    Padrão Estranhos IPS no log do Squid
    Aeee alguem pode me dizer pq apareceram esse ip's q nao constam na rota da minha rede aqui.
    #pico /var/squid/logs/acess.log
    #1123701515.466 8 200.97.188.117 TCP_DENIED/403 1352 CONNECT 67.18.232.154:25 - NONE/- text/html
    1123701515.680 7 200.97.188.117 TCP_DENIED/403 1352 CONNECT 67.18.232.154:25 - NONE/- text/html
    1123701515.868 8 200.97.188.117 TCP_DENIED/403 1352 CONNECT 67.18.232.154:25 - NONE/- text/html
    1123702380.670 8 200.97.188.117 TCP_DENIED/403 1352 CONNECT 67.18.232.154:25 - NONE/- text/html
    1123702380.863 8 200.97.188.117 TCP_DENIED/403 1352 CONNECT 67.18.232.154:25 - NONE/- text/html
    1123702381.134 12 200.97.188.117 TCP_DENIED/403 1352 CONNECT 67.18.232.154:25 - NONE/- text/html
    1123704124.787 8 200.97.188.117 TCP_DENIED/403 1352 CONNECT 67.18.232.154:25 - NONE/- text/html
    1123704125.068 0 200.97.188.117 TCP_DENIED/403 1352 CONNECT 67.18.232.154:25 - NONE/- text/html
    1123704125.379 10 200.97.188.117 TCP_DENIED/403 1352 CONNECT 67.18.232.154:25 - NONE/- text/html
    1123705504.408 5 61.141.185.251 TCP_DENIED/403 1352 CONNECT 68.142.226.33:80 - NONE/- text/html
    1123705508.540 1313 61.141.185.251 TCP_MISS/200 11383 GET http://www.yahoo.com/ - DIRECT/216.109.117.106 text/html
    1123755715.608 3 219.134.232.252 TCP_DENIED/403 1370 CONNECT smtp.mail.yahoo.com.cn:25 - NONE/- text/html
    1123755738.587 0 219.133.247.127 TCP_DENIED/403 1356 CONNECT ms94.url.com.tw:25 - NONE/- text/html
    1123755868.051 10 219.134.73.88 TCP_DENIED/403 1356 CONNECT ms94.url.com.tw:25 - NONE/- text/html
    1123755912.897 3 219.134.232.17 TCP_DENIED/403 1364 CONNECT smtp.mail.yahoo.com:25 - NONE/- text/html
    1123755958.617 2 219.134.31.97 TCP_DENIED/403 1352 CONNECT cml.hinet.net:25 - NONE/- text/html
    1123764418.602 68 219.133.247.127 TCP_DENIED/403 1356 CONNECT ms94.url.com.tw:25 - NONE/- text/html
    1123764607.524 0 219.134.73.88 TCP_DENIED/403 1356 CONNECT ms94.url.com.tw:25 - NONE/- text/html
    1123764649.903 9 219.134.232.252 TCP_DENIED/403 1370 CONNECT smtp.mail.yahoo.com.cn:25 - NONE/- text/html
    1123769042.576 5 218.17.75.210 TCP_DENIED/403 1364 CONNECT smtp.mail.yahoo.com:25 - NONE/- text/html
    Aparecem esses ips negando serviço só q esses ips nao sao da minha rede.
    Alguem ae Help-me
    sambaloco40
    Padrão ora, estão tentando te roubar!!
    Amigo, estão tentando roubar acesso pelo seu proxy. Sabe esse end com final cn ai? São da China, onde a internet é controlada pelo governo. Ai eles tentam sair por qualquer lado! As linhas que tem :25 são tentativar de uso do seu servidor como spammer! Ainda bem que estão sendo bloqueados!
    Colega.. isso é pq vc tem a porta do squid aberta para todo o mundo, entao esses spammers estao tentando se connectar pra enviar spam pelo seu servidor.. isso é facil de resolver
    iptables -A INPUT -p tcp -i ethX (placa ligada á Internet) --dport 3128 -j DROP
    e tá feito.. n vai ter mais problemas
    Um abraço.
    Citação Postado originalmente por The-shadow
    Um abraço.
    Como fica esta regra so p/ minha rede?
    Ola
    Uma solução mais prátia ainda é mudar a linha no seu squid.conf para:
    http_port 192.168.1.1:3128
    icp_port 0
    onde 192.168.1.1 é o IP do servidor que ta rodando o squid...
    t+
    whinston
    Padrão 2 regras
    1) coloca 1 regra no firewall pra nao aceitar conexao na porta do proxy que não seja da sua LAN
    2) coloca 1 ACL no proxy pra fz a mesma coisa, só aceitar conexão vinda dos Ips da LAN
    Padrão Re: 2 regras
    Citação Postado originalmente por whinston
    Complementando, a regra no firewall seria a seguinte:
    supondo que a sua rede seja 192.168.1.0
    iptables -t nat -A PREROUTING -s ! 192.168.1.0/24 -j REJECT (ou DROP)
    iptables -A FORWARD -s ! 192.168.1.0/24 -j REJECT
    iptables -A INPUT -s ! 192.168.1.0/24 -j REJECT
    Talvez eu esteja sendo um pouco redundante (mas uma linha a mais não custa nada).
    Teu firewal não aceitará nenhuma conexão mais com máquinas de fora da sua rede.
    Mas se lembre que é importante liberar algumas portas, como por exemplo DNS (53), eu particularmente defino somente a ip's específicos.
    Para definir as portas você deve usar
    -p tcp (ou udp) --dport 53
    e para a volta da requisição
    -p tcp (ou udp) --sport 53
    não esqueça que na volta você inverte o -s e o -d.
    Assim verifique os seus serviços que necessitam de portas abertas, abras mas especifique qual ip determinado terá acesso a estas portas.
    Para mais informações
    http://focalinux.cipsga.org.br/guia/...w-iptables.htm
    []'s
    wrochal
    Caro,
    No caso nem precisa colocar regras de iptables, basta deixar a regra all bloqueada e a porta do squid apenas para rede internet.
    Porta do squid
    # http_port IP_DO_PROXY:PORTA_PROXY
    http_port 192.168.0.1:3128
    acl all src 0.0.0.0/0.0.0.0
    acl rede src 192.168.0.0/24
    http_access allow rede
    http_access deny all
    Bastaria isso.
    falou,
    Olá, também passei por isso. Meu squid também bloqueava o acesso, mas o relatório do sarg era puro 'lixo', por causa desses ips.
    Fiz um mini tutorial esses tempos, pra bloquear isso. E o pessoal ainda contribuiu com algumas dicas legais.
    Dá uma olhada:
    Bloqueando o uso do squid por spammers
    https://under-linux.org/noticia5361.html
