    Joerbeth
    Padrão Meu Fire, querendo Conectividade Social
    Pessoal, desculpem, más estou quase a beira do desespero mesmo...
    Olha, este é meu Fire:
    #!/bin/sh
    IPT='/usr/sbin/iptables'
    NET_IFACE='eth0'
    LAN_IFACE='eth1'
    LAN_RANGE='192.168.3.0/24'
    IP_LOCAL='192.168.3.254'
    IP_UNIREMA='200.200.187.178'
    IP_RMT_WWW='192.168.3.1'
    IP_RMT_POP='192.168.3.2'
    PROXY="172.16.6.5"
    PORT="8027"
    /sbin/modprobe ip_conntrack
    /sbin/modprobe ipt_MASQUERADE
    /sbin/modprobe ipt_LOG
    /sbin/modprobe iptable_nat
    echo 0 > /proc/sys/net/ipv4/conf/default/log_martians
    $IPT -F
    $IPT -Z
    $IPT -t nat -F
    $IPT -t filter -P FORWARD DROP
    $IPT -t filter -A INPUT -i lo -s 0/0 -d 0/0 -j ACCEPT
    $IPT -t filter -A OUTPUT -o lo -s 0/0 -d 0/0 -j ACCEPT
    $IPT -t filter -A INPUT -i $LAN_IFACE -m state --state NEW -j ACCEPT
    $IPT -t filter -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
    $IPT -t filter -A FORWARD -d 0/0 -s $LAN_RANGE -o $NET_IFACE -j ACCEPT
    $IPT -t filter -A FORWARD -d $LAN_RANGE -s 0/0 -i $NET_IFACE -j ACCEPT
    $IPT -t nat -A POSTROUTING -o $NET_IFACE -j MASQUERADE
    $IPT -t nat -A POSTROUTING -o $NET_IFACE -j ACCEPT
    $IPT -t nat -A PREROUTING -p tcp -d 192.168.3.254 --dport 3128 -j DNAT --to $PROXY:$PORT
    $IPT -t nat -A PREROUTING -p udp -d 192.168.3.254 --dport 3128 -j DNAT --to $PROXY:$PORT
    #$IPT -A INPUT -p all -s 200.201.174.207 -j ACCEPT
    #$IPT -A INPUT -p all -s 200.201.174.204 -j ACCEPT
    $IPT -t nat -A POSTROUNTING -p TCP --dport 2631 -s $LAN_RANGE -d 0/0 -j MASQUERADE
    #$IPT -t nat -A POSTROUTING -s $LAN_RANGE -d 200.201.173.68 -j MASQUERADE
    #$IPT -t nat -A POSTROUTING -s $LAN_RANGE -d 200.201.174.204 -j MASQUERADE
    #$IPT -t nat -A POSTROUTING -s $LAN_RANGE -d 200.201.166.200 -j MASQUERADE
    #$IPT -t nat -A POSTROUTING -s $LAN_RANGE -d 200.201.174.207 -j MASQUERADE
    $IPT -t nat -A PREROUTING -p tcp -d $IP_UNIREMA --dport 80 -j DNAT --to $IP_RMT_WWW
    $IPT -t nat -A PREROUTING -p udp -d $IP_UNIREMA --dport 80 -j DNAT --to $IP_RMT_WWW
    $IPT -t nat -A PREROUTING -p tcp -d $IP_UNIREMA --dport 110 -j DNAT --to $IP_RMT_POP
    $IPT -t nat -A PREROUTING -p udp -d $IP_UNIREMA --dport 110 -j DNAT --to $IP_RMT_POP
    $IPT -t nat -A PREROUTING -p tcp -d $IP_UNIREMA --dport 25 -j DNAT --to $IP_RMT_POP
    $IPT -t nat -A PREROUTING -p udp -d $IP_UNIREMA --dport 25 -j DNAT --to $IP_RMT_POP
    $IPT -t filter -A INPUT -s $LAN_RANGE -d 0/0 -j ACCEPT
    $IPT -t filter -A OUTPUT -s $LAN_RANGE -d 0/0 -j ACCEPT
    $IPT -t filter -A OUTPUT -p icmp -s $LAN_RANGE -d 0/0 -j ACCEPT
    As linhas que estão comentadas: # são as que tentei acessar/liberar para a caixa economicca, más não deu certo, por favor, alguém poderia me ajudar, montando o retante das linhas para acesso ao Conectividade Social?
    Valeu pessoal!
    Joerbeth
    augusto_jdl
    Visite este link:
    https://under-linux.org/noticia5475.html
    e vc poderá resolver o seu problema.
    Dica: Antes de postar uma mensagem pesquise sobre o assunto aki no fórum.
    Boa Sorte!
    Joerbeth
    Padrão Nada
    Kra. não sei o que está acontecendo, pois eu já vi esse tópico e segui todas as regras, e num deu certo, por isso mesmo, que eu postei meu fire aqui para modificações, pois como falei, ainda sou leigo e estou apanhando pra caramba...
    Olha, acho que a solução de um colega lá, que faz um Loop, vai dá certo, más só que, ele não declarou estas variaveis:
    i=?
    redein=?
    iptables -A INPUT -s $rh -i $redein -p tcp -d $i -j ACCEPT
    Falow
    Tem esta tambem, veja se te ajuda
    https://under-linux.org/noticia5157.html
    Joerbeth
    Von, já fiz tb os procedimentos daí, e nada...
    Pessoal, eu só queria o seguinte, como eu já coloquei o meu Fire aqui, alguma pessoa me ajudar em montar essas regras para Caixa, e depois eu testar aquo, pois, depois de montado e que realmente funcione, o problema é aqui...
    Falow
    Sera que nao e esta sua regra de drop na primeira linha
    Padrão Re: Já
    Cara vc tem que liberar a porta do conectividade social no chain FORWARD !!!!!!
    Joerbeth
    Padrão Ajuda
    Pow galera, não me levem a mal, más como falei, agora que estou começando a pegar a coisa, me ajudem a montar esse fire aí, por favor, algumas coisas que vocês, falaram com fluentemente, pode e ser e é novo pra mim...
    Valeu
    mushroom-br
    Pior que eu também estou sendo cobrado na empresa pelo Departamento Pessoal sobre a Conectividade Social da Caixa.
    Inclusive a própria Caixa já nos ligou falando sobre isso.
    Acabei de ler agora no www.guiadohardware.net e vou tentar utilizar isso.
    Legal galera. Obrigado. Qualquer coisa, posto aqui ...... :good:
