    Padrão problema com proxy cache
    ola pessoal, olha só quando inicio o proxy esta tudo ok, mas se for somente poucos usuarios quando libero pra rede para não consigo enteder o por que...
    olha a partiçao do cache...
    Sist. Arq. Tam Usad Disp Uso% Montado em
    /dev/hda9 37G 12G 24G 34% /var/spool/squid
    parece qeu esta tudo ok mas funciona antes estava chegando a 3,9 giga depois de estudar muito agora chegou a 12G, pelo menos ele não para agora, antes chegava a 3,9 e parava o serviço agora não para mas tambem não funciona....
    Desde ja agradeço...
    Nov 30 10:40:23 contatonet squid[32097]: Starting Squid Cache version 2.5.STABLE9 for i386-debian-linux-gnu...
    Nov 30 10:40:23 contatonet squid[32097]: Process ID 32097
    Nov 30 10:40:23 contatonet squid[32097]: With 1024 file descriptors available
    Nov 30 10:40:23 contatonet squid[32097]: DNS Socket created at 0.0.0.0, port 33901, FD 5
    Nov 30 10:40:23 contatonet squid[32097]: Adding nameserver 192.168.30.1 from squid.conf
    Nov 30 10:40:23 contatonet squid[32097]: Adding nameserver 201.10.1.2 from squid.conf
    Nov 30 10:40:23 contatonet squid[32097]: Adding nameserver 201.10.128.2 from squid.conf
    Nov 30 10:40:23 contatonet squid[32097]: Adding nameserver 201.10.120.2 from squid.conf
    Nov 30 10:40:23 contatonet squid[32097]: User-Agent logging is disabled.
    Nov 30 10:40:23 contatonet squid[32097]: Referer logging is disabled.
    Nov 30 10:40:23 contatonet squid[32097]: Unlinkd pipe opened on FD 10
    Nov 30 10:40:23 contatonet squid[32097]: Swap maxSize 36462592 KB, estimated 2804814 objects
    Nov 30 10:40:23 contatonet squid[32097]: Target number of buckets: 140240
    Nov 30 10:40:23 contatonet squid[32097]: Using 262144 Store buckets
    Nov 30 10:40:23 contatonet squid[32097]: Max Mem size: 131072 KB
    Nov 30 10:40:23 contatonet squid[32097]: Max Swap size: 36462592 KB
    Nov 30 10:40:23 contatonet squid[32097]: Local cache digest enabled; rebuild/rewrite every 3600/3600 sec
    Nov 30 10:40:23 contatonet squid[32097]: Rebuilding storage in /var/spool/squid (DIRTY)
    Nov 30 10:40:23 contatonet squid[32097]: Using Least Load store dir selection
    Nov 30 10:40:23 contatonet squid[32097]: Set Current Directory to /var/spool/squid
    Nov 30 10:40:23 contatonet squid[32097]: Loaded Icons.
    Nov 30 10:40:23 contatonet squid[32097]: Accepting HTTP connections at 192.168.30.1, port 3128, FD 12.
    Nov 30 10:40:23 contatonet squid[32097]: Accepting ICP messages at 0.0.0.0, port 3130, FD 13.
    Nov 30 10:40:23 contatonet squid[32097]: HTCP Disabled.
    Nov 30 10:40:23 contatonet squid[32097]: WCCP Disabled.
    Nov 30 10:40:23 contatonet squid[32097]: Ready to serve requests.
    Nov 30 10:40:23 contatonet squid[32097]: Store rebuilding is 0.7% complete
    caramba...
    as vezes a falta de uma simples "," (virgula) deixa o texto confuso pacarai...
    vamo lá...
    o que deu a entender é que seu squid funcionava e quando o cache chegava a 3.9gb ele parava o serviço, aí você conseguiu resolver isso e ele passa dos 3.9gb, mas agora não funciona...
    é isso?
    coloca seu squid.conf pra darmos uma olhada...
    é quase isso agora ele passou blz mas quando chegou a 34% da partição o serviço não para mas ele não manda internet pra rede toda ai tiro a transparência e configuro minha maquina manualmente ele esta funcionando... libero ele pra rede... ele navega uns 20 segundos e para novamente mas o serviço não para como antes... nunca consegui fazer ele funcionar aqui uso Debian 3.1r2, kernel 2.6.8-2-386...
    http_port 192.168.30.1:3128
    cache_effective_user proxy
    cache_effective_group proxy
    cache_dir ufs /var/spool/squid 35608 32 512
    cache_access_log /home/sistema/access.log
    cache_log /home/sistema/cache.log
    cache_store_log /home/sistema/store.log
    cache_mgr [email protected]
    #logfile_rotate 10
    #Evita configurar o DNS manualmente nos clientes.
    dns_nameservers 192.168.30.1
    dns_nameservers 201.10.1.2
    dns_nameservers 201.10.128.2
    dns_nameservers 201.10.120.2
    cache_mem 128 MB
    cache_swap_low 90
    cache_swap_high 95
    maximum_object_size 512 MB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 1024 KB
    ipcache_size 2048
    ipcache_low 90
    ipcache_high 95
    fqdncache_size 2048
    visible_hostname contatoinfo.com.br
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    #auth_param basic children 5
    #auth_param basic realm Squid proxy-caching web server
    #auth_param basic credentialsttl 2 hours
    refresh_pattern . 0 20% 4320
    half_closed_clients off
    #redirect_program /etc/squid/bannerfilter/redirector.pl
    acl all src 0.0.0.0/0.0.0.0
    #acl redelocal src 192.168.30.0/255.255.255.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80
    acl Safe_ports port 21
    acl Safe_ports port 443 563
    acl Safe_ports port 70
    acl Safe_ports port 210
    acl Safe_ports port 1025-65535
    acl Safe_ports port 280
    acl Safe_ports port 488
    acl Safe_ports port 591
    acl Safe_ports port 777
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny to_localhost
    acl mynetwork src 192.168.30.0/255.255.255.0
    http_access allow mynetwork
    http_access allow localhost
    http_reply_access allow all
    icp_access allow all
    httpd_accel_host virtual
    httpd_accel_with_proxy on
    append_domain .contatoinfo.com.br
    err_html_text [email protected]
    #deny_info ERR_CUSTOM_ACCESS_DENIED all
    memory_pools off
    coredump_dir /var/spool/squid
    ie_refresh on
    como está a integridade de seu HD ... ?
    verifiquei tmb que fez um cache de ~ 35 GB ...
    tenta partir ele em alguns caches menores ...
    eu particularmente não uso mais que 3 Gb
    cache_dir ufs /squid/var/cache/cache1 3000 16 256
    cache_dir ufs /squid/var/cache/cache2 3000 16 256
    cache_dir ufs /squid/var/cache/cache3 3000 16 256
    cache_dir ufs /squid/var/cache/cache4 3000 16 256
    Só mudei o diretório pois uso outro HD só pra o Cache ...
    Falow ...
    cara..
    com relação ao tamanho do cache eu não tive problema ainda...
    tenho um servidor rodando com um HD ATA 133, e o cache está setado para usar 80GB, até agora está com 25GB...
    valeu
    Blz... então a configuração não tem nada de errado???
