Página 3 de 9 PrimeiroPrimeiro 12345678 ... ÚltimoÚltimo
  1. Citação Postado originalmente por viny_carvalho Ver Post
    Amigo, verifique as suas acls, o squid verifica as regras de cima para baixo, caso uma das regras que vem antes do blockedsites servir, ele usa ela.
    Abraço
    Você está usando proxy transparente ???
    se sim ... verifica se o redirecionamento à porta do squid no firewall está correto ...
    Falow ...
  2. #12
    ThiagoOverseer
    Kara nao tem como ser as acls pq eu so criei uma as outras q tem são as recomendadas.
    o redirecionamento ta assim:
    /sbin/iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 80 -j REDIRECT --to-port 3128
    meu squid:
    http_port 3128
    # TAG: no_cache
    # A list of ACL elements which, if matched, cause the request to
    # not be satisfied from the cache and the reply to not be cached.
    # In other words, use this to force certain objects to never be cached.
    # You must use the word 'DENY' to indicate the ACL names which should
    # NOT be cached.
    #We recommend you to use the following two lines.
    no_cache deny QUERY
    cache_mem 64 MB
    cache_swap_low 90
    cache_swap_high 95
    maximum_object_size 140960 KB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 256 KB
    cache_dir ufs /var/spool/squid 2000 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    #auth_param basic casesensitive off
    refresh_pattern . 0 20% 4320
    #Recommended minimum configuration:
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 901 #SWAT
    acl CONNECT method CONNECT
    # http_access deny all
    # Only allow cachemgr access from localhost
    http_access deny manager
    # Deny requests to unknown ports
    http_access deny !Safe_ports
    # Deny CONNECT to other than SSL ports
    acl proibidos dstdom_regex "/etc/squid/proibidos/block.txt"
    http_access deny proibidos
    acl our_networks src 172.19.123.0/24
    http_access allow our_networks
    # And finally deny all other access to this proxy
    http_access allow localhost
    # http_reply_access allow all
    icp_access allow all
    #proxy transparente
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
    # TAG: httpd_accel_no_pmtu_disc on|off
    # In many setups of transparently intercepting proxies Path-MTU
    # discovery can not work on traffic towards the clients. This is
    # the case when the intercepting device does not fully track
    # connections and fails to forward ICMP must fragment messages
    # to the cache server.
    # If you have such setup and experience that certain clients
    # sporadically hang or never complete requests set this to on.
    # httpd_accel_no_pmtu_disc off
    coredump_dir /var/spool/squid
    visible_hostname teste
    eu digito o comando squid -k aparece q ele ta rodando..
    mais ai eu vou ver o log no var/log/squid/access.log e so aparece isso:
    1169109046.187 7 69.159.116.26 TCP_DENIED/403 1323 GET http://200.174.28.195/ - NONE/- text/html
    acho q o problema e esse.. alguem ja passou por isso? =[
    Última edição por ThiagoOverseer; 18-01-2007 às 10:17.
  3. Kra faz o seguinte, da esse comando:
    squid -d9
    vai ser criado um arquivo chamado squid.run neste arquivo tem o motivo do problema, posta ele ai pra gente...
  4. #14
    ThiagoOverseer
    Kara eu digitei esse comando aki e nada oh.. ele trava.. e não gera nada =[
  5. Amigo, vc pode postar o arquivo txt onde estao os bloqueados? Talvez possa ser a forma como vc declarou.
  1. log do sendmail nao ta funcionando
    Por mcclaudio no fórum Servidores de Rede
    Último Post: 22-07-2004, 09:29
  2. Bloqueio por Mac/IP não tá funcionando direito no iptables
    Por gustavo_marcon no fórum Servidores de Rede
    Respostas: 7
    Último Post: 15-03-2004, 11:36
  3. autenticação squid nao esta funcionando
    Por muganga no fórum Servidores de Rede
    Respostas: 6
    Último Post: 18-02-2004, 12:50
  4. Respostas: 10
    Último Post: 11-06-2003, 07:20
  5. acl no squid não está funcionando. O que fazer ?
    Último Post: 20-12-2002, 16:01
