    perl-5.8.5-8tr,
    eu tentei por fonte tb...
    (wget http://pam.sourceforge.net/mod_auth....0-1.1.1.tar.gz)
    root@server ~# cd /tmp/mod_auth_pam#
    root@server /tmp/mod_auth_pam# make
    apxs -c mod_auth_pam.c -lpam
    /home/httpd/build/libtool --silent --mode=compile i586-trustix-linux-gcc -prefer -pic -O3 -fomit-frame-pointer -pipe -s -mpentium -mcpu=pentium -march=pentium -f expensive-optimizations -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES=1 -D_LARGEFILE64_S OURCE=1 -DAP_HAVE_DESIGNATED_INITIALIZER -DLINUX=2 -D_REENTRANT -D_XOPEN_SOURCE= 500 -D_BSD_SOURCE -D_SVID_SOURCE -D_GNU_SOURCE -pthread -I/usr/include/apache - I/usr/include/apache -I/usr/include/apache -c -o mod_auth_pam.lo mod_auth_pa m.c && touch mod_auth_pam.slo
    mod_auth_pam.c:145:31: security/pam_appl.h: No such file or directory
    mod_auth_pam.c:255: warning: `struct pam_response' declared inside parameter list
    mod_auth_pam.c:255: warning: its scope is only this definition or declaration, which is probably not what you want
    mod_auth_pam.c:255: warning: `struct pam_message' declared inside parameter list
    mod_auth_pam.c: In function `auth_pam_talker':
    mod_auth_pam.c:269: error: `PAM_CONV_ERR' undeclared (first use in this function)
    mod_auth_pam.c:269: error: (Each undeclared identifier is reported only once
    mod_auth_pam.c:269: error: for each function it appears in.)
    mod_auth_pam.c:272: error: invalid application of `sizeof' to an incomplete type
    mod_auth_pam.c:279: error: invalid use of undefined type `struct pam_response'
    mod_auth_pam.c:279: error: dereferencing pointer to incomplete type
    mod_auth_pam.c:280: error: invalid use of undefined type `struct pam_response'
    mod_auth_pam.c:280: error: dereferencing pointer to incomplete type
    mod_auth_pam.c:283: error: dereferencing pointer to incomplete type
    mod_auth_pam.c:284: error: `PAM_PROMPT_ECHO_ON' undeclared (first use in this function)
    mod_auth_pam.c:286: error: invalid use of undefined type `struct pam_response'
    mod_auth_pam.c:286: error: dereferencing pointer to incomplete type
    mod_auth_pam.c:288: error: `PAM_PROMPT_ECHO_OFF' undeclared (first use in this function)
    mod_auth_pam.c:289: error: invalid use of undefined type `struct pam_response'
    mod_auth_pam.c:289: error: dereferencing pointer to incomplete type
    mod_auth_pam.c:299: error: `PAM_SUCCESS' undeclared (first use in this function)
    mod_auth_pam.c: In function `pam_auth_basic_user':
    mod_auth_pam.c:325: error: variable `conv_info' has initializer but incomplete type
    mod_auth_pam.c:325: warning: excess elements in struct initializer
    mod_auth_pam.c:325: warning: (near initialization for `conv_info')
    mod_auth_pam.c:325: error: storage size of `conv_info' isn't known
    mod_auth_pam.c:326: error: `pam_handle_t' undeclared (first use in this function)
    mod_auth_pam.c:326: error: `pamh' undeclared (first use in this function)
    mod_auth_pam.c:347: error: `PAM_SUCCESS' undeclared (first use in this function)
    mod_auth_pam.c:368: error: `PAM_DISALLOW_NULL_AUTHTOK' undeclared (first use in this function)
    mod_auth_pam.c:373: error: `PAM_USER_UNKNOWN' undeclared (first use in this function)
    apxs:Error: Command failed with rc=65536
    make: *** [mod_auth_pam.la] Error 1
  2. #7
    acho que esse modulo nao funciona no apache2, sinceramente olhei no google milhares de pessoas com esse problema, e nenhuma resposta
  3. #8
    Alguém já enfrentou este problema ? :toim:
  4. #9
    ninguém utilizou esse modo ??!?
  5. Estou utilizando sem problemas Guest.
    Consegui fazer rodar no Slackware, claro tive que isntalar o Pam.
    e estou rodando tambem nos Fedoras sem problemas.
    Qual distro você está utilizando???
  1. como funciona o mod_auth do apache ?
    Último Post: 07-09-2005, 17:04
  2. mod_auth erro doido
    Último Post: 07-09-2005, 09:41
  3. Auteticação com mod_auth não funciona
    Por LeOnArDzEn no fórum Servidores de Rede
    Último Post: 09-02-2004, 12:04
