  1. Edite /etc/postfix/main.cf e na linha myneworks deixe relay configurado apenas para o host local
    Ex.:
    mynetworks = 127.0.0.1/8
    Execute o comando /etc/init.d/postfix reload.
  2. Boa Noite !
    então gimenes quando eu coloco essa linha meu outlook não envia o e-mail e da erro agora nos logs da esse erro
    fatal: non-null host address bits in "127.0.0.1/8", perhaps you should use "127.0.0.0/8" instead
    não sei o que pode ser
    obrigado
  3. Post aqui seu main.cf e master.cf para que possamos avaliar e tentar te ajudar.
  4. ok vo postar aii em baixo
    main.cf
    queue_directory = /var/spool/postfix
    program_directory = /usr/sbin
    command_directory = /usr/sbin
    daemon_directory = /usr/lib/postfix
    mail_owner = postfix
    myhostname = max.flexit.intra
    mydomain = flexit.intra
    myorigin = $mydomain
    mynetworks = 127.0.0.0/8
    inet_interfaces = all
    mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain,
    mail.$mydomain, www.$mydomain, ftp.$mydomain
    unknown_local_recipient_reject_code = 550
    relay_domains = $mydomain
    relayhost = $mydomain
    recipient_delimiter = +
    alias_maps = hash:/etc/postfix/aliases
    alias_database = $alias_maps
    home_mailbox = Maildir/
    smtpd_banner = SMTP Server
    smtpd_recipient_restrictions = permit_sasl_authenticated,
    permit_mynetworks,
    reject_unauth_destination
    #smtpd_sender_restrictions = permit_sasl_authenticated,
    # permit_mynetworks,
    # reject_non_fqdn_sender,
    # reject_unknown_sender_domain,
    # reject_unauth_pipelining,
    # permit
    debug_peer_level = 2
    debugger_command =
    PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin
    xxgdb $daemon_directory/$process_name $process_id & sleep 5
    sendmail_path = /usr/sbin/sendmail
    newaliases_path = /usr/bin/newaliases
    mailq_path = /usr/bin/mailq
    setgid_group = postdrop
    html_directory = no
    biff = no
    append_dot_mydomain = no
    manpage_directory = /usr/local/man
    sample_directory = /etc/postfix
    readme_directory = no
    # CONTROLE DE FALHA DE ENTREGA.
    # O tempo entre as tentativas de entrega da fila.
    queue_run_delay = 480s
    # O tempo maximo que uma menssagem fica na fila
    bounce_queue_lifetime = 5400s
    # O tempo maximo que uma mensagem fica na fila de adiadas, antes de voltar ao sender.
    maximal_queue_lifetime = 5400s
    # O tempo maxima entre tentativas de entregar uma mensagem adiada (deferida)
    maximal_backoff_time = 480s
    # O tempo minimo entre tentativas de entregar uma mensagem adiada (deferida)
    minimal_backoff_time = 240s
    #TLS Parametros
    smtpd_use_tls = yes
    smtpd_tls_auth_only = yes
    smtpd_tls_key_file = /etc/ssl/private/ssl-cert-snakeoil.key
    smtpd_tls_cert_file = /etc/ssl/certs/ssl-cert-snakeoil.pem
    ##smtpd_tls_CAfile = /etc/certs/certs/ca-certificates.crt
    smtpd_tls_loglevel = 2
    smtpd_tls_received_header = yes
    smtpd_tls_session_cache_timeout = 3600s
    smtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
    tls_random_source = dev:/dev/urandom
    ##smtp_use_tls = yes
    ##smtp_tls_note_starttls_offer = yes
    ##smtp_tls_key_file = /etc/ssl/private/ssl-cert-snakeoil.key
    ##smtp_tls_cert_file = /etc/ssl/certs/ssl-cert-snakeoil.pem
    ##smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
    smtpd_tls_ask_ccert = yes
    smtpd_tls_req_ccert = no
    #SMTP Autenticado com SASL
    smtpd_sasl_auth_enable = yes
    smtpd_sasl_security_options = noanonymous
    smtpd_sasl_local_domain =
    ##smtpd_sasl_type = dovecot
    ##smtpd_sasl_path = private/auth
    smtpd_sasl_authenticated_header = yes
    broken_sasl_auth_clients = yes
    ##smtp_sasl_auth_enable =yes
    master.cf
    # Postfix master process configuration file. For details on the format
    # of the file, see the master(5) manual page (command: "man 5 master").
    # service type private unpriv chroot wakeup maxproc command + args
    # (yes) (yes) (yes) (never) (100)
    smtp inet n - y - 100 smtpd
    #submission inet n - - - - smtpd
    # -o smtpd_enforce_tls=yes
    # -o smtpd_sasl_auth_enable=yes
    # -o smtpd_client_restrictions=permit_sasl_authenticated,reject
    smtps inet n - n - - smtpd
    -o smtpd_tls_wrappermode=yes
    #628 inet n - - - - qmqpd
    587 inet n - n - - smtpd
    pickup fifo n - - 60 1 pickup
    cleanup unix n - - - 0 cleanup
    qmgr fifo n - n 300 1 qmgr
    #qmgr fifo n - - 300 1 oqmgr
    tlsmgr unix - - n 300 1 tlsmgr
    rewrite unix - - - - - trivial-rewrite
    bounce unix - - - - 0 bounce
    defer unix - - - - 0 bounce
    trace unix - - - - 0 bounce
    verify unix - - - - 1 verify
    flush unix n - - 1000? 0 flush
    proxymap unix - - n - - proxymap
    smtp unix - - - - - smtp
    # When relaying mail as backup MX, disable fallback_relay to avoid MX loops
    relay unix - - - - - smtp
    -o fallback_relay=
    # -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
    showq unix n - - - - showq
    error unix - - - - - error
    discard unix - - - - - discard
    local unix - n n - - local
    virtual unix - n n - - virtual
    lmtp unix - - - - - lmtp
    anvil unix - - - - 1 anvil
    scache unix - - - - 1 scache
    # Interfaces to non-Postfix software. Be sure to examine the manual
    # pages of the non-Postfix software to find out what options it wants.
    # Many of the following services use the Postfix pipe(8) delivery
    # agent. See the pipe(8) man page for information about ${recipient}
    # and other message envelope options.
    # maildrop. See the Postfix MAILDROP_README file for details.
    # Also specify in main.cf: maildrop_destination_recipient_limit=1
    maildrop unix - n n - - pipe
    flags=DRhu user=vmail argv=/usr/bin/maildrop -d ${recipient}
    # See the Postfix UUCP_README file for configuration details.
    uucp unix - n n - - pipe
    flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
    # Other external delivery methods.
    ifmail unix - n n - - pipe
    flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
    bsmtp unix - n n - - pipe
    flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
    scalemail-backend unix - n n - 2 pipe
    flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
    mailman unix - n n - - pipe
    flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
    ${nexthop} ${user}
    é isso aee
    obrigado pela ajuda
  5. Citação Postado originalmente por peregrino Ver Post
    Boa Noite !
    obrigado
    Olhando com mais calma vi que digitei errado, aonde coloquei 127.0.0.1/8 na verdade era para ser 127.0.0.0/8.
    Vou descrever as linhas do meu main.cf que difere do seu, fiz poucas alterações em relação ao original criado pelo instalador.
    Minha linha myorigin, está assim:
    myorigin = /etc/mailname
    - cat /etc/mailname = hostname.dominio.com.br
    Minha linha relayhost, está vazia.
    relayhost =
    As configurações do SASLAUTH estão como descritos abaixo:
    smtp_sasl_security_options = noanonymous
    smtpd_sasl_application_name = smtpd
    Meu smtpd_recipient_restrictions, está como descrito abaixo:
    permit_mynetworks,
    reject_sender_login_mismatch,
    reject_unauth_destination,
    reject_unknown_client,
    reject_non_fqdn_hostname,
    reject_unknown_recipient_domain,
    Em /etc/postfix/sasl/ tenho um arquivo chamado "smtpd.conf" com o seguinte conteudo:
    pwcheck_method: saslauthd
    mech_list: plain login
    Não sei se vai te ajudar, pois ainda estou engatinhando com o postfix ... Mas vale a intenção.
    De uma olhada nessa lista Postfix-BR Página de Detalhes tenho aprendido muito por ela.
  1. Antivirus+Fetchmail+Postfix
    Por hlopes no fórum Servidores de Rede
    Último Post: 19-11-2002, 23:39
  2. POSTFIX+FETCHMAIL+PROCMAIL
    Último Post: 08-11-2002, 23:02
  3. antívirus no postfix
    Por ediguedes no fórum Servidores de Rede
    Último Post: 25-10-2002, 13:35
  4. postfix
    Último Post: 18-06-2002, 19:31
  5. Postfix+MySQL
    Por eclaudin no fórum Servidores de Rede
    Último Post: 26-04-2002, 10:25
