    Padrão email, ftp, telnet lentos!será q é dns???
    Ai pessoal estou com problemas de lentidão pra conectar no meu server local!!!
    tipo no outlook demora quase dois minutos para conectar no servidor(postfix), no ftp tb demora qdo digito ftp.thelast.com.br demora o mesmo tempo pra conectar!!!Minha rede é ponto-a-ponto deveria ser mto rapido!!!
    Um amigo disse que pode ser probema no dns!!!Séra que ele tem razao???
    Segue arquivos de configuracao pra vc's analisarem!!!
    named.conf
    ########################3
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    memstatistics-file "/var/named/dump/named.memstats";
    // remove this next line if you want named to listen on
    // all available interfaces, or adjust add new ones as
    // you see fit
    listen-on { 192.168.0.1/32; };
    // a caching only nameserver config
    zone "." {
    type hint;
    file "named.ca";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    zone "thelast.com.br" {
    type master;
    file "thelast.com.br";
    zone "0.168.192.in-addr.arpa" {
    type master;
    file "192.168.0.1.rev";
    thelast.com.br
    $TTL 600
    @ IN SOA thelast.com.br. root.thelast.com.br. (
    2005062000 ; serial;
    3600 ; refresh
    900 ; retry
    1209600 ; expire
    43200 ) ; default_ttl
    @ IN NS thelast.com.br.
    @ IN NS laboratorio.thelast.com.br.
    @ IN MX 5 laboratorio.thelast.com.br.
    laboratorio.thelast.com.br. IN A 192.168.0.1
    www IN CNAME laboratorio.thelast.com.br.
    ftp IN CNAME laboratorio.thelast.com.br.
    pop IN CNAME laboratorio.thelast.com.br.
    smtp IN CNAME laboratorio.thelast.com.br.
    Reverso
    $TTL 600
    2005051000
    3600
    900
    1209600
    43200 )
    1 IN PTR thelast.com.br.
    resolv.conf
    search thelast.com.br
    nameserver 192.168.0.1
    hosts
    127.0.0.1 localhost.localdomain localhost
    192.168.0.1 laboratorio.localdomain laboratorio
    192.168.0.1 laboratorio.thelast.com.br laboratorio
    Será que vc's podem me ajudar????????
    Embora eu acredite que não, tenta trocar o hostname pelo IP e ver se vai rápido. Se não for, é porque não é.
    Fiz o teste por IP e continua a mesma coisa o por que será que demora tanto(quase dois minutos pra conectar!!!)
    aki está o link pra um post que coloquei no forum sobre servidores de email!!!Lá tem todas as configuracoes do postfix!!!será que o problema é no postfix???
    https://under-linux.org/modules.php?...wtopic&t=34307
    Valeu pela atencao
    Logo o problema não é com DNS.
    vc usa o INETD ou XINETD?
    como esta o PING alto ou baixo?
    O ping está normal
    o serviço é o xinetd
    experimenta usar o inetd .. eu tivew esse problema para acessar fora da minha rede com o xinetd com o inetd ficou normal
