    Esta é a lista do comandos obtida com o comando help para a versão 1.025, o comando set overridetxpower XX não aparece e também não funciona. O comando que permite alterar a região e a potencia é: admin, só que pede uma senha.
    del key -- Delete Encryption key
    del remoteWbr -- Delete Remote Bridge
    ftp -- Software update via FTP
    get bandwidth -- Display Radio Channel Width
    get channel -- Display Radio Channel
    get cipher -- Display Encryption Type
    get encryption -- Display Encryption State
    get frequency -- Display Radio Frequency (MHz)
    get gateway -- Display Gateway IP Address
    get ipaddr -- Display IP Address
    get ipmask -- Display IP Subnet Mask
    get key -- Display Encryption Key
    get keyentrymethod -- Display Encryption Key Entry Method
    get login -- Display Login User Name
    get macaddr -- Display Local Bridge MAC Address
    get power -- Display Transmit Power Setting
    get rate -- Display Data Rate
    get remoteWbr -- Display Authorized Bridges
    get snmp -- Display SNMP Community Name
    get systemname -- Display Unique Name
    get uptime -- Display Bridge Uptime
    help -- Display CLI Command List
    ping -- Ping
    reboot -- Reboot Bridge
    quit -- Logoff
    set bandwidth -- Set Radio Channel Width
    set channel -- Set Radio Channel
    set cipher -- Set Encryption Type
    set encryption -- Set Encryption State
    set factorydefault -- Restore to Default Factory Settings
    set frequency -- Set Radio Frequency (MHz)
    set gateway -- Set Gateway IP Address
    set ipaddr -- Set IP Address
    set ipmask -- Set IP Subnet Mask
    set key -- Set Encryption Key
    set keyentrymethod -- Select Encryption Key Entry Method
    set login -- Modify Login User Name
    set password -- Modify Password
    set power -- Set Transmit Power
    set rate -- Set Data Rate
    set remoteWbr -- Add New Authorized Bridge
    set snmp -- Modify SNMP Community Name
    set systemname -- Set Unique Name
    version -- Software version
  2. #8
    tem q fazer o procedimento para liverar os canais e assim te habilita mais comandos no telnet.
    Lee
  3. #9
    Lee,
    Como fazer isso? Pelo que li o modo de alterar o country code é pelo comando admin que usa um gerador aleatório de senhas que só são fornecidas pelo suporte da Airaya.
  4. #10
    Citação Postado originalmente por manuelesteves Ver Post
    Lee,
    exatamente... tem q esperar a boa vondade do airaya deixa o server ligado.. maiorias das vezes esta desligado.
    Lee
  5. #11
    Lee, Já conseguiu, alguma vez, acessar o servidor telnet? (telnet 216.139.30.71 4999)
  6. #12
    sim consegui, más raras vezes..
    Lee
