  1. Opa
    Bem, com certeza seu problema não é no Sarg entaum...
    Analize o squid.conf de um dos servidores que administro e funciona normalmente e tire suas conclusões. Segue:
    http_port 3128
    icp_port 0
    #Para proxy transparente
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_single_host off
    httpd_accel_with_proxy on
    cache_mem 128 MB
    maximum_object_size 4096 KB
    cache_dir ufs /var/spool/squid 600 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log none
    emulate_httpd_log on
    connect_timeout 2 minutes
    #Recommended minimum configuration:
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    #ACL PROSERV NET
    acl proserv src 192.168.1.0/255.255.255.0
    http_access deny manager
    http_access deny !Safe_ports
    # Hotmail com anexo ####
    acl hotmail_domains dstdomain .hotmail.msn.com
    acl hotmail_domains2 dst 64.0.0.0/255.0.0.0
    acl hotmail_domains3 dst 65.0.0.0/255.0.0.0
    header_access Accept-Encoding deny hotmail_domains
    header_access Accept-Encoding deny hotmail_domains2
    header_access Accept-Encoding deny hotmail_domains3
    #REGRAS DO USUARIO
    ### ACL´s Usuarios
    acl luiz src 192.168.1.50
    http_access allow luiz
    acl libera dstdomain "/usr/local/squid/etc/libera.txt"
    http_access allow libera all
    acl proibido url_regex "/usr/local/squid/etc/proibido.txt"
    http_access deny proibido all
    acl DOWN url_regex -i "/usr/local/squid/etc/down.txt"
    http_access deny DOWN all
    acl spyware url_regex "/usr/local/squid/etc/spyware.txt"
    http_access deny spyware all
    http_access allow proserv
    http_access deny all
    icp_access allow all
    miss_access allow all
    cache_mgr luiz@proserv.com.br
    cache_effective_user squid
    cache_effective_group squid
    visible_hostname localhost
    store_avg_object_size 13 KB
  2. Finalmente descobri
    Quando deixamos no inicio do squid.conf como:
    http_port 3128
    o squid faz um default para a porta de rede que no meu roteador é 192.168.0.0
    ai quando eu adcionei a porta do meu servidor
    http_port 192.168.0.1:3128
    Ai ele pegou não mais o que estava no roteador e sim quem solicitava o pacote ao servidor
    Apos isso funcionou como uma luva.
    Espero compartilhar essa informação para que colegas não fiquem cansados de procurar.
    Obrigado a todos que me daram uma força para conquistar mais um desafio
    Sandro Roldan
  1. Cliente PPOE pegar sempre o mesmo IP
    Por ronaldoipm no fórum Redes
    Respostas: 8
    Último Post: 23-02-2015, 10:38
  2. Respostas: 1
    Último Post: 03-12-2010, 13:31
  3. Servidor PPPOE entregando sempre o mesmo ip
    Por AndersonMachado no fórum Redes
    Último Post: 14-03-2009, 08:51
  4. Respostas: 7
    Último Post: 22-12-2008, 13:42
  5. DHCP mandando sempre o mesmo IP. Tem como??
    Por lacierdias no fórum Servidores de Rede
    Respostas: 11
    Último Post: 12-06-2005, 08:00
