    Padrão traceroute funciona, mas ping nao funciona
    [font=Courier New]Alguem sabe dizer porque consigo efetuar um traceroute para um endereço, mas nao consigo um ping para o mesmo endereço?
    SERVIDOR A acessando SERVIDOR B:
    traceroute to 192.168.6.2 (192.168.6.2), 30 hops max, 38 byte packets
    1 192.168.1.100 (192.168.1.100) 1.003 ms 0.771 ms 0.763 ms
    2 192.168.3.2 (192.168.3.2) 4.916 ms 11.990 ms 3.982 ms
    3 192.168.6.2 (192.168.6.2) 7.508 ms 14.574 ms 10.460 ms
    ping 192.168.6.2
    PING 192.168.6.2 (192.168.6.2) 56(84) bytes of data.
    Vou colocar abaixo as configurações das maquinas envolvidas:
    SERVIDOR A:
    ifconfig
    eth0 inet end.: 192.168.1.1 Bcast:192.168.1.255 Masc:255.255.255.0
    eth0:2 inet end.: 192.168.6.1 Bcast:192.168.6.255 Masc:255.255.255.0
    tun0 inet end.: 192.168.2.1 P-a-P:192.168.2.2 Masc:255.255.255.255
    route
    Tabela de Roteamento IP do Kernel
    Destino Roteador MáscaraGen. Opções Métrica Ref Uso Iface
    192.168.6.2 192.168.1.100 255.255.255.255 UGH 0 0 0 eth0
    192.168.2.2 * 255.255.255.255 UH 0 0 0 tun0
    192.168.3.0 192.168.1.100 255.255.255.0 UG 0 0 0 eth0
    192.168.1.0 * 255.255.255.0 U 0 0 0 eth0
    192.168.0.0 * 255.255.255.0 U 0 0 0 tun0
    default 192.168.1.101 0.0.0.0 UG 0 0 0 eth0
    WIRELESS A - AP MONOWALL freebsd
    ifconfig
    dc0: inet 192.168.1.100 netmask 0xffffff00 broadcast 192.168.1.255
    wi0: inet 192.168.3.1 netmask 0xffffff00 broadcast 192.168.3.255
    route
    Destination Gateway Flags Refs Use Netif Expire
    default 192.168.1.1 UGSc 1 52 dc0
    127.0.0.1 127.0.0.1 UH 0 0 lo0
    192.168.1 link#2 UC 2 0 dc0
    192.168.1.1 00:11:5b:98:c4:dc UHLW 3 16924 dc0 1168
    192.168.1.100 00:30:21:11:3c:8b UHLW 0 0 lo0
    192.168.3 link#4 UC 2 0 wi0
    192.168.3.1 00:02:6f:3a:96:85 UHLW 0 0 lo0
    192.168.3.2 00:4f:62:06:ed:9f UHLW 3 240998 wi0 1177
    192.168.6.1/32 192.168.1.1 UGSc 1 146737 dc0
    WIRELESS B - OVISLINK 5460 COM FIRMWARE ROTEADOR - CLIENTE DO MONOWALL
    ifconfig
    br0 inet addr:192.168.0.100 Bcast:192.168.0.255 Mask:255.255.255.0
    eth0 Link encap:Ethernet
    eth1 Link encap:Ethernet
    wlan0 inet addr:192.168.3.2 Bcast:192.168.3.255 Mask:255.255.255.0
    Kernel IP routing table
    Destination Gateway Genmask Flags Metric Ref Use Iface
    255.255.255.255 * 255.255.255.255 UH 0 0 0 br0
    192.168.6.2 * 255.255.255.255 UH 0 0 0 br0
    192.168.3.0 * 255.255.255.0 U 0 0 0 wlan0
    192.168.0.0 * 255.255.255.0 U 0 0 0 br0
    default 192.168.3.1 0.0.0.0 UG 0 0 0 wlan0
    SERVIDOR B
    ifconfig
    eth0 inet end.: 192.168.0.1 Bcast:192.168.0.255 Masc:255.255.255.0
    eth0:2 inet end.: 192.168.6.2 Bcast:192.168.6.255 Masc:255.255.255.0
    eth1 inet end.: 200.200.200.200 Bcast:255.255.255.255 Masc:255.255.254.0
    tun0 inet end.: 192.168.2.2 P-a-P:192.168.2.1 Masc:255.255.255.255
    route
    192.168.2.1 * 255.255.255.255 UH 0 0 0 tun0
    192.168.6.1 192.168.0.100 255.255.255.255 UGH 0 0 0 eth0
    192.168.3.0 192.168.0.100 255.255.255.0 UG 0 0 0 eth0
    192.168.1.0 * 255.255.255.0 U 0 0 0 tun0
    192.168.0.0 * 255.255.255.0 U 0 0 0 eth0
    200.200.200.0 * 255.255.254.0 U 0 0 0 eth1
    Obrigado a quem puder me ajudar.
    laercio
    Padrão Re: traceroute funciona, mas ping nao funciona
    laercio,
    Eu tive um problema parecido. Montei toda uma estrutura e do servidor remoto eu não conseguia pingar em lugar alguma a não ser o gateway dele. Quando pingava de outro local para lá ia normalmente. Descobri que era uma troca de MAC entre os servidores e os StarOS que eu estava montando (minha estação remota era em modo AP e a estação da repetidora era em modo CLIENTE). Quando inverti essa situação funcionou perfeitamente.
    Acho que talvez não encaixe nesse seu modelo, mas é uma dica.
    Outra coisa é tentar usar dois hardwares do mesmo fabricante: mesclar as coisas é a mesma situação de comprar um motor de uno mile e querer enfiar dentro de um fiesta... não funciona bem mas pode encaixar.
    Além dessas duas tente colocar ambos os rádios em modo bridge para ver o que acontece.
    Nataniel
    Vou dar mais detalhes para tentar mostrar que deve ser um problema de rota ou iptables no Ovislink 5460:
    SERVIDOR A para SERVIDOR B nao pinga
    WIRELESS B para SERVIDOR B pinga
    WIRELESS B para SERVIDOR A pinga
    SERVIDOR B para SERVIDOR A pinga
    WIRELESS A para SERVIDOR A pinga
    WIRELESS A para SERVIDOR B nao pinga
    Ou sera que o problema esta no WIRELESS A, pois ele tambem nao pinga o SERVIDOR B?
    Mas ai o traceroute tambem nao deveria passar.
    traceroute 192.168.6.2 (origem servidor A).
    1 192.168.1.100 (192.168.1.100) 1.044 ms 0.744 ms 0.701 ms
    2 192.168.3.2 (192.168.3.2) 7.345 ms 4.206 ms 4.905 ms
    3 192.168.6.2 (192.168.6.2) 5.664 ms 8.863 ms 4.989 ms
    Alem disto quando uso tcpdump -i wlan0 no Ovislink aparece o seguinte:
    a) Ping de 192.168.6.1 para 192.168.6.2
    10:55:10.491299 192.168.3.2.5002 > 192.168.6.1.5002: udp 88
    10:55:16.151299 192.168.6.1.8 > 192.168.6.2.0:
    10:55:17.161299 192.168.6.1.8 > 192.168.6.2.0:
    10:55:18.161299 192.168.6.1.8 > 192.168.6.2.0:
    10:55:19.161299 192.168.6.1.8 > 192.168.6.2.0:
    b) ping de 192.168.6.2 para 192.168.6.1
    10:57:55.501299 192.168.3.2.5002 > 192.168.6.1.5002: udp 88
    10:57:56.11299 192.168.3.2.8 > 192.168.6.1.0:
    10:57:56.11299 192.168.6.1.0 > 192.168.3.2.0:
    10:57:57.11299 192.168.3.2.8 > 192.168.6.1.0:
    10:57:57.11299 192.168.6.1.0 > 192.168.3.2.0:
    10:57:58.11299 192.168.3.2.8 > 192.168.6.1.0:
    10:57:58.21299 192.168.6.1.0 > 192.168.3.2.0:
    Desta forma posso demonstrar que tem algum problema entre o OVISLINK 5460 e o SERVIDOR B, pois pelo log acima demonstra que o SERVIDOR B nao responde e alem disto me parece que o OVISLINK esta alterando o endereço no caso b.
    O ovislink esta configurado como CLIENTE ISP e Cliente de Infraestrutura. Se eu configurar o Ovislink como WDS nao poderia resolver???
    Obrigado.
    Laercio
    Só com teus testes de ping já vi que é problema realmente no não repasse de MAC dos APS...
    Veja que do AP em modo CLIENTE para o AP em modo AP você consegue contato (SERVIDOR B para SERVIDOR A). É exatamente o problema que relatei com meu caso aqui do StarOS.
    Padrão Resolvido: traceroute funciona, mas ping nao funciona
    Nataniel
    Nao sei explicar, mas o problema estava realmente no Ovislink 5460, ou seja, acrescentei a regra de firewall "iptables -P FORWARD ACCEPT" e passou a funcionar.
    Todos os ping estao funcionando e desta forma consegui ativar o openvpn por este link.
    Agora ficou a duvida sobre a segurança.
    Estou utilizando uma VPN entre uma conexao sem fio que utiliza WEP, entao pergunto se preciso deixar habilitado o WEP e se tambem seria bom colocar autenticacao radius no cliente ovislink?
    De qualquer forma obrigado.
    laerciok
    laercio,
    Realmente essa regra eu nunca tentei, mas provavelmente ela libera o repasse de MAC entre as estações. Interessante.
    Eu não uso WEP mas no seu caso, se for um PtP com dados restritos, é bom sim que o WEP esteja ativado.
