  1. Código :
    #<VirtualHost _default_:*>
    #</VirtualHost>
    ##  SSL Global Context
    ##  All SSL configuration in this context applies both to
    ##  the main server and all SSL-enabled virtual hosts.
    #   Some MIME-types for downloading Certificates and CRLs
    <IfDefine SSL>
    AddType application/x-x509-ca-cert .crt
    AddType application/x-pkcs7-crl    .crl
    </IfDefine>
    <IfModule mod_ssl.c>
    #   Pass Phrase Dialog:
    #   Configure the pass phrase gathering process.
    #   The filtering dialog program (`builtin' is a internal
    #   terminal dialog) has to provide the pass phrase on stdout.
    SSLPassPhraseDialog  builtin
    #   Inter-Process Session Cache:
    #   Configure the SSL Session Cache: First the mechanism
    #   to use and second the expiring timeout (in seconds).
    #SSLSessionCache        none
    #SSLSessionCache        shmht:/usr/local/apache/logs/ssl_scache(512000)
    #SSLSessionCache        shmcb:/usr/local/apache/logs/ssl_scache(512000)
    SSLSessionCache         dbm:/usr/local/apache/logs/ssl_scache
    SSLSessionCacheTimeout  300
    #   Semaphore:
    #   Configure the path to the mutual exclusion semaphore the
    #   SSL engine uses internally for inter-process synchronization.
    SSLMutex  file:/usr/local/apache/logs/ssl_mutex
    #   Pseudo Random Number Generator (PRNG):
    #   Configure one or more sources to seed the PRNG of the
    #   SSL library. The seed data should be of good random quality.
    #   WARNING! On some platforms /dev/random blocks if not enough entropy
    #   is available. This means you then cannot use the /dev/random device
    #   because it would lead to very long connection times (as long as
    #   it requires to make more entropy available). But usually those
    #   platforms additionally provide a /dev/urandom device which doesn't
    #   block. So, if available, use this one instead. Read the mod_ssl User
    #   Manual for more details.
    SSLRandomSeed startup builtin
    SSLRandomSeed connect builtin
    #SSLRandomSeed startup file:/dev/random  512
    #SSLRandomSeed startup file:/dev/urandom 512
    #SSLRandomSeed connect file:/dev/random  512
    #SSLRandomSeed connect file:/dev/urandom 512
    #   Logging:
    #   The home of the dedicated SSL protocol logfile. Errors are
    #   additionally duplicated in the general error log file.  Put
    #   this somewhere where it cannot be used for symlink attacks on
    #   a real server (i.e. somewhere where only root can write).
    #   Log levels are (ascending order: higher ones include lower ones):
    #   none, error, warn, info, trace, debug.
    SSLLog      /usr/local/apache/logs/ssl_engine_log
    SSLLogLevel info
    </IfModule>
    <IfDefine SSL>
    ## SSL Virtual Host Context
    <VirtualHost _default_:443>
    #  General setup for the virtual host
    DocumentRoot "/usr/local/server/"
    ServerName firewall.
    ServerAdmin cpd@fafil.com.br.
    ErrorLog /usr/local/apache/logs/error_log
    TransferLog /usr/local/apache/logs/access_log
    #   SSL Engine Switch:
    #   Enable/Disable SSL for this virtual host.
    SSLEngine on
    #   SSL Cipher Suite:
    #   List the ciphers that the client is permitted to negotiate.
    #   See the mod_ssl documentation for a complete list.
    SSLCipherSuite ALL:!ADH:!EXPORT56:RC4+RSA:+HIGH:+MEDIUM:+LOW:+SSLv2:+EXP:+eNULL
    #   Server Certificate:
    #   Point SSLCertificateFile at a PEM encoded certificate.  If
    #   the certificate is encrypted, then you will be prompted for a
    #   pass phrase.  Note that a kill -HUP will prompt again. A test
    #   certificate can be generated with `make certificate' under
    #   built time. Keep in mind that if you've both a RSA and a DSA
    #   certificate you can configure both in parallel (to also allow
    #   the use of DSA ciphers, etc.)
    SSLCertificateFile /usr/local/apache/conf/ssl.crt/server.crt
    #SSLCertificateFile /usr/local/apache/conf/ssl.crt/server-dsa.crt
    #   Server Private Key:
    #   If the key is not combined with the certificate, use this
    #   directive to point at the key file.  Keep in mind that if
    #   you've both a RSA and a DSA private key you can configure
    #   both in parallel (to also allow the use of DSA ciphers, etc.)
    SSLCertificateKeyFile /usr/local/apache/conf/ssl.key/server.key
    #SSLCertificateKeyFile /usr/local/apache/conf/ssl.key/server-dsa.key
    #   Server Certificate Chain:
    #   Point SSLCertificateChainFile at a file containing the
    #   concatenation of PEM encoded CA certificates which form the
    #   certificate chain for the server certificate. Alternatively
    #   the referenced file can be the same as SSLCertificateFile
    #   when the CA certificates are directly appended to the server
    #   certificate for convinience.
    #SSLCertificateChainFile /usr/local/apache/conf/ssl.crt/ca.crt
  2. Código :
    #   Certificate Authority (CA):
    #   Set the CA certificate verification path where to find CA
    #   certificates for client authentication or alternatively one
    #   huge file containing all of them (file must be PEM encoded)
    #   Note: Inside SSLCACertificatePath you need hash symlinks
    #         to point to the certificate files. Use the provided
    #         Makefile to update the hash symlinks after changes.
    #SSLCACertificatePath /usr/local/apache/conf/ssl.crt
    #SSLCACertificateFile /usr/local/apache/conf/ssl.crt/ca-bundle.crt
    #   Certificate Revocation Lists (CRL):
    #   Set the CA revocation path where to find CA CRLs for client
    #   authentication or alternatively one huge file containing all
    #   of them (file must be PEM encoded)
    #   Note: Inside SSLCARevocationPath you need hash symlinks
    #SSLCARevocationPath /usr/local/apache/conf/ssl.crl
    #SSLCARevocationFile /usr/local/apache/conf/ssl.crl/ca-bundle.crl
    #   Client Authentication (Type):
    #   Client certificate verification type and depth.  Types are
    #   none, optional, require and optional_no_ca.  Depth is a
    #   number which specifies how deeply to verify the certificate
    #   issuer chain before deciding the certificate is not valid.
    #SSLVerifyClient require
    #SSLVerifyDepth  10
    #   Access Control:
    #   With SSLRequire you can do per-directory access control based
    #   on arbitrary complex boolean expressions containing server
    #   variable checks and other lookup directives.  The syntax is a
    #   mixture between C and Perl.  See the mod_ssl documentation
    #   for more details.
    #<Location />
    #SSLRequire (    %{SSL_CIPHER} !~ m/^(EXP|NULL)/ \
    #            and %{SSL_CLIENT_S_DN_O} eq "Snake Oil, Ltd." \
    #            and %{SSL_CLIENT_S_DN_OU} in {"Staff", "CA", "Dev"} \
    #            and %{TIME_WDAY} >= 1 and %{TIME_WDAY} <= 5 \
    #            and %{TIME_HOUR} >= 8 and %{TIME_HOUR} <= 20       ) \
    #           or %{REMOTE_ADDR} =~ m/^192\.76\.162\.[0-9]+$/
    #</Location>
    #   SSL Engine Options:
    #   Set various options for the SSL engine.
    #   o FakeBasicAuth:
    #     Translate the client X.509 into a Basic Authorisation.  This means that
    #     the standard Auth/DBMAuth methods can be used for access control.  The
    #     user name is the `one line' version of the client's X.509 certificate.
    #     Note that no password is obtained from the user. Every entry in the user
    #     file needs this password: `xxj31ZMTZzkVA'.
    #   o ExportCertData:
    #     This exports two additional environment variables: SSL_CLIENT_CERT and
    #     SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
    #     server (always existing) and the client (only existing when client
    #     authentication is used). This can be used to import the certificates
    #     into CGI scripts.
    #   o StdEnvVars:
    #     This exports the standard SSL/TLS related `SSL_*' environment variables.
    #     Per default this exportation is switched off for performance reasons,
    #     because the extraction step is an expensive operation and is usually
    #     useless for serving static content. So one usually enables the
    #     exportation for CGI and SSI requests only.
    #   o CompatEnvVars:
    #     This exports obsolete environment variables for backward compatibility
    #     to Apache-SSL 1.x, mod_ssl 2.0.x, Sioux 1.0 and Stronghold 2.x. Use this
    #     to provide compatibility to existing CGI scripts.
    #   o StrictRequire:
    #     This denies access when "SSLRequireSSL" or "SSLRequire" applied even
    #     under a "Satisfy any" situation, i.e. when it applies access is denied
    #     and no other module can change it.
    #   o OptRenegotiate:
    #     This enables optimized SSL connection renegotiation handling when SSL
    #     directives are used in per-directory context.
    #SSLOptions +FakeBasicAuth +ExportCertData +CompatEnvVars +StrictRequire
    <Files ~ "\.(cgi|shtml|phtml|php3?)$">
        SSLOptions +StdEnvVars
    </Files>
    <Directory "/usr/local/apache/cgi-bin">
    </Directory>
    #   SSL Protocol Adjustments:
    #   The safe and default but still SSL/TLS standard compliant shutdown
    #   approach is that mod_ssl sends the close notify alert but doesn't wait for
    #   the close notify alert from client. When you need a different shutdown
    #   approach you can use one of the following variables:
    #   o ssl-unclean-shutdown:
    #     This forces an unclean shutdown when the connection is closed, i.e. no
    #     SSL close notify alert is send or allowed to received.  This violates
    #     the SSL/TLS standard but is needed for some brain-dead browsers. Use
    #     this when you receive I/O errors because of the standard approach where
    #     mod_ssl sends the close notify alert.
    #   o ssl-accurate-shutdown:
    #     This forces an accurate shutdown when the connection is closed, i.e. a
    #     SSL close notify alert is send and mod_ssl waits for the close notify
    #     alert of the client. This is 100% SSL/TLS standard compliant, but in
    #     practice often causes hanging connections with brain-dead browsers. Use
    #     this only for browsers where you know that their SSL implementation
    #     works correctly.
    #   Notice: Most problems of broken clients are also related to the HTTP
    #   keep-alive facility, so you usually additionally want to disable
    #   keep-alive for those clients, too. Use variable "nokeepalive" for this.
    #   Similarly, one has to force some clients to use HTTP/1.0 to workaround
    #   their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and
    #   "force-response-1.0" for this.
    SetEnvIf User-Agent ".*MSIE.*" \
             nokeepalive ssl-unclean-shutdown \
             downgrade-1.0 force-response-1.0
    #   Per-Server Logging:
    #   The home of a custom SSL log file. Use this when you want a
    #   compact non-error SSL logfile on a virtual host basis.
    CustomLog /usr/local/apache/logs/ssl_request_log \
              "%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x \"%r\" %b"
    </VirtualHost>
    </IfDefine>
  3. nada ainda pessoal?
  4. procura isso:
    #ServerName Example Web Page
    troca por:
    ServerName localhost
    ou
    ServerName 192.168.0.1
    veja se resolve
  1. Menssagem de erro no qmail
    Último Post: 03-02-2005, 20:41
  2. ERRO qdo crio uma chamada para o banco MYSQL
    Por thiagog no fórum Servidores de Rede
    Último Post: 07-10-2002, 16:02
  3. ERRO qdo crio uma chamada para o banco MYSQL
    Último Post: 20-09-2002, 10:13
  4. Respostas: 1
    Último Post: 05-09-2002, 14:54
  5. re: erro no linux
    Por haysar no fórum Servidores de Rede
    Último Post: 12-06-2002, 17:48
