    xcompbrasil
    Fiz os 2 procedimentos citados por vcs mas o linux pede uma senha e nem a do usuario e nem a do root passa pela autenticacao.
    Alguem sabe como contornar este problema ?
  2. Reinstala o cups e veja se a senha de root funciona.
    Ab, Duca.
  3. #8
    xcompbrasil
    Reinstalei e ele nao aceita logar como root ou como qualquer outro usuario.
    Estou com o cupsd.conf padrao e nao sei mais o que fazer para ativar o servidor de impressao e compartilhar a impressora.
    Sera que pode ser um bug do Ubuntu 6 ?
  4. xcompbrasil, cola aqui seu cupsd.conf, por favor.
    Ab, Duca.
  5. #10
    xcompbrasil
    Segue o arquivo cupsd.conf
    # Sample configuration file for the Common UNIX Printing System (CUPS)
    # scheduler. See "man cupsd.conf" for a complete description of this
    # file.
    # Log general information in error_log - change "info" to "debug" for
    # troubleshooting...
    LogLevel warning
    # Administrator user group...
    SystemGroup lpadmin
    # Only listen for connections from the local machine.
    # These settings are configured in /etc/cups/cups.d/ports.conf so that
    # changing them does not require to change this file.
    Listen localhost:631
    # Listen /var/run/cups/cups.sock
    # Show shared printers on the local network.
    # The 'Browsing' setting is configured in /etc/cups/cups.d/browse.conf
    # so that changing it does not require to change this file.
    # Browsing Off
    BrowseOrder allow,deny
    BrowseAllow @LOCAL
    BrowseAddress @LOCAL
    # Default authentication type, when authentication is required...
    DefaultAuthType Basic
    # Restrict access to the server...
    <Location />
    Order deny,allow
    deny none
    Allow localhost
    Allow @LOCAL
    allow 192.168.0.*
    </Location>
    # Restrict access to the admin pages...
    <Location /admin>
    Order allow,deny
    Allow localhost
    </Location>
    # Restrict access to configuration files...
    <Location /admin/conf>
    AuthType Basic
    Require user @SYSTEM
    Order allow,deny
    Allow localhost
    </Location>
    # Set the default printer/job policies...
    <Policy default>
    # Job-related operations must be done by the owner or an adminstrator...
    <Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job CUPS-Move-Job>
    Require user @OWNER @SYSTEM
    Order deny,allow
    </Limit>
    # All administration operations require an adminstrator to authenticate...
    <Limit Pause-Printer Resume-Printer Set-Printer-Attributes Enable-Printer Disable-Printer Pause-Printer-After-Current-Job Hold-New-Jobs Release-Held-New-Jobs Deactivate-Printer Activate-Printer Restart-Printer Shutdown-Printer Startup-Printer Promote-Job Schedule-Job-After CUPS-Add-Printer CUPS-Delete-Printer CUPS-Add-Class CUPS-Delete-Class CUPS-Accept-Jobs CUPS-Reject-Jobs CUPS-Set-Default>
    AuthType Basic
    Order deny,allow
    </Limit>
    # Only the owner or an administrator can cancel or authenticate a job...
    <Limit Cancel-Job CUPS-Authenticate-Job>
    Order deny,allow
    </Limit>
    <Limit All>
    Order deny,allow
    </Limit>
    </Policy>
    # Include files in /etc/cups/conf.d
    Include /etc/cups/cups.d/ports.conf
    Include /etc/cups/cups.d/browse.conf
    Valeu pela ajuda
  1. Respostas: 2
    Último Post: 07-09-2006, 13:03
  2. Editores de texto para Linux
    Por JoCkEr no fórum Servidores de Rede
    Respostas: 10
    Último Post: 19-12-2004, 22:53
  3. Substituir estaçoes de windows para linux numa rede samba
    Por Jocimar no fórum Servidores de Rede
    Último Post: 24-06-2004, 06:16
  4. Migração de Windows para Linux....
    Último Post: 18-07-2003, 15:51
  5. Existe algum tipo de Ghost para linux?
    Último Post: 24-05-2003, 14:40
