    Padrão Erro na SCSI
    Pessoal,
    Tenho um servidor que está dando constantemente a mensagem de erro:
    Aug 30 17:59:46 mail kernel: SCSI disk error : host 0 channel 0 id 0 lun 0 return code = 8000002
    Aug 30 17:59:46 mail kernel: Info fld=0xd557, Deferred sd08:01: sense key Hardware Error
    Aug 30 17:59:46 mail kernel: I/O error: dev 08:01, sector 54632
    Aug 30 17:59:55 mail kernel: SCSI disk error : host 0 channel 0 id 0 lun 0 return code = 8000002
    Aug 30 17:59:55 mail kernel: Info fld=0xe183, Deferred sd08:01: sense key Hardware Error
    Aug 30 17:59:55 mail kernel: I/O error: dev 08:01, sector 57768
    Aug 30 18:00:03 mail kernel: SCSI disk error : host 0 channel 0 id 0 lun 0 return code = 8000002
    Aug 30 18:00:03 mail kernel: Info fld=0xeae9, Deferred sd08:01: sense key Hardware Error
    Aug 30 18:00:03 mail kernel: I/O error: dev 08:01, sector 60088
    Aug 30 18:00:15 mail kernel: SCSI disk error : host 0 channel 0 id 0 lun 0 return code = 8000002
    Aug 30 18:00:15 mail kernel: Info fld=0x10376, Deferred sd08:01: sense key Hardware Error
    Aug 30 18:00:15 mail kernel: I/O error: dev 08:01, sector 66408
    Aug 30 18:00:25 mail kernel: SCSI disk error : host 0 channel 0 id 0 lun 0 return code = 8000002
    Aug 30 18:00:25 mail kernel: Info fld=0x98e90, Deferred sd08:01: sense key Hardware Error
    Aug 30 18:00:25 mail kernel: I/O error: dev 08:01, sector 1041016
    Segue o conteudo do diretório /proc/scsi/scsi
    [[email protected] backup]# cat /proc/scsi/scsi
    Attached devices:
    Host: scsi0 Channel: 00 Id: 00 Lun: 00
    Vendor: HP 18.2G Model: MAN3184MC Rev: HP04
    Type: Direct-Access ANSI SCSI revision: 02
    Host: scsi0 Channel: 00 Id: 01 Lun: 00
    Host: scsi0 Channel: 00 Id: 06 Lun: 00
    Vendor: ARCHIVE Model: Python 04106-XXX Rev: 7350
    Type: Sequential-Access ANSI SCSI revision: 02
    Esse erro refere-se ao HD 1 ???
    O que significa Deferred sd08:01: sense key Hardware ??
    e return code = 8000002 diz respeito a que ??
    Grato.
    Padrão Erro na SCSI
    Cara tenho um servidor da Dell e outro dia suspeitei de ter problemas no scsi, liguei la e eles me mandaram uma ferramenta que testou tudo, acredite!
    TEm umas ferramentas linux que testam o scsi, mas eu nao consegui instalar elas.
    Padrão Erro na SCSI
    Você sabe quais são ?? Ela testa a SCSI com ele em execução e volumes montados??
    Meu servidor é montado.
    Se vc puder me dar os nomes eu agradeço.
    Padrão Programa
    Olá !!!
    Quinta passada um dos HDs (SCSI) do servidor DELL daqui tava dando uns problema e a DELL me passou este programinha e o sacaninha testa tudo mesmo, o monitor piscava que parecia uma boate B) . Resultado, eles vão trocar o HD e a garantia acabava em setembro , ops hj eh dia 30 !!
    Se o seu servidor for DELL, se você quiser, eu posso lhe passar o programa. Me manda uma MP. , Ele funciona no boot, ele cria uma RamDrive, a primeira msg que aparece é: Iniciando o windows 95, haushaushaushausaushauhausahaushaushsahsua :martelo: !!! Mas o programinha eh bom!
    Eu dei uma procurada no google e tem centenas de mensagem de erro semelhante a sua.....
    E achei este site:
    http://unthought.net/Software-RAID.H...OWTO.html#toc1
    Abraço !!!
    Padrão Erro na SCSI
    Descobri o problema, Ele está no cooler dos HD's, estão parados. Os discos estavam parecendo frigideiras. Se colocasse ovos em cima eles fritavam. ehehehe
    Deixei o servidor aberto com um ventilador voltado para ele.
    Depois que carrreguei o linux, esse erro não apareceu mais.
    Amanhã vou compra novos coolers e substituo.
    Se eu quiser verificar por badblocks no linux, eu posso usar o comando badblocks, vocês sabe, se posso fazer com a máquina em produção ?? quais os prejuízos que posso ter ???
    Abraços.
    Padrão Erro na SCSI
    cara eu nao me lembro o nome dos programas nao
    so sei que eles sao free, se eu nao me engano é scu o nome do testador.
    Eles testam o hd desmontado, imagino que seja um fsck para scsi....
