    alexandresamorim
    Padrão problemas na instalação do zebedee
    Boa tarde galera estou com problema em instalar o zebedee no linux slackware 10.1
    O que foi feito?
    Bem primeiro baixei o zebedee 2.4.1.tar.gz.
    depois; tar -zxvf zebedee 2.4.1.tar.gz.
    cd zebedee-2.4.1/
    make e ai vem o erro
    Use 'make OS=xxx' where xxx is win32, linux, solaris, freebsd, tru64, irix, hpux, macosx or bsdi
    make: *** [precheck] Error 1
    Grato
    alexandreamorim
    nao eh um erro... eh q o make dele eh diferente
    pra instalar ele, vc deve executar como root:
    Código :
    ./configure
    make OS=linux
    make install
    []'s
    alexandresamorim
    Obrigado......mas deu outro erro. olhe abaixo
    [email protected]:/etc/zebedee/zebedee-2.5.2# make install OS=linux
    gcc -pthread -Wall -O3 -DHAVE_PTHREADS -I. -I../blowfish-0.9.5a -I../zlib-1.1.4 -I../bzip2-1.0.1 -c -o zebedee.o zebedee.c
    zebedee.c:62:22: blowfish.h: No such file or directory
    zebedee.c:323: error: parse error before "BF_KEY"
    zebedee.c:323: warning: no semicolon at end of struct or union
    zebedee.c: In function `makeMsgBuf':
    zebedee.c:1293: error: `msg' undeclared (first use in this function)
    zebedee.c:1293: error: (Each undeclared identifier is reported only once
    zebedee.c:1293: error: for each function it appears in.)
    zebedee.c:1296: error: parse error before ')' token
    zebedee.c: At top level:
    zebedee.c:1302: error: parse error before '->' token
    zebedee.c:1337: warning: type defaults to `int' in declaration of `free'
    zebedee.c:1337: warning: parameter names (without types) in function declaration
    zebedee.c:1337: error: conflicting types for `free'
    /usr/include/stdlib.h:597: error: previous declaration of `free'
    zebedee.c:1337: warning: data definition has no type or storage class
    zebedee.c:1338: error: parse error before "return"
    zebedee.c:1352: error: parse error before '*' token
    zebedee.c: In function `freeMsgBuf':
    zebedee.c:1354: error: `msg' undeclared (first use in this function)
    zebedee.c:1370: error: parse error before '*' token
    zebedee.c: In function `setMsgBuf':
    zebedee.c:1390: error: `msg' undeclared (first use in this function)
    zebedee.c:1390: error: `size' undeclared (first use in this function)
    zebedee.c:1391: error: `buffer' undeclared (first use in this function)
    zebedee.c:1412: error: parse error before "MsgBuf_t"
    zebedee.c: In function `readMessage':
    zebedee.c:1429: error: `fd' undeclared (first use in this function)
    zebedee.c:1438: error: `thisSize' undeclared (first use in this function)
    zebedee.c:1438: error: `msg' undeclared (first use in this function)
    zebedee.c:1468: warning: implicit declaration of function `BF_cfb64_encrypt'
    zebedee.c:1470: error: `BF_DECRYPT' undeclared (first use in this function)
    zebedee.c:1564: warning: dereferencing type-punned pointer will break strict-aliasing rules
    zebedee.c:1614: error: parse error before "MsgBuf_t"
    zebedee.c: In function `writeMessage':
    zebedee.c:1616: error: `msg' undeclared (first use in this function)
    zebedee.c:1647: warning: dereferencing type-punned pointer will break strict-aliasing rules
    zebedee.c:1731: error: `BF_ENCRYPT' undeclared (first use in this function)
    zebedee.c:1753: error: `fd' undeclared (first use in this function)
    zebedee.c:2854: error: parse error before '*' token
    zebedee.c:2856: warning: return type defaults to `int'
    zebedee.c: In function `setupBlowfish':
    zebedee.c:2857: error: `bf' undeclared (first use in this function)
    zebedee.c:2858: error: `BF_ROUNDS' undeclared (first use in this function)
    zebedee.c:2868: error: parse error before ')' token
    zebedee.c:2858: warning: unused variable `keyData'
    zebedee.c:2859: warning: unused variable `keyBytes'
    zebedee.c:2875: warning: type defaults to `int' in declaration of `keyBytes'
    zebedee.c:2875: error: `keyStr' undeclared here (not in a function)
    zebedee.c:2875: error: `keyBits' undeclared here (not in a function)
    zebedee.c:2875: error: `keyData' undeclared here (not in a function)
    zebedee.c:2875: error: initializer element is not constant
    zebedee.c:2875: warning: data definition has no type or storage class
    zebedee.c:2877: error: parse error before numeric constant
    zebedee.c:2878: error: parse error before '&' token
    zebedee.c:2878: warning: type defaults to `int' in declaration of `BF_set_key'
    zebedee.c:2878: warning: type defaults to `int' in declaration of `keyBytes'
    zebedee.c:2878: warning: type defaults to `int' in declaration of `keyData'
    zebedee.c:2878: error: parse error before ')' token
    zebedee.c:2879: error: parse error before '->' token
    zebedee.c:2879: warning: type defaults to `int' in declaration of `memcpy'
    zebedee.c:2879: warning: data definition has no type or storage class
    zebedee.c:2880: error: parse error before '->' token
    zebedee.c: In function `hexStrToBits':
    zebedee.c:3414: error: `BF_ROUNDS' undeclared (first use in this function)
    zebedee.c:3556: error: parse error before "MsgBuf_t"
    zebedee.c: In function `clientPerformChallenge':
    zebedee.c:3566: error: `serverFd' undeclared (first use in this function)
    zebedee.c:3566: error: `msg' undeclared (first use in this function)
    zebedee.c:3641: error: parse error before "MsgBuf_t"
    zebedee.c: In function `serverPerformChallenge':
    zebedee.c:3653: error: `msg' undeclared (first use in this function)
    zebedee.c:3654: error: `clientFd' undeclared (first use in this function)
    zebedee.c:4067: error: parse error before "MsgBuf_t"
    zebedee.c: In function `filterLoop':
    zebedee.c:4073: error: `localFd' undeclared (first use in this function)
    zebedee.c:4073: error: `remoteFd' undeclared (first use in this function)
    zebedee.c:4083: error: `udpMode' undeclared (first use in this function)
    zebedee.c:4125: error: `msgBuf' undeclared (first use in this function)
    zebedee.c:4165: error: `replyFd' undeclared (first use in this function)
    zebedee.c:4166: error: `toAddrP' undeclared (first use in this function)
    zebedee.c: In function `client':
    zebedee.c:5459: error: `msg' undeclared (first use in this function)
    zebedee.c: In function `server':
    zebedee.c:6256: error: `msg' undeclared (first use in this function)
    zebedee.c: In function `main':
    zebedee.c:8032: warning: unused variable `serviceArgs'
    make: *** [zebedee.o] Error 1
    Grato
    alexandreamorim
    em q distro vc estah instalando?
    veja se no seu /usr/include ou /usr/local/include existe esse arquivo blowfish.h
    se nao, instale o pacote dele...
    []'s
    alexandresamorim
    Esse arquivo se encontra em /usr/include/openssl/blowfish.h e a distri.... que estou usando é o slackware 10.1
    grato
    alexandreamorim
    tente ver se nao é possivel informar junto ao configure (d um ./configure --help) o caminho do blowfish.h...
    qq coisa, copie o arquivo blowfish.h para o diretorio /usr/include
    e compile novamente
    []'s
    alexandresamorim
    Bem esta mudando o erro....copiei o blowfish.h para /usr/include e agora aparece isso...
    [email protected]:~/zebedee-2.4.1# make install OS=linux
    gcc -pthread -O3 -DHAVE_PTHREADS -I. -I../blowfish-0.9.5a -I../zlib-1.1.4 -I../bzip2-1.0.1 -o zebedee zebedee.o sha_func.o huge.o ../blowfish-0.9.5a/libblowfish.a ../zlib-1.1.4/libz.a ../bzip2-1.0.1/libbz2.a -lpthread
    gcc: ../blowfish-0.9.5a/libblowfish.a: No such file or directory
    gcc: ../zlib-1.1.4/libz.a: No such file or directory
    gcc: ../bzip2-1.0.1/libbz2.a: No such file or directory
    make: *** [zebedee] Error 1
    ele tah falando q nao tah encontrando 3 arquivos
    eles existem, se sim, onde?
    se existirem... indique o caminho deles no configure ou copie eles para uma estrutura d diretorios conforme o configure estah t mostrando
    ../diretorio/arquivo
    []'s
    alexandresamorim
    ok o problema é que não tem o ./configure no manual ele pede para dar apenas um make e pronto, tbm achei que deveria ter o ./configure mas não tem. Vc ja instalou esse Zebedee se sim tem como me mandar o pacote pra mim;
    [email protected]
    grato.
    alexandreamorim
    baixe o .tgz dele aque
    http://ftp.nluug.nl/ftp/pub/os/Linux/distr/trinux/pkg/
    e instale usando o gerenciador d pacotes do slack... cujo nome nao me lembro hahahha
    mas acho q eh pkgtool ou algo asism hauhUAHUha
    []'s
    felco
    Citação Postado originalmente por alexandresamorim
    Filho... olha isso:
    Aonde voce achou essa linha?
    poootz... no make install... nao precisava mesmo do OS=linux...
    eu nem tinha me ligado... ele soh foi necessario na hora do make
    []'s
    alexandresamorim
    Cara primeiro fiz o seguinte;
    make OS=linix deu o erro então tentei o make install mas tbm deu o mesmo erro olhe abaixo;
    [email protected]:~/zebedee-2.4.1# make OS=linux
    Ha e para complementar ai esta o make install sem o OS=linux
    e pelo pkgtool com aquele .tgz q eu t passei? funfou?
    []'s
    alexandresamorim
    Sim, demiurgo deu sertinho muito obrigado pela atenção. Voce tbm usa firebird?
    disponha :]
    uso sim
    []'s
    alexandresamorim
    ok, obrigado..
    Então sobre firebird estou trabalhando no CPD de uma empresa e nessa empresa estamos recentemente com o banco de dados firebird em software em delphi. esta tudo funcionando bem. ou quase bem; estou tendo alguns erros podendo assim ser minha rede que ainda tenho que ver mas queria ter certesa que é minha rede, enfim estou com um problemão por que vai que eu fale que é a rede e trocamos tudo e mesmo assim continuar o erro.....vc me entende!!!
    No seu lugar o que faria?
    Abaixo vai o log do firebied
    bdados (Server) Wed Jul 20 07:53:53 2005
    Super Server/main: Bad client socket, send() resulted in SIGPIPE, caught by server
    client exited improperly or crashed ????
    INET/inet_error: send errno = 32
    bdados (Server) Wed Jul 20 07:56:58 2005
    INET/inet_error: read errno = 104
    bdados (Server) Wed Jul 20 08:05:02 2005
    bdados (Server) Wed Jul 20 08:34:05 2005
    [email protected]:~/zebedee-2.5.2# tail -f /usr/local/firebird/firebird.log
    Como vc pode ver esta acontecendo com uma certa frequencia.
    grato
    alexandreamorim
    crie um novo topico, no forum de firebird e poste esse seu problema com o firebird...
    para nao misturar as coisas...
    vou trancar o topico e respondo no novo que vc criar
    #LOCKED :twisted:
