digo ... no lugar do no é yes
eu instalei o uebimiau aqui .. so que deu um seguinte erro .... na hora que abre o site e clica em login .... vcé direcionado para uma pagina chamada msglist.php so que quando é direcionado nao acontece nada... no navegador aparece concluido la em baixo e a tela fica toda branca
oque pode ser?
vou postar o config.php
Defaults:
1 - Yes/On/True
0 - No/Off/False
_ Please attention _:
The temporary files will be stored on this folder
For security reasons, do not use web-shared folders
** The Web Server needs write-permission on this folder
* Unix/Linux users use.
/tmp/uebimiau
* Win32 users
c:/winnt/temp/uebimiau
** Note: Under Win32, use "right bars";
$temporary_directory = "temporary_files/";
Your local SMTP Server (alias or IP) like as "smtp.yourdomain.com"
eg. server1;server2;server3 -> specify main and backup server
$smtp_server = "smtp.dominio.com.br;dominio2.com.br"; //YOU NEED CHANGE IT !!
The maximum size for stored files
$quota_limit = 512000; //in KB, eg. 2048 Kb = 2MB
Your local POP3 Servers, ____ OPTIONAL ___
// 1st
$pop3_servers[0]["domain"] = "dominio.com.br";
// $pop3_servers[0]["server"] = "pop.nada.com.br";
// 2nd
$pop3_servers[1]["domain"] = "dominio2.com.br";
//$pop3_servers[1]["server"] = "pop3.2ndDomain.com";
// Nnd
//$pop3_servers[2]["domain"] = "NndDomain.com";
//$pop3_servers[2]["server"] = "pop3.NndDomain.com";
Language settings
$default_language = 0;
$allow_user_change = 0; //allow users select language
$languages[0]["name"] = "Português Brasileiro";
$languages[0]["path"] = "themes/pt-brasil"; // folder that is stored the theme
$languages[1]["name"] = "English";
$languages[1]["path"] = "themes/english"; // folder that is stored the theme
Date format for non-portuguese systems
$date_format = "d/m/y h:m"; // d = day, m = month, y = year, h = hour, m = minutes
In some POP3 servers, if you send a "RETR" command, your
message will be automatically deleted
This option prevents this inconvenience
$pop_use_top = 1;
Enable HTML messages (recommended)
$mime_show_html = 1;
Use SMTP password (AUTH LOGIN type)
$use_password_for_smtp = 0;
// $use_email_as_user_pop3 = 1;
// $use_email_as_user_smtp = 1;
// $check_first_login = yes;
// $mime_show_html = yes;
Name and Version, it's used in many places, like as
"X-Mailer" field, footer
$appversion = "2.0";
$appname = "UebiMiau";
Add an "footer" to sent mails
$footer = "
________________________________________________
This mail was sent by $appname $appversion
Enable debug
$enable_debug = 0 ;
Session timeout for inactivity
$idle_timeout = 10; //minutes
Order setting
$default_sortby = "date";
$default_sortorder = "DESC";
Default preferences...
$send_to_trash_default = 1; //send deleted messages to trash
$st_only_ready_default = 1; //only read messages, otherwise, delete it
$save_to_sent_default = 1; //send sent messages to sent
$empty_trash_default = 1; //empty trash on logout
$sortby_default = "date"; //alowed: "attach","subject","fromname","date","size"
$sortorder_default = "DESC"; //alowed: "ASC","DESC"
$rpp_default = 10; // records per page (messages), alowed: 10,20,30,40,50
$add_signature_default = 0; //add the signature by default
$signature_default = ""; // an default signature for all users
