    Padrão Eth1
    Estou com duas placas de rede mas quando dou um ifconfig soh aparece uma. A outra não levanta. O que pode ser. Estou usando o suse então tah um pouco diferente aqui os aquivos de configuração.
    rato16br
    Padrão Eth1
    Dê uma olhada se o módulo da mesma esta sendo carregado na inicialização, caso sim então insira a linha: ificonfig eth1 (IP a ser atribuido ) netmask ( mascara ) up no arquivo /etc/rc.d/rc.local
    Padrão Eth1
    Como vejo se o módulo está sendo carregado?
    Padrão Eth1
    srv-cony:/etc # lspci
    0000:00:00.0 Host bridge: Intel Corp. 82845G/GL[Brookdale-G]/GE/PE DRAM Controller/Host-Hub Interface (rev 01)
    0000:00:01.0 PCI bridge: Intel Corp. 82845G/GL[Brookdale-G]/GE/PE Host-to-AGP Bridge (rev 01)
    0000:00:1d.0 USB Controller: Intel Corp. 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 (rev 01)
    0000:00:1d.1 USB Controller: Intel Corp. 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 (rev 01)
    0000:00:1d.2 USB Controller: Intel Corp. 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 (rev 01)
    0000:00:1d.7 USB Controller: Intel Corp. 82801DB/DBM (ICH4/ICH4-M) USB 2.0 EHCI Controller (rev 01)
    0000:00:1e.0 PCI bridge: Intel Corp. 82801 PCI Bridge (rev 81)
    0000:00:1f.0 ISA bridge: Intel Corp. 82801DB/DBL (ICH4/ICH4-L) LPC Bridge (rev 01)
    0000:00:1f.1 IDE interface: Intel Corp. 82801DB/DBL (ICH4/ICH4-L) UltraATA-100 IDE Controller (rev 01)
    0000:00:1f.3 SMBus: Intel Corp. 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller (rev 01)
    0000:00:1f.5 Multimedia audio controller: Intel Corp. 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller (rev 01)
    0000:01:00.0 VGA compatible controller: nVidia Corporation NV17 [GeForce4 MX 440] (rev a3)
    0000:02:01.0 Ethernet controller: VIA Technologies, Inc. VT6105 [Rhine-III] (rev 86)
    0000:02:02.0 Ethernet controller: Accton Technology Corporation SMC2-1211TX (rev 10)
    srv-cony:/etc # ifconfig
    eth0 Link encap:Ethernet HWaddr 00:E0:29:12:1A:43
    inet addr:10.1.1.3 Bcast:10.255.255.255 Mask:255.0.0.0
    inet6 addr: fe80::2e0:29ff:fe12:1a43/64 Scope:Link
    UP BROADCAST NOTRAILERS RUNNING MULTICAST MTU:1500 Metric:1
    RX packets:7576 errors:0 dropped:0 overruns:0 frame:0
    TX packets:7683 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:1000
    RX bytes:5012896 (4.7 Mb) TX bytes:1010657 (986.9 Kb)
    Interrupt:9 Base address:0x6800
    lo Link encap:Local Loopback
    inet addr:127.0.0.1 Mask:255.0.0.0
    inet6 addr: ::1/128 Scope:Host
    UP LOOPBACK RUNNING MTU:16436 Metric:1
    RX packets:1250 errors:0 dropped:0 overruns:0 frame:0
    TX packets:1250 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:0
    RX bytes:82228 (80.3 Kb) TX bytes:82228 (80.3 Kb)
    srv-cony:/etc # ifup eth1
    ERROR: Interface eth1 is not available
    Padrão Eth1
    cara..
    nao sei se na sua distro serah o mesmo comando, mas no conectiva pra ver os módulos carregados o comando é
    lsmod
    caso nao esteja carregando o módulo, verifique o arquivo (se existir em sua distro) /etc/modprobe.conf, veja se tem o módulo da sua placa de rede...
    valew
    Padrão Eth1
    Estão carregando sim.
    doidoht
    Padrão Eth1
    vai no yast e procura lá a respeito de network (ou rede se for em Português) e configura o IP na segunda placa... se não tiver lá é pq seguer achou o módulo ...
    qual o modelo da placa?! Tem que ser velhaća pro SuSE não tá reconhecendo....
    Padrão Eth1
    No Yast ele encontra e já está configurado. A placa eh nova. No ifconfig que não aparece e nem levanta.
    Padrão Eth1
    Só para postar a minha solução. Troquei a segunda placa de slot passando do slot 2 para o 3. Assim funcionou de boa.
    Padrão Eth1
    Galera, uma coisa que me ensinaram aqui e que hoje estou vendo o quanto valeu.
    Eu venho de cultura do Conectiva 6, 8, e 10.
    Sempre usava o Linuxconf para configurar o necessário.
    Me sugeriram usar o modo texto para fazer as coisas na "unha".
    Realmente. Deu certo.
    Já passei pelo Mandrake 10, Kurumin, Suse 9.3 e agora o Slackware 10.1. E não posso negar. Fazer as configurações na mão realmente, a gente não sente a diferença de uma distro para outra.
    Eu instalei o Slackware 10.1 como servidor de internet na empresa. E o SuSE 9.3 como o meu desktop tanto na empresa como aqui em casa.
    Quero aprender. E é legal fazer as configurações na "unha" . Parece um saco, dar a sensação de voltar ao antigo DOS ou Netware, mas é assim que conhecemos.
    Um grande abraço fórum do Underlinux ... :clap:
