  1. Faz assim:
    chmod g+w
    E corre pro abraço...
    Seu diretório está setado com o SGUI, ou seja, todo arquivo criado dentro dele, vai pertencer ao grupo ftpgroup, porém somente o dono tem permissão de escrever dentro dele. Sacou???
  2. fiz o seguinte
    cd /var/ftp
    chmod g+w Programas
    chmod g+w Portal
    e ainda naum resolveu....teve o usuario rafael naum teve permissao de copiar na pasta Portal, só na pasta Programas
  3. então o problema está na configuração do ftp, vc não restringiu nada no arquivo de configuração não????
  4. BOM TA AI TD QUE EU FIZ...COMO CRIEI OS USUARIOS...MEU CONF..ETC...ISSO EU PEGUEI NA NET.....
    # Example config file /etc/vsftpd/vsftpd.conf
    # The default compiled in settings are fairly paranoid. This sample file
    # loosens things up a bit, to make the ftp daemon more usable.
    # Please see vsftpd.conf.5 for all compiled in defaults.
    # READ THIS: This example file is NOT an exhaustive list of vsftpd options.
    # Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's
    # capabilities.
    # Allow anonymous FTP? (Beware - allowed by default if you comment this
    out).
    anonymous_enable=NO
    # Uncomment this to allow local users to log in.
    local_enable=YES
    # Uncomment this to enable any form of FTP write command.
    write_enable=YES
    # Default umask for local users is 077. You may wish to change this to 022,
    # if your users expect that (022 is used by most other ftpd's)
    local_umask=022
    # Uncomment this to allow the anonymous FTP user to upload files. This only
    # has an effect if the above global write enable is activated. Also, you
    will
    # obviously need to create a directory writable by the FTP user.
    #anon_upload_enable=YES
    # Uncomment this if you want the anonymous FTP user to be able to create
    # new directories.
    #anon_mkdir_write_enable=YES
    # Activate directory messages - messages given to remote users when they
    # go into a certain directory.
    dirmessage_enable=YES
    # Activate logging of uploads/downloads.
    xferlog_enable=YES
    # Make sure PORT transfer connections originate from port 20 (ftp-data).
    connect_from_port_20=YES
    # If you want, you can arrange for uploaded anonymous files to be owned by
    # a different user. Note! Using "root" for uploaded files is not
    # recommended!
    #chown_uploads=YES
    #chown_username=whoever
    # You may override where the log file goes if you like. The default is shown
    # below.
    xferlog_file=/var/log/vsftpd.log
    # If you want, you can have your log file in standard ftpd xferlog format
    xferlog_std_format=YES
    # You may change the default value for timing out an idle session.
    idle_session_timeout=1000
    # You may change the default value for timing out a data connection.
    #data_connection_timeout=120
    # It is recommended that you define on your system a unique user which the
    # ftp server can use as a totally isolated and unprivileged user.
    #nopriv_user=ftpsecure
    # Enable this and the server will recognise asynchronous ABOR requests. Not
    # recommended for security (the code is non-trivial). Not enabling it,
    # however, may confuse older FTP clients.
    async_abor_enable=NO
    # By default the server will pretend to allow ASCII mode but in fact ignore
    # the request. Turn on the below options to have the server actually do
    ASCII
    # mangling on files when in ASCII mode.
    # Beware that turning on ascii_download_enable enables malicious remote
    parties
    # to consume your I/O resources, by issuing the command "SIZE /big/file" in
    # ASCII mode.
    # These ASCII options are split into upload and download because you may
    wish
    # to enable ASCII uploads (to prevent uploaded scripts etc. from breaking),
    # without the DoS risk of SIZE and ASCII downloads. ASCII mangling should be
    # on the client anyway..
    #ascii_upload_enable=YES
    #ascii_download_enable=YES
    # You may fully customise the login banner string:
    ftpd_banner= Bem vindo ao servidor FTP Calcados Milano.
    # You may specify a file of disallowed anonymous e-mail addresses.
    Apparently
    # useful for combatting certain DoS attacks.
    #deny_email_enable=YES
    # (default follows)
    #banned_email_file=/etc/vsftpd.banned_emails
    # You may specify an explicit list of local users to chroot() to their home
    # directory. If chroot_local_user is YES, then this list becomes a list of
    # users to NOT chroot().
    chroot_list_enable=YES
    # (default follows)
    chroot_list_file=/etc/vsftpd/ftpusers
    # You may activate the "-R" option to the builtin ls. This is disabled by
    # default to avoid remote users being able to cause excessive I/O on large
    # sites. However, some broken FTP clients such as "ncftp" and "mirror"
    assume
    # the presence of the "-R" option, so there is a strong case for enabling
    it.
    ls_recurse_enable=NO
    pam_service_name=vsftpd
    userlist_enable=YES
    #enable for standalone mode
    listen=YES
    tcp_wrappers=YES
    #groupadd ftpgroup
    Depois o diretório do ftp
    #mkdir /var/ftp
    Mudamos a permissão do dretório.
    #chmod 0770 /var/ftp
    #chgrp ftpgroup /var/ftp
    Setar o GUID do diretório /var/ftp para que todos os arquivos criados nele pertença ao grupo ftpgroup
    #chmod g+s /var/ftp
    Criando os usuários no exemplo “jose”
    #useradd –s /sbin/nologin –d /var/ftp –c “usuario de ftp” –g ftpgroup jose
    #passwd jose
    Vamos ao ftp agora, edite o arquivo /etc/vsftpd/vsftpd.conf, vou colocar apenas as linhas que fiz alguma mudança.
    anonymous_enable=NO
    ftpd_banner=FTP SERVER EMPRESA
    Crie
    o arquivo /etc/vsftpd/ftpusers e insira o usuario que vai usar o ftp (
    no meu caso o jose ) nele, bom todos os usuários que forem fazer uso do
    ftp devem ser incluídos nesse arquivo.
    Bom o arquivo
    /etc/vsftpd/ftpusers vai servir pra dois fundamentos o chroot dos
    usuários e quais usuários vão poder fazer ftp, o vsftpd trabalha com
    uma lista de usuários que não podem fazer ftp, vou inverter essa lista,
    vou especificar o usuário que pode usar.
    Edite agora o arquivo /etc/pam.d/vsftpd e deixe da seguinte forma.
    #%PAM-1.0
    auth required pam_listfile.so item=user sense=allow file=/etc/vsftpd/ftpusers onerr=succeed
    auth required pam_stack.so service=system-auth
    auth required pam_shells.so
    account required pam_stack.so service=system-auth
    session required pam_stack.so service=system-auth
    No arquivo acima a seguinte linha faz com que apenas usuários dentro do arquivo /etc/vsftpd/ftpusers possam utilizar o serviço.
    Inicie o serviço.
    # service vsftpd start
  5. Desculpe a pergunta um pouco óbvia, mas por acaso existe restrição por quota em disco????
  1. mysql - root sem permissao...
    Por sergioluis no fórum Servidores de Rede
    Último Post: 09-06-2006, 13:27
  2. Sem permissão para Outlook Express
    Por odbc no fórum Servidores de Rede
    Último Post: 15-05-2004, 07:22
  3. CRIAR USUARIO SEM.....
    Por brunocalabria no fórum Servidores de Rede
    Último Post: 05-01-2004, 10:39
  4. squid limitar usuario sem smb_auth
    Por lando no fórum Servidores de Rede
    Último Post: 07-05-2003, 13:44
  5. Sem permissão para cache
    Por l00k no fórum Servidores de Rede
    Respostas: 7
    Último Post: 27-12-2002, 12:03
