  1. Amigo eu vo tentar te ajudar, li algumas coisas deste post e gostaria de fazer algumas perguntas. Qual distribuição que vc usa? O teu squid é gateway da rede? Vc sabe dirzer está usando proxy transparente? Vc criou o cache do squid?
    ThiagoOverseer
    Citação Postado originalmente por vioflas Ver Post
    A distribuição é Fedora
    Essa segunda pergunta eu sou iniciante e sinceramente eu não sei te responder..
    o proxy transparente ta criado
    tem essas linhas no squid.conf:
    #proxy transparente
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
    e essa no script d firewall:
    /sbin/iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 80 -j REDIRECT --to-port 3128
    o cache ta criado veja os logs abaixo:
    2007/01/19 10:00:55| Starting Squid Cache version 2.5.STABLE3 for i386-redhat-linux-gnu...
    2007/01/19 10:00:55| Process ID 5679
    2007/01/19 10:00:55| With 1024 file descriptors available
    2007/01/19 10:00:55| DNS Socket created at 0.0.0.0, port 33132, FD 4
    2007/01/19 10:00:55| Adding nameserver 200.255.125.211 from /etc/resolv.conf
    2007/01/19 10:00:55| Adding nameserver 172.19.123.2 from /etc/resolv.conf
    2007/01/19 10:00:55| User-Agent logging is disabled.
    2007/01/19 10:00:55| Referer logging is disabled.
    2007/01/19 10:00:55| Unlinkd pipe opened on FD 9
    2007/01/19 10:00:55| Swap maxSize 2048000 KB, estimated 157538 objects
    2007/01/19 10:00:55| Target number of buckets: 7876
    2007/01/19 10:00:55| Using 8192 Store buckets
    2007/01/19 10:00:55| Max Mem size: 65536 KB
    2007/01/19 10:00:55| Max Swap size: 2048000 KB
    2007/01/19 10:00:55| Rebuilding storage in /var/spool/squid (CLEAN)
    2007/01/19 10:00:55| Using Least Load store dir selection
    2007/01/19 10:00:55| Set Current Directory to /var/spool/squid
    2007/01/19 10:00:55| Loaded Icons.
    2007/01/19 10:00:55| Accepting HTTP connections at 0.0.0.0, port 3128, FD 10.
    2007/01/19 10:00:55| Accepting ICP messages at 0.0.0.0, port 3130, FD 11.
    2007/01/19 10:00:55| WCCP Disabled.
    2007/01/19 10:00:55| Ready to serve requests.
    2007/01/19 10:00:55| Done scanning /var/spool/squid swaplog (0 entries)
    2007/01/19 10:00:55| Finished rebuilding storage from disk.
    2007/01/19 10:00:55| 0 Entries scanned
    2007/01/19 10:00:55| 0 Invalid entries.
    2007/01/19 10:00:55| 0 With invalid flags.
    2007/01/19 10:00:55| 0 Objects loaded.
    2007/01/19 10:00:55| 0 Objects expired.
    2007/01/19 10:00:55| 0 Objects cancelled.
    2007/01/19 10:00:55| 0 Duplicate URLs purged.
    2007/01/19 10:00:55| 0 Swapfile clashes avoided.
    2007/01/19 10:00:55| Took 0.3 seconds ( 0.0 objects/sec).
    2007/01/19 10:00:55| Beginning Validation Procedure
    2007/01/19 10:00:55| Completed Validation Procedure
    2007/01/19 10:00:55| Validated 0 Entries
    2007/01/19 10:00:55| store_swap_size = 0k
    2007/01/19 10:00:56| storeLateRelease: released 0 objects
  3. Beleza, então faz o seguinte, pra fazer um teste, comenta aquelas linhas do proxy transparente, retira nas suas regras iptables o redirecionamento para 3128, executa o comando squid-z que vai criar o cache do squid e depois e depois tu restarta o serviço do squid, instalar o pacote sysvconfig com esse pacote vc podes stopar, restartar, startar serviços é bem simples aí vc usa o comando service squid restart.
    Verifica isso e tenta lá
    ThiagoOverseer
    não bloqueou não.. =[ sera q algo q tem no meu script d firewall pode estar atrapalhando?
  5. Citação Postado originalmente por ThiagoOverseer Ver Post
    Voce pode postar seu script pra gente ver ...
    Falow ...
  1. log do sendmail nao ta funcionando
    Por mcclaudio no fórum Servidores de Rede
    Último Post: 22-07-2004, 09:29
  2. Bloqueio por Mac/IP não tá funcionando direito no iptables
    Por gustavo_marcon no fórum Servidores de Rede
    Respostas: 7
    Último Post: 15-03-2004, 11:36
  3. autenticação squid nao esta funcionando
    Por muganga no fórum Servidores de Rede
    Respostas: 6
    Último Post: 18-02-2004, 12:50
  4. Respostas: 10
    Último Post: 11-06-2003, 07:20
  5. acl no squid não está funcionando. O que fazer ?
    Último Post: 20-12-2002, 16:01
