  1. Citação Postado originalmente por _AGM_ Ver Post
    Para a Wrap com Mikrotik "conversar" com teu Senao, a interface com o CM9 não pode estar em modo bridge, apenas roteando...
    Ela esta em modo station.
    Veja abaixo:
    [admin@Wrap] interface wireless> print
    Flags: X - disabled, R - running
    0 name="wlan2" mtu=1500 mac-address=00:0B:6B:09:F0:8C arp=enabled
    disable-running-check=no interface-type=Atheros AR5213 radio-name="000B6B09F08C"
    mode=ap-bridge ssid="CM9AP" area="" frequency-mode=superchannel
    country=no_country_set antenna-gain=18 frequency=2437 band=2.4ghz-b
    scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
    supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
    basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
    ack-timeout=dynamic tx-power=17 tx-power-mode=card-rates
    noise-floor-threshold=default periodic-calibration=default
    periodic-calibration-interval=60 burst-time=disabled dfs-mode=none
    antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
    wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
    update-stats-interval=disabled default-authentication=yes default-forwarding=no
    default-ap-tx-limit=0 default-client-tx-limit=0
    proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=default
    disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no
    allow-sharedkey=no
    1 R name="wlan1" mtu=1500 mac-address=00:0B:6B:09:F0:76 arp=enabled
    disable-running-check=no interface-type=Atheros AR5213 radio-name="000B6B09F076"
    mode=station ssid="DataConnection" area="" frequency-mode=manual-txpower
    country=brazil antenna-gain=0 frequency=2437 band=2.4ghz-b scan-list=default
    ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
    periodic-calibration=default periodic-calibration-interval=60
    burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
    wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
    wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes
    default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
    disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=long
    compression=yes allow-sharedkey=no
    Se alguem puder me ajudar, dou ate acesso a minha WRAP.
    Última edição por klemensonleal; 24-02-2007 às 14:12.
  2. Klemenson através de tua WRAP você consegue pingar no mk? Caso positivo, consegue pingar no ip que o teu cliente recebeu?
    Se você não pingar, experimenta, setar um ip do range de tua rede e aloca ele na tua bridge, possivelmente dessa forma você conseguirá navegar.
    Outra coisa se no mikrotik tive ativado o controle ipXmac, desativa ele. Limpa o arp desse cliente na tabela e seta a interface para "enable" dessa forma possivelmente seu cliente vai navegar.
    tenta ae. Abraços
  3. Citação Postado originalmente por Josevaldo Ver Post
    tenta ae. Abraços
    Quando desativo a bridge a WRAP pinga o MK e até servidores externos tipo RJNET - Provedor de acesso à Internet - banda larga via rádio - Rio de Janeiro, mas o cliente deixa de receber IP automatico. Quando ativo a bridge o cliente recebe o IP automatico, porém ninguem pinga ninguem.
    Range de IP: 192.168.2.0/24
    Servidor MK: 192.168.2.7
    IP AP SENAO: 192.168.2.222
    IP WLAN1 WRAP: 192.168.2.223
    IP WLAN2 WRAP: 192.168.2.224
  1. Ftp nao conecta
    Último Post: 05-09-2003, 12:33
  2. VPN não conecta
    Por calthc no fórum Servidores de Rede
    Último Post: 05-08-2003, 15:38
  3. Seu Speedy é PPPOE ? Não conecta? Não navega??
    Por zerocoolll no fórum Servidores de Rede
    Último Post: 24-03-2003, 09:09
  4. Help Help Licq não conecta no servidor
    Por Itise no fórum Servidores de Rede
    Último Post: 30-01-2003, 11:03
  5. Mysql não conecta com FrontEnd!!!
    Por AndrewAmorimdaSilva no fórum Servidores de Rede
    Último Post: 07-01-2003, 17:27
