  1. Realmente dessa forma procurei bastante e não encontrei.
    Abaixo tem um link sobre o delaypools mas seria algo que você poderia tentar. Limitar apenas para 5Mb acredito que num de por você querer um valor de 5Mb mas pode ser que eu esteja errado por não conhecer alguma solução.
    Tente olhar e ver se é válido ou não.
    http://www.vivaolinux.com.br/artigos...php?codigo=439
    Vou continuar olhando esse tópico, interessante a questão
    Falow
  2. Com certeza, é um controle muito interessante.
    Vou pesquisar aqui tb sobre o assunto.
    Um abraço!
  3. Olha o que eu encontrei:
    Código :
    # TAG: reply_body_max_size   bytes allow|deny acl acl...
    #    This option specifies the maximum size of a reply body in bytes.
    #    It can be used to prevent users from downloading very large files,
    #    such as MP3's and movies. When the reply headers are recieved,
    #    the reply_body_max_size lines are processed, and the first line with
    #    a result of "allow" is used as the maximum body size for this reply.
    #    This size is then checked twice. First when we get the reply headers,
    #    we check the content-length value. If the content length value exists
    #    and is larger than the allowed size, the request is denied and the
    #    user receives an error message that says "the request or reply
    #    is too large." If there is no content-length, and the reply
    #    size exceeds this limit, the client's connection is just closed
    #    and they will receive a partial reply.
    #    WARNING: downstream caches probably can not detect a partial reply
    #    if there is no content-length header, so they will cache
    #    partial responses and give them out as hits. You should NOT
    #    use this option if you have downstream caches.
    #    WARNING: A maximum size larger than the size of squid's error messages
    #    will cause an infinite loop and crash squid. Ensure that the smallest
    #    non-zero value you use is greater that the maximum header size plus
    #    the size of your largest error page.
    #    If you set this parameter to zero (the default), there will be
    #    no limit imposed.
    #Default:
    # reply_body_max_size 0 allow all
    Proxy transparente:
    reply_body_max_size 5242880 allow src 192.168.0.1
    reply_body_max_size 10485760 allow src 192.168.0.2
    reply_body_max_size 5242880 allow all
    Downloads de até 5 MB para o ip 192.168.0.1 e 10 MB para o IP 192.168.0.2.
    O restante faz downloads de até 5 MB.
    Proxy autenticado:
    reply_body_max_size 5242880 allow proxy_auth fulano
    reply_body_max_size 10485760 allow proxy_auth ciclano
    Downloads de até 5 MB para o usuário fulano e 10 MB para o ciclano.
    Problema resolvido?
  4. Nossa show de bola neto.
    Isso ta na documentação do squid .
    Valeu ai,
  5. #10
    rafaelmontek
    Muito Obrigado mesmo gente !!! Nem sei como agradecer... Sei que sempre poderia contar com vcs... mas uma ajuda da comunidade... Possam ter certeza que poderão contar sempre comigo.
    Abraços...
  1. Limitar Download de Arquivos
    Por xadouron no fórum Servidores de Rede
    Último Post: 17-01-2008, 16:20
  2. Como limitar downloads
    Por tomega no fórum Redes
    Último Post: 07-03-2007, 17:22
  3. Limitar Download
    Por vcasali no fórum Servidores de Rede
    Último Post: 02-09-2006, 23:57
  4. Delay pool - limitar download
    Por cvr no fórum Servidores de Rede
    Último Post: 22-08-2006, 23:03
  5. limitar download tamanho do arquivo
    Por tes454 no fórum Servidores de Rede
    Último Post: 17-06-2005, 02:49
