    fabio2
    Padrão Problemas ao gravar cd noLinux
    Ola pessoal ,
    alguem pode me ajudar a descobrir o que está acontecendo que nao estou conseguindo gravar cd´s no linux:
    Pesquisei na internet e fiz todos os teste possiveis, vou postar todas as respostas das saidas dos comandos que executei:
    # ls -l /dev/cdrom
    lrwxrwxrwx 1 root root 3 May 8 08:26 /dev/cdrom -> hdc
    elinux:~ # cdrecord -scanbus
    Cdrecord-Clone 2.01 (i686-suse-linux) Copyright (C) 1995-2004 Jörg Schilling
    Note: This version is an unofficial (modified) version
    Note: and therefore may have bugs that are not present in the original.
    Note: Please send bug reports or support requests to Submitting Bug Reports - openSUSE
    Note: The author of cdrecord should not be bothered with problems in this version.
    cdrecord: No such file or directory. Cannot open '/dev/pg*'. Cannot open SCSI driver.
    cdrecord: For possible targets try 'cdrecord -scanbus'.
    cdrecord: For possible transport specifiers try 'cdrecord dev=help'.
    elinux:~ # cdrecord -v speed=8 dev=/dev/hdc /comp.tar.gz
    cdrecord: No write mode specified.
    cdrecord: Asuming -tao mode.
    cdrecord: Future versions of cdrecord may have different drive dependent defaults.
    cdrecord: Continuing in 5 seconds...
    TOC Type: 1 = CD-ROM
    scsidev: '/dev/hdc'
    devname: '/dev/hdc'
    scsibus: -2 target: -2 lun: -2
    Warning: Open by 'devname' is unintentional and not supported.
    Linux sg driver version: 3.5.27
    Using libscg version 'schily-0.8'.
    cdrecord: Warning: using inofficial libscg transport code version ([email protected] '@(#)scsi-linux-sg.c 1.83 04/05/20 Copyright 1997 J. Schilling').
    SCSI buffer size: 64512
    atapi: 1
    Device type : Removable CD-ROM
    Version : 0
    Response Format: 1
    Vendor_info : 'MS'
    Identifikation : 'C/DVD-ROM '
    Revision : '3.0 '
    Device seems to be: Generic mmc2 DVD-ROM.
    cdrecord: Cannot load media with this drive!
    cdrecord: Try to load media by hand.
    Current: 0x0000
    Profile: 0x0010
    Profile: 0x0008
    cdrecord: Sorry, no CD/DVD-Recorder or unsupported CD/DVD-Recorder found on this target.
    Obrigado a todos pela atenção
    Amigo,
    - Qual distribuição?
    - Qual versão do kernel?
    Para obter a versão do kernel é só digitar no console, como super usuário (root), o comando "uname", exemplo:
    # uname -a
    fabio2
    Padrão Olá
    Opa companheiro,
    SEguinte
    Linux Suse enterprise
    Kernel: 2.6
    Obrigado
    Amigo,
    Dá uma olhada nestes artigos:
    http://www.guiafoca.org/guia/inic_in...-cdwritter-ide
    Linux in Brazil ( Gravador de CD )
    Caso não dê certo, por favor, imprima um lista dos módulos carregados com o comando:
    # lsmod > modulos.txt
    Abra o arquivo modulos.txt, copie o conteudo e cole aqui no fórum, para sabermos quais modulos foram carregados.
    fabio2
    Opa amigo,
    Só me tire uma dúvida, em linux com kernel 2.6 não é necessário emular um drive scsi para gravar cd´s ou é necessário??
    A Dúvida é por que os dois link que vc me passou falam sobre a emulação de scsi, e eu não sei aonde foi que eu li alguma coisa a respeito de gravação de cd´s e lá dizia que kernel 2.6 não era necessário
    Agradeço pela sua paciencia e ajuda.
    Um grande abraço
    fabio2
    Opa
    Segue abaixo a saida do comando lsmod > modulos.txt
    Module Size Used by
    ipv6 216704 20
    button 6672 0
    battery 9476 0
    ac 4996 0
    apparmor 48412 0
    aamatch_pcre 13440 1 apparmor
    loop 14856 0
    dm_mod 52200 0
    ide_cd 35360 0
    tulip 45600 0
    cdrom 32288 1 ide_cd
    i2c_piix4 8208 0
    i2c_core 19472 1 i2c_piix4
    ns558 4612 0
    gameport 13704 2 ns558
    parport_pc 34916 1
    lp 10692 0
    parport 31944 2 parport_pc,lp
    reiserfs 209664 1
    edd 8516 0
    fan 4612 0
    thermal 13448 0
    processor 22468 1 thermal
    piix 9092 0 [permanent]
    ide_disk 14976 3
    ide_core 115900 3 ide_cd,piix,ide_disk
    Obrigado.
