    sambaloco40
    Ai, depois de uma madruga de testes resolvi todos dos problemas. Bom, realmente o FORWARD precisa ficar aberto, logo mudei essa política. Ficou assim:
    #!/bin/bash
    # Autor: RENAN DE SOUZA RODRIGUES - jamanta44@bol.com.br
    # Agradecimentos: www.guiadohardware.net ; under-linux.org
    firewall_start()
    # Altera a politica de INPUT FORWARD OUTPUT
    /usr/sbin/iptables -P INPUT DROP
    /usr/sbin/iptables -P FORWARD ACCEPT
    /usr/sbin/iptables -P OUTPUT DROP
    # Abre para o DHCPD
    /usr/sbin/iptables -A INPUT -i eth1 -p udp --sport 68 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth1 -p udp --dport 68 -j ACCEPT
    /usr/sbin/iptables -A INPUT -i eth1 -p udp --sport 67 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth1 -p udp --dport 67 -j ACCEPT
    # Abre o HTTPD
    /usr/sbin/iptables -A INPUT -i eth0 -p tcp --dport 80 -j ACCEPT
    /usr/sbin/iptables -A INPUT -i eth0 -p tcp --sport 80 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p tcp --dport 80 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p tcp --sport 80 -j ACCEPT
    # Abre para uma faixa de endereços da rede local
    /usr/sbin/iptables -A INPUT -i eth0 -p all -s 134.41.35.0/255.255.255.0 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p all -d 134.41.35.0/255.255.255.0 -j ACCEPT
    /usr/sbin/iptables -A INPUT -i eth0 -p all -s 192.168.0.0/255.255.255.0 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p all -d 192.168.0.0/255.255.255.0 -j ACCEPT
    /usr/sbin/iptables -A INPUT -i eth1 -p all -s 134.41.35.0/255.255.255.0 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth1 -p all -d 134.41.35.0/255.255.255.0 -j ACCEPT
    /usr/sbin/iptables -A INPUT -i eth1 -p all -s 192.168.0.0/255.255.255.0 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth1 -p all -d 192.168.0.0/255.255.255.0 -j ACCEPT
    # Abre para a interface de loopback.
    /usr/sbin/iptables -A INPUT -i lo -s 127.0.0.1/255.255.255.255 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o lo -d 127.0.0.1/255.255.255.255 -j ACCEPT
    # FTP Cliente
    /usr/sbin/iptables -A INPUT -i eth0 -p tcp --sport 20 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p tcp --dport 20 -j ACCEPT
    /usr/sbin/iptables -A INPUT -i eth0 -p tcp --sport 21 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p tcp --dport 21 -j ACCEPT
    #FTP Servidor
    /usr/sbin/iptables -A INPUT -i eth0 -p tcp --dport 20 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p tcp --sport 20 -j ACCEPT
    /usr/sbin/iptables -A INPUT -i eth0 -p tcp --dport 21 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p tcp --sport 21 -j ACCEPT
    # SSH Servidor
    /usr/sbin/iptables -A INPUT -i eth0 -p tcp --dport 22 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p tcp --sport 22 -j ACCEPT
    # SSH Cliente
    /usr/sbin/iptables -A OUTPUT -o eth0 -p tcp --dport 22 -j ACCEPT
    /usr/sbin/iptables -A INPUT -i eth0 -p tcp --sport 22 -j ACCEPT
    # DNS Cliente
    /usr/sbin/iptables -A INPUT -i eth0 -p tcp --sport 53 -j ACCEPT
    /usr/sbin/iptables -A INPUT -i eth0 -p udp --sport 53 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p tcp --dport 53 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p udp --dport 53 -j ACCEPT
    # Libera o HTTP e o HTTPS
    /usr/sbin/iptables -A INPUT -i eth0 -p tcp --sport 443 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p tcp --dport 443 -j ACCEPT
    # Ignora mais algumas coisas ruins
    echo "1" > /proc/sys/net/ipv4/icmp_echo_ignore_all
    echo "1" > /proc/sys/net/ipv4/tcp_syncookies
    echo "1" > /proc/sys/net/ipv4/icmp_echo_ignore_broadcasts
    echo "0" > /proc/sys/net/ipv4/conf/eth0/accept_source_route
    # Compartilha a internet com proxy e carrega modulos necessarios
    modprobe ip_conntrack_ftp
    modprobe ip_nat_ftp
    modprobe iptable_nat
    iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
    iptables -t nat -A PREROUTING -i eth1 -p tcp --dport 80 -j REDIRECT --to-port 3128
    firewall_stop()
    /usr/sbin/iptables -F
    /usr/sbin/iptables -t nat -F
    /usr/sbin/iptables -X
    /usr/sbin/iptables -P INPUT ACCEPT
    /usr/sbin/iptables -P OUTPUT ACCEPT
    modprobe ip_nat_ftp
    case "$1" in
    "start")firewall_start;
    echo "Firewall is runnig.";;
    "stop")firewall_stop;
    echo "Firewall is NOT runnig.";;
    "restart")firewall_stop;
    sleep 1;
    firewall_start;
    echo "Firewall was restarted and it is runnig.";;
    *)/usr/sbin/iptables -L -n;;
    esac
    É isso ai galera! Problema resolvidos total!! Tudo rodando perfeitamente. Valeu as opiniões.
    []'s
  2. porque esta dessa forma?? essas regras não estão duplicadas?
    # Abre o HTTPD
    até agora não entendi a questão do forward, pelo que entendo forward é usado quando um pacote vai passar pela maquina firewall, o que não parece ser o caso já que o HTTPD esta na mesma maquina em que esta o firewall
  3. #13
    sambaloco40
    Bom, olhando agora parece duplicado mesmo. O lance do FORWARD era para o proxy, não para o httpd.Sem o FORWARD ACCEPT, o proxy não funfa. Ai como não queria ficar fazendo tantas regras, acho que não ficaria ruim assim, fica? Vou tirar esses duplicações e testar. Vamos ver...
  4. #14
    sambaloco40
    Ai, agora sim. Segue as configurações que funfaram bem aqui. Sem regras repetidas e com servers a toda:
    #!/bin/bash
    # Agradecimentos: www.guiadohardware.net https://under-linux.org
    firewall_start()
    # Abre para o DHCPD
    /usr/sbin/iptables -A INPUT -i eth0 -p all -s 132.41.32.0/255.255.255.0 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth0 -p all -d 132.41.32.0/255.255.255.0 -j ACCEPT
    /usr/sbin/iptables -A INPUT -i eth1 -p all -s 132.41.32.0/255.255.255.0 -j ACCEPT
    /usr/sbin/iptables -A OUTPUT -o eth1 -p all -d 132.41.32.0/255.255.255.0 -j ACCEPT
    # FTP Cliente
    #FTP Servidor
    # SSH Servidor
    # SSH Cliente
    # DNS Cliente
    # Abre o HTTPD
    modprobe ip_nat_ftp
    firewall_stop()
    modprobe ip_nat_ftp
    case "$1" in
    sleep 1;
    firewall_start;
    esac
    Quem tiver dúvidas/sugestões/opiniões manda ai que estou ouvindo!
    []'s RENAN
  1. Problemas com IPTABLES
    Último Post: 20-01-2004, 10:35
  2. Problema com Iptables em Cache Server
    Último Post: 04-10-2003, 00:53
  3. Problemas com IPTABLES
    Último Post: 11-07-2003, 16:38
  4. Problemas com IPTABLES
    Último Post: 26-06-2003, 10:00
  5. problemas com iptables
    Respostas: 15
    Último Post: 05-02-2003, 18:00
