    Padrão Re: Projeto Firmware Free VIDA
    gostei da ideia.. !! se possivel.. com fotos tambem
  2. #162
    jdprevedello
    Alguem sabe como fazer um openssh conectar nun dropbear sem senha?
  3. #163
    Aê pessoal, a quantas anda o DESENVOLVIMENTO do firmware? Percebi que o tópico ficou sendo usado mais pra dicas de recuperação de rádios (Cabo serial, JTAG, etc.) que para o desenvolvimento em si....
  4. #164
    unpacking firmware Edimax EW-7209PG to get the rootfilesystem
    1. Download EdiEngEW7209APg_1.20.bin
    2.dd if=EdiEngEW7209APg_1.20.bin of=image.bz2 bs=38932 skip=1
    3.bzip2 -d image.bz2
    4.dd if=image of=image.ext2 skip=1 bs=1884160
    5. mount -t ext2 -o loop image.ext2 /mnt/ext2 -o ro,nodev,nosuid,noexec
    thats all
    if you are lazy, in this link you have the rootfilesystem
    http://www.box.net/index.php?rm=box_..._id=f_18845476
    Edmian
  5. #165
    aê brother, em que site vc conseguiu estas informações?
  6. #166
    Hi
    I didnt find this on a site. I was working with the GPL source code from Edimax, and after a couple of weeks, I culd get this information.
    I hope this was usefull for someone.
    Edmian.
  7. #167
    Hey edmian the URL you provided is not accessible...the website says: "User is not allowed to use direct links.". Antother question I have: Is this procedure applicable to other firmware images, like the original ovislink firmware, or ap-router?! thx
  8. #168
    sorry, I didnt know that,this is the new link http://www.box.net/public/9ghatea376 ,its not direct link, but here is the file.The procedure is not the same for other firmwares, because the point where cuts the file is different. try to find it, its not complicated, for example ,the point 2 ,you have to search this chain BZh9 . you cuold serach this points comparing one firmware with the other.
    Edmian
    pd: extra ball,the "AP ROUTER" rootfilesystem ,here http://www.box.net/public/trcm4571zo
  9. #169
    bro, what command do you use to search these points (od?, what parameters? ?)? and how to compare the firmware images? I'm intending to extract the rootfs of Zinwell firmwares...and What about re-making the firmware images? Is there a way to do that, or a I have to adapt the availables SDKs and generate the images from the rootfs that I got with your procedure? thx
  10. #170
    shortlinux.sourceforge.net
    no forum do sourceforge do short tem uma explicação de como obter o rootfs ... talvez ajude tambem !!!
  11. #171
    Valeu pessoal, eu tô doido pra fazer um firmware bacana, que atenda às minhas necessidades (pois só uso essas bridges - Ovislink, Zinwell - em clientes)...quero implementar umas funções bacanas de QOS, connlimit, etc...ai se eu conseguir eu posto aqui!
  12. #172
    thats the idea, post what we find out, To research Im using linux and the midnight commander, with this program you can see the the file in hexa mode or binary, and you can make a chain search ,its so easy to use.About re-making the firmware ,I didnt test it. When I descompress the bunzip image, the end of the file is fill with garbage, i dont know why.In the invert process will be not garbage, May be it is necesary to fill with especific sizes file, I dont know. and testing it has a risk ops:
    Edmian
  13. #173
    jane.ordenavia
    !! Olá sou nova aqui e estou precisando de uma ajudinha, algem sabe as pinagens seriais dos APs EDIMAX 7206, LINKSYS WET11 e WET54G, DLINK DWL900+, OVISLINK WL1120AP, to temtando salvar eles mas esta dificil, agradeço a ajuda!!
  14. #174
    a do ovislink 1120 vc consegue em
  15. #175
    um solucao interessante que achei foi o brazilfw ele tem boas opcoes e é de facil inclusao de componentes... alguem jah tentou portar ele para alguma ap???
  16. #176
    pelo que vi do brasilfw.. tem mto recurso "pesado" para o processador desses aparelhos "embbedded"
  17. #177
    e se conseguissemos fazer uma "versao" com recursos mais apropriados para as ap's onde fosse possivel a pessoa que utilizar acrescer os recursos conforme necessario, no mesmo esquema usando o mount acrescendo e fechando??? ficaria até interessante...
  18. #178
    nao eh simples assim nao heeh !!
    a arquitetura eh outra (MIPS)... o espaço e memoria .. bem limitados...
  19. #179
    somebody knows if is there some emulator to test the rtl8186 firmwares? im testing a edimax version adding dropbear, but it doesnt work the dropbear server at the moment,and I would like to test it on emulator.
    Edmian
  20. #180
    exists for rtl8181 ?
