    Padrão Interface V.35
    Pessoal,
    Alguem conhece alguma placa pci que tenha uma interface v.35 e que tambem seja compativel com o mikrotik, pois quero substituir o meu roteador por um mikrotik.
    Synchronous Serial
    Packages required: synchronous
    Description
    Moxa C101 ISA and PCI V.35 (4 Mbit/s)
    Moxa C502 PCI 2-port V.35 (8 Mbit/s)
    Cyclades PCI PC-300 V.35 (5 Mbit/s)
    Cyclades PCI PC-300 E1/T1
    FarSync PCI V.35/X.21 (8.448 Mbit/s)
    LMC/SBEI wanPCI-1T1E1 PCI T1/E1 (also known as DS1 or LMC1200P, 1.544 Mbit/s or 2.048 Mbit/s)
    LMC/SBEI wanPCI-1T3 PCI T3 (also known as DS3, 44.736Mbit/s)
    Sangoma S5141 (dual-port) and S5142 (quad-port) PCI RS232/V.35/X.21 (4Mbit/s - primary port and 512Kbit/s - secondary ones)
    Sangoma S5148 (single-port) and S5147 (dual-port) PCI E1/T1
    Asynchronous Serial
    Packages required: system
    cyclades pc-300 funciona blzinha !
    Pc-300 Da Cyclades Funciona E Por Sinal Eu Tenho Uma Dessas Aki Novinha Com 3 Meses De Uso, Completa...caso Queira Pvt.
    Abracos
    Dec 2000
    Boston
    fbig lembre-se que temos um classificados para anunciar as vendas
