    Jan 2004
    Capital do Triângulo
    Padrão AP LINUX
    nesta opção:
    $IWPRIV wlan0 wlan_para networktype=infra
    mude para:
    $IWPRIV wlan0 wlan_para networktype=master
    Veja se funciona, caso nao funcione, comente essa linha e use:
    $IWPRIV wlan0 wlan_para mode=master
  2. #14
    sadirj
    Padrão AP LINUX
    Tentei as duas formas mas não funcionou. depois que carrego modulo e "estarto" a placa aparece o seguinte no /var/log/messages:
    Código :
    Nov 23 14:40:59 hermes kernel: RTL8180:  ------ Enable wlan driver ------
    Nov 23 14:40:59 hermes kernel: RTL8180: WLAN driver version 1.3
    Nov 23 14:40:59 hermes kernel: RTL8180: wireless LAN controller RTL8180 + philips RF.
    Nov 23 14:40:59 hermes kernel: RTL8180: PHILIPS_Config()
    Nov 23 14:40:59 hermes kernel: RTL8180: PHILIPS_Config() - Analog mode
    Nov 23 14:40:59 hermes kernel: RTL8180: ENABLE_RTL_DCST
    Nov 23 14:40:59 hermes kernel: RTL8180:  Set dot11PrivacyInvoked = 0.
    Nov 23 14:40:59 hermes kernel: RTL8180:  encryptmode = RTL_ENC_NONE
    Nov 23 14:40:59 hermes kernel: RTL8180:  wepkeymode = WEP_MODE_OFF
    Nov 23 14:41:02 hermes kernel: RTL8180: Start an IBSS network at channel 11
    Nov 23 14:41:02 hermes kernel: IBSSJoin(): Please check out the following ...
    Nov 23 14:41:02 hermes kernel: IBSSJoin(): BSSID = 0x02:0xe0:0x4f:0x2f:0x16:0x97
    Nov 23 14:41:02 hermes kernel: IBSSJoin(): SSID = aptest2
    Nov 23 14:41:02 hermes kernel: IBSSJoin(): dot11BeaconPeriod = 100
    Nov 23 14:41:02 hermes kernel: IBSSJoin(): dot11DtimPeriod = 0
    Nov 23 14:41:02 hermes kernel: IBSSJoin(): dot11OperationalRates = 0x03
    Nov 23 14:41:02 hermes kernel: IBSSJoin(): mCap = 0x02
    Nov 23 14:41:02 hermes kernel: RTL8180: Act_UpdateBeaconFrame......
    Nov 23 14:41:02 hermes kernel: RTL8180: TIM_setup......
    Nov 23 14:41:07 hermes kernel: RTL8180: Searching IBSS...
    Nov 23 14:41:10 hermes kernel: RTL8180: Start an IBSS network at channel 11
    Nov 23 14:41:10 hermes kernel: IBSSJoin(): Please check out the following ...
    Nov 23 14:41:10 hermes kernel: IBSSJoin(): BSSID = 0x02:0xe0:0x4f:0x2f:0x16:0x97
    Nov 23 14:41:10 hermes kernel: IBSSJoin(): SSID = aptest2
    Nov 23 14:41:10 hermes kernel: IBSSJoin(): dot11BeaconPeriod = 100
    Nov 23 14:41:10 hermes kernel: IBSSJoin(): dot11DtimPeriod = 0
    Nov 23 14:41:10 hermes kernel: IBSSJoin(): dot11OperationalRates = 0x03
    Nov 23 14:41:10 hermes kernel: IBSSJoin(): mCap = 0x02
    Nov 23 14:41:10 hermes kernel: RTL8180: Act_UpdateBeaconFrame......
    Nov 23 14:41:10 hermes kernel: RTL8180: TIM_setup......
    E fica assim direto, em um loop infinito. Parece que tem que compilar o modulo denovo com alguma opção... eu segui o passo-a-passo do Eduardo Mota, o único que consegui fazer funcionar. Segue o link:
    http://www.emota.com.br/wireless/rtl8180.html
    Obrigado mais uma vez.
  3. #15
    Jan 2004
    Padrão AP LINUX
    acho que falei asneira antes ops:
    use assim:
    iwpriv wlan0 disable -> desliga antes
    OS OUTROS COMANDOS...
    #iwpriv wlan0 drv_para apclient_enable=1 -> modo cliente
    iwpriv wlan0 drv_para apclient_enable=0 -> modo AP
    iwpriv wlan0 enable -> liga
    Se não funcionar, então essa placa que voce usa, ou os drivers que instalou não possui a opção.
  4. #16
    sadirj
    Padrão AP LINUX
    Sergio meu caro, valeu!!!! agora sim funcionou! vc tem uma lista completa dos comandos? o arquivo de exemplo que vem com ele não tinha essa opção que vc passou pra mim e que fez funcionar. Manda a lista ou melhor, me diz onde eu pego, que aí eu posso configurar de acordo com minhas necessidades.
    Desculpe pelo incômodo e mais uma vez, Muito Obrigado!
  5. #17
    Jan 2004
    Padrão AP LINUX
    sadirj, não tenho lista não... eu quase não uso RTL aqui(somente umas ovislink com linux), por isso vacilei no comando que passei primeiro... Na verdade esse comando que passei e funcionou é daqui mesmo (forum wireless), dica postada pelo aheringer. Quanto aos outros comandos possiveis tenta ae:
    #man iwpriv
    #iwpriv --help
    e a propria documentação que veio com os drivers que você compilou.
