    RAFA_RP
    Padrão Re: Cyclades PR1000IP X BLF Embratel
    OLHA A CONF. Q FIZ NO ROUTER
    Encapsulation Ethernet
    MAC address 00:60:2E:10:1E:5D
    Fast Ethernet Automatic Negotiation
    IP protocol active
    Interface Numbered
    Primary IP address 200.213.134.2
    Subnet mask 255.255.255.192
    IP MTU 1500
    IP Fragmentation bit DF - accept
    NAT - Address Scope Local
    ICMP Port inactive
    Incoming Filter List None
    Detailed Incoming IP Accounting Process inactive
    Outgoing Filter List None
    Detailed Outgoing IP Accounting Process inactive
    Routing of Broadcast Messages inactive
    Interface Transparent Bridge Inactive
    Proxy ARP inactive
    Time interval in seconds to refresh ARP table: 30
    IP Bridge inactive
    Bandwidth 0
    IP Traffic Control List None
    SNMP interface :
    Interface UP/Down TRAP Disable
    Cyclades-PR1000 (PR1000) Fast Ethernet Interface Menu
    Cyclades-PR1000 (PR1000) Slot 1 (SWAN) Encapsulation Menu
    1. Frame Relay 2. PPP 3. X.25
    4. HDLC 5. Inactive
    Select option ==> 1
    Encapsulation Type ( (R)FC1490 - IETF or (C)isco ) [R] : R
    SNAP IP ( (A)ctive or (I)nactive ) [I] : I
    LMI ( (A)NSI, (G)roup of 4, (Q)933a or (N)one ) [A] : A
    Enable alternative DLCI routing for this link (Y/N) [N] : N
    T391 in seconds [10] : 10
    N391 (1 to 255) [6] : 6
    N392 (1 to 10) [3] : 3
    N393 (1 to 10) [4] : 4
    Bandwidth Reservation ( (A)ctive or (I)nactive ) [I] : I
    FRF-12 - Fragment Size (0-no fragment, 40-1600) [0] : 0
    Cyclades-PR1000 (PR1000) Frame Relay Map options Menu
    1. Add DLCI 2. Delete DLCI 3. Edit DLCI
    (L for list) Select option ==> 1
    DLCI number (16 to 991) [16] : 100
    Frame Relay address map ( (S)tatic or (I)nverse ARP enable ) [S] : S
    Remote IP address [192.168.161.2] : 200.250.159.113
    DLCI state controls link status (Y/N) [N] : N
    CIR (1 to 100%) [100] : 100
    Enable Predictor Compression (Y/N) [N] : N
    Cyclades-PR1000 (PR1000) Static Routes Menu
    1. Add Route 2. Delete Route 3. Edit Route
    4. Clear Static Routes
    Destination IP address [192.168.161.0] : 0.0.0.0
    Gateway or Interface (G/I) [G] : G
    Gateway IP address [192.168.161.2] : 200.250.159.113
    Metric (1 to 15) [1] : 1
    Is this a backup route ? (Y/N) [N] : n
    May this route be replaced by a RIP route ? (Y/N) [N] :
    DUVIDAS QUAL FINALIDADE DESTE IP
    Endereco das portas seriais dos roteadores
    IP CLIENTE : 200.250.159.114 255.255.255.252
    DUVIDA CRUCIAL
    NAT - Address Scope Local???
    eSCOLHI OPCAO CERTA PQ ATUALMENTE NA MINHA REDE QUEM FAZ NAT É MEU FIREWALL COM OUTRO ROTEADOR ( Q VOU TROCAR PELO CYCLADES)
    WAN -> ROUTER -> ETH0 200.213.134.2 FIREWALL ETH1 192.168.0.1 -> REDE
    VLW!
  2. #8
    FUCAPE
    RAFA,
    Veja se consigo te ajudar:
    Este IP é a porta de entrada de sua rede para a Embratel.
    >> DUVIDA CRUCIAL
    >> eSCOLHI OPCAO CERTA PQ ATUALMENTE NA MINHA REDE QUEM FAZ NAT É MEU FIREWALL >>COM OUTRO ROTEADOR ( Q VOU TROCAR PELO CYCLADES) WAN -> ROUTER -> ETH0 200.213.134.2 FIREWALL ETH1 192.168.0.1 -> REDE
    Não entendi muito bem a questão, mas basicamente penso que é o seguinte, corrijam-me se tiver errado: NAT - Address Scope Local = faixa de ip privados que vc usará em sua rede local.
    Como vc estará usando um firewall, então não existe esta necessidade. Desabilite o NAT.
    Pelo que entendi até agora, acredito ser esta a sua configuração:
    http://skafe.sites.uol.com.br/projetos/dmz.jpg
    Então é só dar uma olhada em:
    http://www.cyclades.com.br/support/faqs.php?id=594
    Espero ter ajudado.
    Um abraço
  3. #9
    RAFA_RP
    FUCAPE
    Onde utilizo este ip >>IP CLIENTE : 200.250.159.114 255.255.255.252?
    Minha rede é parecida com essa so q do roteador ligo direto no firewall
    Me falara q eu preciso criar um regra de nat e desviar ela para eth1 192.168.0.1 do meu firewall
    Ajudou e mto
    vlw
    Fucape
    []'s
  4. #10
    FUCAPE
    Na verdade, é isto mesmo, o Hub/switch, que ele chama de DMZ, ali é apenas figuração para ligar máquinas com IP´s Válidos. Em nosso caso, pois utilizo o meu assim tb, ligo o router no firewall com um cabo cross.
    Sucesso em seu empreendimento!
    []'s
  5. #11
    RAFA_RP
    FIZ A CONFIGURACAO MAS NAO DEU CERTO MEU FIREWALL NAO SOBE PLACA DE REDE CONECTADA NO ROUTER, NO PRINT DO ROUTER MINHA CONF ESTA ASSIM:
    1. Fast Ethernet 2. Slot 1 (SWAN)
    Select option ==> 2
    Channel 1
    Encapsulation Frame Relay
    IP protocol active
    Interface Numbered
    Primary IP address 192.168.162.1
    Subnet mask 255.255.255.0
    IP MTU 1500
    NAT - Address Scope Global
    ICMP Port inactive
    Sync mode
    External Clock Source
    Don't invert clock phase for transmission
    Interface V.35
    Bandwidth 0
    Encapsulation Type RFC1490 - IETF
    SNAP IP inactive
    LMI type Group of 4
    Alternative DLCI routing disabled for this link
    T391 in seconds 10
    N391 6
    N392 3
    N393 4
    FRF-12 - without fragmentation
    Number of DLCI's 1
    Frame Relay MAP
    # DLCI Remote IP addr Local IP addr CIR Pred Ctrl
    01 100 200.250.159.113 100 Dis None
    DLCI Traffic Control inactive
    SNMP interface :
    IP Static Routes
    Destination Subnet Mask Gateway/Interf Metric/Bkp/RIP OSPF/ExType
    Default Gateway 200.250.159.113 1 no no no
