  1. nao eh pra colocar isso no ld.so.conf
    /var/log/packages/ncurses-5.4-i486-2
    eh pra vc abrir esse arquivo e ver onde estao as libs, e ai sim, colocar o path das libs no ld
  2. #7
    slackrio
    Oconteudo do arquivo ncurses-5.4-i486-2
    lib/
    lib/libncurses.so.5.4
    lib/libncursesw.so.5.4
    usr/
    usr/bin/
    usr/bin/tic
    usr/bin/toe
    usr/bin/tack
    usr/bin/tput
    usr/bin/tset
    usr/bin/clear
    usr/bin/infocmp
    usr/lib/
    usr/lib/libpanel.so.5.4
    usr/lib/libform.a
    usr/lib/libmenuw.so.5.4
    usr/lib/libformw.so.5.4
    usr/lib/libmenuw.a
    usr/lib/libmenu.a
    usr/lib/libform.so.5.4
    usr/lib/libformw.a
    usr/lib/libpanelw.so.5.4
    usr/lib/libncurses++w.a
    usr/lib/libmenu.so.5.4
    usr/lib/libpanel.a
    usr/lib/libncurses++.a
    usr/lib/libncursesw.a
    usr/lib/libncurses.a
    usr/lib/libpanelw.a
    agora o que esta no arquivo ld.so.conf
    /lib
    /usr/lib
    usr/lib/libform.a
    usr/lib/libmenuw.a
    usr/lib/libmenu.a
    usr/lib/libformw.a
    usr/lib/libpanel.a
    usr/lib/libpanelw.a
    /usr/local/lib
    /usr/X11R6/lib
    /usr/i486-slackware-linux/lib
    /usr/lib/gcc-lib
    depois dei o comando ldconfig
    e fui na pasta /usr/src/linux
    e make menuconfig e ......
    root@slacklinux:/usr/src/linux# make menuconfig
    rm -f include/asm
    ( cd include ; ln -sf asm-i386 asm)
    make -C scripts/lxdialog all
    make[1]: Entering directory `/usr/src/linux-2.4.29/scripts/lxdialog'
    /usr/lib/gcc-lib/i486-slackware-linux/3.3.4/../../../../i486-slackware-linux/bin/ld: cannot find -lc
    collect2: ld returned 1 exit status
    >> Unable to find the Ncurses libraries.
    >> You must have Ncurses installed in order
    >> to use 'make menuconfig'
    make[1]: *** [ncurses] Error 1
    make[1]: Leaving directory `/usr/src/linux-2.4.29/scripts/lxdialog'
    make: *** [menuconfig] Error 2
    nesmo erro !!!!
    cara ta virando questao de honra fazer isso funcionar!!!
    pq se nao so formatando .. fica complicado rs
  3. nao para cara, formatar nem pensar!!! isso eh coisa de ruwindows,
    deixa eu te explicar uma coisa qu vc nao entendeu ainda, o ld.so.conf vc coloca os paths das libs, nao o caminho completo (incluindo nome do arquivo).
    voltando ao erro, lembrei de um detalhe, vc tem o ncurses instalado, mas vc tem o ncurses-devel? precisa dele tb
  4. #9
    slackrio
    verifiquei o o slackpkg e nao consta ncurses-devel mais somente ncurses-5 ...
    to correndo atraz deste arquivo ncurses-dev na net e ta dificil de archar ele para slack 10.1
    estranho que eu tenho uma outra maquina na rede que ta com slack full na instalacao e nela roda o make menuconfig na boa sem problemas ..
    so tenho este problema com monto servidores somente modo texto ..
    tyo afim de instalar este pacote para poder usar o cbq pq o meu kernel atual nao da suporte .. e tb e bom para futuras instalacoes no sistema etc ...
    to na luta .. ta brabo !! rss
  5. tenta achar aqui
    www.linuxpackages.net
  1. Make Install dando Erros ............
    Por Jonatanmcc no fórum Sistemas Operacionais
    Respostas: 12
    Último Post: 24-11-2008, 14:15
  2. Tentando instalar o APACHE, mas dando erro no make
    Por DanielM no fórum Servidores de Rede
    Respostas: 7
    Último Post: 24-11-2004, 10:24
  3. Erro ao executar make menuconfig?
    Por Hacinn no fórum Servidores de Rede
    Último Post: 04-05-2004, 08:24
  4. postfix dando erro!!!socorro!!!
    Por Leyzem no fórum Servidores de Rede
    Respostas: 10
    Último Post: 24-03-2003, 13:02
  5. redirecionamento dando erro no comando
    Por wrochal no fórum Servidores de Rede
    Último Post: 21-11-2002, 10:28
