    Padrão Squid não inicia
    Ola
    A empresa em que trabalho tem um servidor rodando o mandriva 2006. Acontece que quando coloquei politicas de acesso a site dentro do squid e tentei iniciar o mesmo usando o comando:
    service squid restart [FALHOU]
    Então tentei usar:
    /etc/rc.d/init.d/squid start [FALHOU]
    O que fazer para que o squid volte a funcionar? ja pesquisei algum problema igual ao meu mas não econtrei nada.
    Abaixo segue o arquivo squid.conf:
    http_port 3128
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    cache_dir diskd /var/spool/squid 100 16 256
    cache_store_log none
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    refresh_pattern . 0 20% 4320
    half_closed_clients off
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    acl sitetaua url_regex -i Prefeitura Municipal de Tauá
    no_cache deny sitetaua
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny to_localhost
    acl mynetwork src 192.168.0.0/255.255.255.0
    http_access allow mynetwork
    http_access allow localhost
    http_reply_access allow all
    icp_access allow all
    visible_hostname [email protected]
    httpd_accel_host virtual
    httpd_accel_with_proxy on
    append_domain .cidadedigital.com.br
    err_html_text [email protected]
    deny_info ERR_CUSTOM_ACCESS_DENIED all
    memory_pools off
    coredump_dir /var/spool/squid
    ie_refresh on
    Agradecido
    verifica no /var/log/squid/cache.log
    o que o squid esta acusando de errado !!
    esses são os erros:
    2006/11/21 00:48:27| Preparing for shutdown after 8577 requests
    2006/11/21 00:48:27| Waiting 30 seconds for active connections to finish
    2006/11/21 00:48:27| FD 11 Closing HTTP connection
    2006/11/21 00:48:27| Shutting down...
    2006/11/21 00:48:27| FD 13 Closing ICP connection
    2006/11/21 00:48:27| FD 14 Closing HTCP socket
    2006/11/21 00:48:27| FD 15 Closing SNMP socket
    2006/11/21 00:48:27| Closing unlinkd pipe on FD 10
    2006/11/21 00:48:27| storeDirWriteCleanLogs: Starting...
    2006/11/21 00:48:27| Finished. Wrote 28899 entries.
    2006/11/21 00:48:27| Took 0.0 seconds (1913080.9 entries/sec).
    CPU Usage: 13.459 seconds = 6.401 user + 7.058 sys
    Maximum Resident Size: 0 KB
    Page faults with physical i/o: 2
    Memory usage for squid via mallinfo():
    total space in arena: 15068 KB
    Ordinary blocks: 14901 KB 232 blks
    Small blocks: 0 KB 9 blks
    Holding blocks: 208 KB 1 blks
    Free Small blocks: 0 KB
    Free Ordinary blocks: 166 KB
    Total in use: 15109 KB 100%
    Total free: 166 KB 1%
    2006/11/21 00:48:27| Open FD 12 squid -> diskd
    2006/11/21 00:48:27| Squid Cache (Version 2.5.STABLE10): Exiting normally.
    2006/11/21 07:11:47| Starting Squid Cache version 2.5.STABLE10 for i586-mandriva-linux-gnu...
    2006/11/21 07:11:47| Process ID 5817
    2006/11/21 07:11:47| With 1024 file descriptors available
    2006/11/21 07:11:47| DNS Socket created at 0.0.0.0, port 32771, FD 5
    2006/11/21 07:11:47| Adding nameserver 172.30.0.1 from /etc/resolv.conf
    2006/11/21 07:11:47| User-Agent logging is disabled.
    2006/11/21 07:11:47| Referer logging is disabled.
    2006/11/21 07:11:47| Unlinkd pipe opened on FD 10
    2006/11/21 07:11:47| Swap maxSize 307200 KB, estimated 23630 objects
    2006/11/21 07:11:47| Target number of buckets: 1181
    2006/11/21 07:11:47| Using 8192 Store buckets
    2006/11/21 07:11:47| Max Mem size: 8192 KB
    2006/11/21 07:11:47| Max Swap size: 307200 KB
    2006/11/21 07:11:47| Store logging disabled
    2006/11/21 07:11:47| Rebuilding storage in /var/spool/squid (CLEAN)
    2006/11/21 07:11:47| Using Least Load store dir selection
    2006/11/21 07:11:47| Set Current Directory to /var/spool/squid
    2006/11/21 07:11:47| Loaded Icons.
    2006/11/21 07:11:48| Accepting HTTP connections at 0.0.0.0, port 3128, FD 11.
    2006/11/21 07:11:48| Accepting ICP messages at 0.0.0.0, port 3130, FD 13.
    2006/11/21 07:11:48| Accepting HTCP messages on port 4827, FD 14.
    2006/11/21 07:11:48| Accepting SNMP messages on port 3401, FD 15.
    2006/11/21 07:11:48| WCCP Disabled.
    2006/11/21 07:11:48| Ready to serve requests.
    2006/11/21 07:11:50| Store rebuilding is 14.2% complete
    2006/11/21 07:11:57| Done reading /var/spool/squid swaplog (28899 entries)
    2006/11/21 07:11:57| Finished rebuilding storage from disk.
    2006/11/21 07:11:57| 28899 Entries scanned
    2006/11/21 07:11:57| 0 Invalid entries.
    2006/11/21 07:11:57| 0 With invalid flags.
    2006/11/21 07:11:57| 28899 Objects loaded.
    2006/11/21 07:11:57| 0 Objects expired.
    2006/11/21 07:11:57| 0 Objects cancelled.
    2006/11/21 07:11:57| 0 Duplicate URLs purged.
    2006/11/21 07:11:57| 0 Swapfile clashes avoided.
    2006/11/21 07:11:57| Took 10.0 seconds (2877.7 objects/sec).
    2006/11/21 07:11:57| Beginning Validation Procedure
    2006/11/21 07:11:57| Completed Validation Procedure
    2006/11/21 07:11:57| Validated 28899 Entries
    2006/11/21 07:11:57| store_swap_size = 276476k
    2006/11/21 07:11:57| storeLateRelease: released 0 objects
    2006/11/21 08:03:01| WARNING: failed to unpack meta data
    2006/11/21 08:05:01| WARNING: failed to unpack meta data
    2006/11/21 08:08:43| WARNING: failed to unpack meta data
    2006/11/21 08:46:43| WARNING: failed to unpack meta data
    2006/11/21 08:46:46| WARNING: failed to unpack meta data
    2006/11/21 08:46:47| WARNING: failed to unpack meta data
    2006/11/21 08:46:49| WARNING: failed to unpack meta data
    2006/11/21 08:46:52| WARNING: failed to unpack meta data
    2006/11/21 08:49:54| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 08:49:58| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 08:50:16| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 08:50:18| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 08:50:21| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 08:50:44| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 08:51:26| httpReadReply: Excess data from "GET http://shopping.busca.uol.com.br/favicon.ico"
    2006/11/21 10:06:39| httpReadReply: Excess data from "GET http://www.cbox.ws/box/jsv4_1.php?r=1"
    2006/11/21 10:07:39| httpReadReply: Excess data from "GET http://www.cbox.ws/box/jsv4_1.php?r=1"
    2006/11/21 10:18:40| WARNING: failed to unpack meta data
    2006/11/21 10:37:56| httpReadReply: Excess data from "POST http://www.crackdb.org/x.php"
    2006/11/21 19:23:40| httpReadReply: Excess data from "GET http://c.goclick.com/r?X=uEvgptEUnt2SjEFeptASmTATjENxsuq9mT2XjFeRpteRnDqRnd2Wota6nTIYmda6ot2RmCzfwfq9mcztsuq9mtuGue9tptaGuVa9mwiSytnCytrEnwfLjFvdptaOmtu"
    2006/11/21 19:28:46| httpReadReply: Excess data from "GET http://c.goclick.com/r?X=uEvgptEUnt2SjEFeptASmTATjENxsuq9mT2XjFeRpteRnDqRnd2Zode6mtm6odiToD2XnCzfwfq9mcztsuq9mtuGue9tptaGuVa9mwiSytnCytrEnwfLjFvdptaOmtu"
    2006/11/21 20:27:46| httpReadReply: Excess data from "GET http://prima.certifica.com/cert/hit.dll?sitio_id=200062&path=Proprio/Homepages/usuarios/fabriciofa.ubbihp.com.br&referer=http%3A//www.aonde.com/clique/clique.php%3Farquivo%3Dsexo/50066.htm%26id_site%3D44457%26url%3Dhttp%3A//www.fabriciofa.ubbihp.com.br&size=1024&colors=24&java=false&descr=Paginas%20de%20usuarios"
    2006/11/21 21:11:13| parseHttpRequest: Unsupported method 'recipientid=99&sessionid=5189
    2006/11/21 21:11:13| clientReadRequest: FD 48 Invalid Request
    2006/11/21 21:11:13| clientReadRequest: FD 54 Invalid Request
    2006/11/21 21:56:46| httpReadReply: Excess data from "GET http://www.br.inter.net/bannermanager/adimage.php?filename=fidelidade.gif&contenttype=gif"
    2006/11/21 21:57:42| httpReadReply: Excess data from "GET http://www.br.inter.net/bannermanager/adimage.php?filename=fidelidade.gif&contenttype=gif"
    2006/11/21 21:58:40| httpReadReply: Excess data from "GET http://www.br.inter.net/bannermanager/adimage.php?filename=fidelidade.gif&contenttype=gif"
    2006/11/21 21:59:54| httpReadReply: Excess data from "GET http://www.br.inter.net/bannermanager/adimage.php?filename=fidelidade.gif&contenttype=gif"
    2006/11/21 22:01:15| httpReadReply: Excess data from "GET http://www.br.inter.net/bannermanager/adimage.php?filename=fidelidade.gif&contenttype=gif"
    2006/11/22 00:43:55| Preparing for shutdown after 124024 requests
    2006/11/22 00:43:55| Waiting 30 seconds for active connections to finish
    2006/11/22 00:43:55| FD 11 Closing HTTP connection
    Geralmente isso acontece quando o cache está zoado. Tente zerá-lo deletando as pastas de dentro de /var/spool/squid (Pode estar em outra localização) e recriando o cache com squid -z.
    Outra: evite utilizar o tipo aufs de cache, optando ou por diskd ou por ufs.
    Abraços!
    Última edição por xstefanox; 22-11-2006 às 13:50.
    Thumbs up
    B0a n0ite car0 Xstafan0x. Iss0 ac0nteceu c0mig0 na semana passada.
    Tive que entrar na pasta d0 cache e deletar tud0. Recriei c0m squid -z e v0lt0u tud0 a0 n0rmal.
    Valeus ................
    Citação Postado originalmente por pssgyn Ver Post
    Opa, tá com problema no "o"? AHeuhaeuhae.
    Isso já aconteceu uma vez comigo só. Foi assim que eu resolvi.
    Thumbs up
    É caro Xstefanox, realmente o meu teclado estava com problemas. Mas como não tinha como trocá-lo, o jeito foi ser criativo.
    Pelo menos acho que consegui passar a minha mensagem.
    Mas agora tudo está normal. Adquiri outro teclado .... hehehehehehe
    Um grande abraço caro amigo .....
