  1. Coloquei sim o redirecionamento da porta 80 para a 3128
    agora estou com outro problema
    Código :
    root@srv-glemt:/home/kurumin/salva/squid# squid start
    FATAL: Could not determine fully qualified hostname.  Please set 'visible_hostname'
    Squid Cache (Version 2.5.STABLE10): Terminated abnormally.
    CPU Usage: 0.037 seconds = 0.026 user + 0.011 sys
    Maximum Resident Size: 0 KB
    Page faults with physical i/o: 0
    Aborted
    root@srv-glemt:/home/kurumin/salva/squid# echo $HOSTNAME
    srv-glemt
    squid.conf
    Código :
    http_port 3128
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    cache_mem 16 MB
    maximum_object_size_in_memory 64 KB
    maximum_object_size 16 MB
    minimum_object_size 0 KB
    cache_swap_low 90
    cache_swap_high 95
    cache_dir ufs /var/spool/squid 128 16 256
    visible_hostname srv-glemt
    unique_hostname srv-glemt
    ftp_user [email]kurumin@kurumin.com.br[/email]
    refresh_pattern ^ftp:  15 20% 2280
    refresh_pattern .  15 20% 2280
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80  # http
    acl Safe_ports port 21  # ftp
    acl Safe_ports port 70  # gopher
    acl Safe_ports port 210  # wais
    acl Safe_ports port 280  # http-mgmt
    acl Safe_ports port 488  # gss-http
    acl Safe_ports port 591  # filemaker
    acl Safe_ports port 777  # multiling http
    acl Safe_ports port 901  # SWAT
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    http_access allow localhost
    acl proibidos dstdom_regex "/etc/squid/proibidos"
    http_access deny proibidos
    # Esta acl serve para bloquear alguns domínios específicos. você pode
    # incluir quantos domínios quiser, basta separá-los por espaço e colocar
    # tudo na mesma linha:
    #acl bloqueados dstdomain orkut.com [url]www.orkut.com[/url] playboy.abril.com.br
    #http_access deny bloqueados
    acl redelocal src 192.168.1.0/24
    http_access allow redelocal
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
  2. unique_hostname srv-glemt
    Esta opção precisa ser algo do tipo: nome.dominio
    [ ] 's
  3. Antes estava usando sem essa opção mas encontrei algo na internet (num tenho nem idéia de onde) que falava pra corrigir isso colocando esta e a visible_hostname mas não resolveu.
    Li também que tem a ver com a linha do /etc/hosts. Editei colocando assim:
    127.0.0.0 hostname localhost (essa linha eh padrão(num lembro o ip certo))
    192.168.1.1 srv-glemt srv-glemt
    Mas continua dando o mesmo erro.
  4. Tentou fazer o que eu propus?
  5. Já sim. Inclusive com um dominio válido.
    Normalmente o povu não coloca "unique_hostname". Já testei sem ela também. O erro eh no "visible hostname"
  1. Inicialização do Squid
    Por ATNunes no fórum Servidores de Rede
    Último Post: 11-12-2002, 10:30
  2. Duvidas sobre Log access.log do SQUID !!!
    Por Danielvb no fórum Servidores de Rede
    Último Post: 23-11-2002, 15:46
  3. Log do Squid?
    Último Post: 15-10-2002, 19:50
  4. figura na pagina de erro do squid
    Por roggy no fórum Servidores de Rede
    Último Post: 25-09-2002, 16:40
  5. como limpar o cache do squid?
    Último Post: 17-08-2002, 11:13
