  1. vc pega a lib no site do gnu !! instala ela...
    ai quando for compilar o squid... ele ja reconhece que vc tem a gnumalloc.. e usa ela !!
  2. certo mais tipo ela é uma lib stard certo? outros aplicativos nao vao usar ela amenos que tenham suporte e ela nao vai sobrepor nada eh isso?
  3. meu medo e ferrar tudo
    [wireless@/var/tmp]cat README
    This is the standalone distribution of GNU malloc.
    GNU malloc is part of the GNU C Library, but is also distributed separately.
    If you find bugs in GNU malloc, send reports to bug-glibc@prep.ai.mit.edu.
    GNU malloc is free software. See the file COPYING.LIB for copying conditions.
    The makefile builds libmalloc.a and gmalloc.o. If you are using GNU malloc
    to replace your system's existing malloc package, it is important to make
    sure you get all GNU functions, not some of the GNU functions and some from
    the system library. gmalloc.o has all the functions in one file, so using
    that will make sure you don't accidentally mix the two malloc packages.
  4. eu instalei aqui.. nao substituiu nada.. nem atrapalhou nada nos servidores proxy
  5. meu guro alexandre.. kra eu recompilei o squid tava com o 2.5 agora tá com o 2.6 eu vi que na hora da compilaçao deu tudo certo mais agora nao tah funcionando o diskd
    olha oque acontece quando do um squid -z
    wireless:/usr/local/squid/sbin# ./squid -z
    FATAL: Bungled squid.conf line 42: cache_dir diskd /etc/squid/cache/cache1 10096 16 256 Q1=64 Q2=72
    Squid Cache (Version 2.6.STABLE3): Terminated abnormally.
    Locate diskd
    wireless:/usr/local/squid/sbin# locate diskd
    /etc/squid/squid-2.6.STABLE3/src/fs/diskd
    /etc/squid/squid-2.6.STABLE3/src/fs/diskd/.deps
    /etc/squid/squid-2.6.STABLE3/src/fs/diskd/.deps/diskd.Po
    /etc/squid/squid-2.6.STABLE3/src/fs/diskd/.deps/store_dir_diskd.Po
    /etc/squid/squid-2.6.STABLE3/src/fs/diskd/.deps/store_io_diskd.Po
    /etc/squid/squid-2.6.STABLE3/src/fs/diskd/diskd.c
    /etc/squid/squid-2.6.STABLE3/src/fs/diskd/store_dir_diskd.c
    /etc/squid/squid-2.6.STABLE3/src/fs/diskd/store_diskd.h
    /etc/squid/squid-2.6.STABLE3/src/fs/diskd/store_io_diskd.c
    /usr/bin/diskd
    /usr/share/man/man1/diskd.1.gz
    meus parametros no squid
    #binario do diskd
    #diskd_program /usr/lib/squid/diskd (não tem mais era do squid velho)
    diskd_program /usr/bin/diskd
  1. Respostas: 6
    Último Post: 20-07-2011, 10:58
  2. Copiar arquivos pra dentro da iso !
    Por deivisonmoraes no fórum Sistemas Operacionais
    Último Post: 14-06-2011, 06:22
  3. squid - configuracao com dois parent cache
    Por brito_b no fórum Servidores de Rede
    Último Post: 07-07-2005, 11:14
  4. Squid não controla tamanho do Cache...
    Por lacierdias no fórum Servidores de Rede
    Último Post: 01-01-2005, 08:44
  5. Configurar o Squid para não gerar o cache
    Por webluc no fórum Servidores de Rede
    Último Post: 08-10-2003, 16:51
