1`
    IPSOURCE=`echo $i | cut -d ';' -f 3`
    MACSOURCE=`echo $i | cut -d ';' -f 2`
    # Se STATUS = [a] então Libera a Conexão
    if [ $STATUS = "a" ]; then
    $IPT -t filter -A FORWARD -d 0/0 -s $IPSOURCE -m mac --mac-source $MACSOURCE -j ACCEPT
    $IPT -t filter -A FORWARD -d $IPSOURCE -s 0/0 -j ACCEPT
    $IPT -t nat -A POSTROUTING -s $IPSOURCE -o $NET_IFACE -j MASQUERADE
    $IPT -t filter -A INPUT -s $IPSOURCE -d 0/0 -m mac --mac-source $MACSOURCE -j ACCEPT
    $IPT -t filter -A OUTPUT -s $IPSOURCE -d 0/0 -j ACCEPT
    # SQUID NINJA
    $IPT -t nat -A PREROUTING -d $IPSOURCE -i eth1 -p tcp --dport 80 -j REDIRECT --to-port 800
    # Se STATUS =/= [a] então Bloqueia a Conexão
    else
    $IPT -t filter -A INPUT -m mac --mac-source $MACSOURCE -j DROP
    $IPT -t filter -A OUTPUT -m mac --mac-source $MACSOURCE -j DROP
    $IPT -t filter -A FORWARD -m mac --mac-source $MACSOURCE -j DROP
    fi
    done
    # Compartilha a conexão
    # LIBERANDO SSH DO FIREWALL PARA O MUNDO
    iptables -A INPUT -s 0/0 -p tcp --dport 22 -j ACCEPT
    # FECHA O RESTO
    iptables -A INPUT -j DROP
    iptables -A FORWARD -j DROP
    echo ""
    echo "FIREWALL ATIVO -- REGRAS MAC x IP --> IMPLEMENTADAS -- [ SISTEMA PREPARADO ]"
    echo " "
    echo "REGRAS FIREWALL MAISLINK -- HABILITADAS"
    echo " "
    echo "NAT [ATIVADO]"
    echo " "
    echo "SQUID NINJA [ATIVADO]"
    echo " "
    # STOP CONTROLO REGRAS MAC-IP -- MAC / IP
    stop)
    # FECHAS TODAS AS RESTANTES PORTAS - HABILITA O FORWARD NO SERVIDOR
    $IPT -t filter -P FORWARD ACCEPT
    #Compartilha a conexão
    $IPT -t nat -A POSTROUTING -o eth0 -j MASQUERADE
    # SQUID NINJA
    $IPT -t nat -A PREROUTING -i eth1 -p tcp --dport 80 -j REDIRECT --to-port 800
    echo""
    echo "FIREWALL ATIVO -- REGRAS MAC x IP --> REMOVIDAS -- [ SISTEMA PREPARADO ]"
    echo " "
    echo " "
    echo " "
    echo " "
    # RESTART CONTROLO -- MAC / IP
    restart)
    $PROGRAMA stop
    $PROGRAMA start
    esac
    cara como fica o maclist???
    maclist fica assim
    a;macadress;ip_cliente;nome_cliente liberado
    b;macadress;ip_cliente;nome_cliente bloqueado
    tudo o que seja diferente de "a" n vai navegar
  1. Respostas: 5
    Último Post: 07-10-2011, 20:38
  2. dividir ip valido na rede interna
    Por geeko no fórum Redes
    Último Post: 09-08-2005, 09:50
  3. IP Válidos na rede Interna
    Por marcosfs no fórum Servidores de Rede
    Respostas: 15
    Último Post: 05-11-2004, 14:03
  4. Bloquear ip's na rede mas não entre si
    Por moon_knight no fórum Servidores de Rede
    Último Post: 27-04-2004, 12:31
  5. Rotear IPs válidos para rede inválida
    Respostas: 15
    Último Post: 23-10-2002, 15:46
