    gentoo_unisis
    Padrão problemas ao startar o ldap
    depois de instalar o ldap e tentar startar o serviço com o comando ./slapd start
    aparece a seguinte mensagem:
    * Starting ldap-server ... [ !! ]
    sendo que no log messages aparece o seguinte erro:
    Aug 23 19:19:57 zeus slapd[11109]: No passwd entry for user ldap
    o meu arquivo slapd.conf esta da seguinte forma:
    # See slapd.conf(5) for details on configuration options.
    # This file should NOT be world readable.
    include /etc/openldap/schema/core.schema
    # Define SSL and TLS properties (optional)
    #TLSCertificateFile /etc/ssl/ldap.pem
    #TLSCertificateKeyFile /etc/openldap/ssl/ldap.pem
    #TLSCACertificateFile /etc/ssl/ldap.pem
    # Define global ACLs to disable default read access.
    # Do not enable referrals until AFTER you have a working directory
    # service AND an understanding of referrals.
    #referral ldap://root.openldap.org
    pidfile /var/run/openldap/slapd.pid
    argsfile /var/run/openldap/slapd.args
    # Load dynamic backend modules:
    # modulepath /usr/lib/openldap/openldap
    # moduleload back_bdb.la
    # moduleload back_ldap.la
    # moduleload back_ldbm.la
    # moduleload back_passwd.la
    # moduleload back_shell.la
    # Sample security restrictions
    # Require integrity protection (prevent hijacking)
    # Require 112-bit (3DES or better) encryption for updates
    # Require 63-bit encryption for simple bind
    # security ssf=1 update_ssf=112 simple_bind=64
    # Sample access control policy:
    i# Root DSE: allow anyone to read it
    # Subschema (sub)entry DSE: allow anyone to read it
    # Other DSEs:
    # Allow self write access
    # Allow authenticated users read access
    # Allow anonymous users to authenticate
    # Directives needed to implement policy:
    # access to dn.base="" by * read
    # access to dn.base="cn=Subschema" by * read
    access to attrs=userPassword
    by dn="cn=manager,o=unisis,c=br" write
    by self write
    by anonymous auth
    by * none
    # Full rights to the admin
    access to *
    by * read
    # if no access controls are present, the default policy
    # allows anyone and everyone to read anything but restricts
    # updates to rootdn. (e.g., "access to * by * read")
    # rootdn can always read and write EVERYTHING!
    # BDB database definitions
    database bdb
    suffix "dc=unisis,dc=br"
    rootdn "cn=Manager,dc=unisis,dc=br"
    # Cleartext passwords, especially for the rootdn, should
    # be avoid. See slappasswd(8) and slapd.conf(5) for details.
    # Use of strong authentication encouraged.
    #rootpw secret
    rootpw {MD5}vIkT22XHZaojkRfrr2t5Fw==
    # The database directory MUST exist prior to running slapd AND
    # should only be accessible by the slapd and slap tools.
    # Mode 700 recommended.
    directory /var/lib/openldap-data
    # Indices to maintain
    index objectClass eq
    e o arquivo ldap.conf esta assim:
    # LDAP Defaults
    # See ldap.conf(5) for details
    # This file should be world readable but not world writable.
    BASE dc=unisis, dc=br
    URI ldap://zeus.ldap.unisis.br:636/
    TLS_REQCERT allow
    Ja estou alguns dias tentando configurar o ldap e não saiu do lugar, uso o gentoo no servidor.
    se alguem puder me ajudar, agradeço muito...
    Falow
    Padrão Re: problemas ao startar o ldap
    Olá amigo,
    Tente comentar estas linhas e veja se consegue startar.
    by self write
    by anonymous auth
    by * none
    access to *
    by * read
    TLS_REQCERT allow
    Se funcionar, vá descomentando as poucos e veja se esta relacionado a algumas destas configurações.
    Valeu.
    gentoo_unisis
    então mesmo assim não subiu... o serviço...
    continua dando a mesma mensagem...
    !!!!!!! :mrgreen:
    Olá,
    Ele esta reclamando que não definida a senha do usuario do ldap, verifique isso.
    Abraços...
    Citação Postado originalmente por gentoo_unisis
    !!!!!!! :mrgreen:
    gentoo_unisis
    onde defino a senha?
    pois ja coloquei ela criptografada no arquio slap.conf.
    Tenho que definir um usuario ou deixar manager?
    Olá,
    Voce pode colocar o usuario que voce quiser e logo após use novamente o comando:
    #slappasswd
    New password:
    Re-enter new password:
    {SSHA}IMzCFI4FW4O6gpe0JVm3/+V/rDMmrjj1
    Copie a senha e coloque no lugar da que esta agora..
    Qualquer coisa posta ai..
    Abraços..
    gentoo_unisis
    coloquei o usuario como vc falou e ele startou, sendo que adora tentei executar o comando abaixo e ele me deu a seguinte mensagem....
    digitei a senha que eu tinha cadastrado.
    ldapadd -D "cn=root,dc=unisis,dc=br" -W -f /tmp/base.ldif
    Enter LDAP Password:
    ldap_bind: Can't contact LDAP server (-1)
