  1. Pessoal agora estou com o seguinte problema, quando starto o radiusd aparece a seguinte mensagem:
    /usr/local/sbin/radiusd: error while loading shared libraries: libradius-1.1.7.so: cannot open shared object file: No such file or directory
    Qual seria o problema que o radius nõ starta?
  2. falta a libradius.. tenta recompilar o radius !
  3. Ok ja compilei novamente o radius, mas agora quando dou restart aparece a seguinte mensagem:
    Starting FreeRADIUS:Tue Aug 21 10:16:31 2007 : Info: Starting - reading configuration files ...
    radiusd: Couldn't open /usr/local/var/log/radius/radius.log for logging: Permission denied
    (rlm_exec: Wait=yes but no output defined. Did you mean output=none?)
    (HASH: Reinitializing hash structures and lists for caching...)
    (HASH: Stored 26 entries from /etc/passwd)
    (HASH: Stored 41 entries from /etc/group)
    (radiusd.conf[10] Failed to link to module 'rlm_eap': libeap-1.1.7.so: cannot open shared object file: No such file or directory
    (radiusd.conf[1960] Unknown module "eap".)
    (radiusd.conf[1907] Failed to parse authenticate section.
    radiusd
    Última edição por jasonlinux; 21-08-2007 às 09:16.
  4. cara..
    verificar as permissoes do diretorio
    veja se o usuario do radius tem permissao para escrever nesta pasta !!
  5. ok, ja verifiquei as permissões, agora quando starto o radiusd starta sem nenhum problema, mas quando uso o check-radius.config aparecea seguinte mensagem:
    Module: Instantiated preprocess (preprocess)
    Module: Loaded realm
    realm: format = "suffix"
    realm: delimiter = "@"
    realm: ignore_default = no
    realm: ignore_null = no
    Module: Instantiated realm (suffix)
    Module: Loaded files
    files: usersfile = "/usr/local/etc/raddb/users"
    files: acctusersfile = "/usr/local/etc/raddb/acct_users"
    files: preproxy_usersfile = "/usr/local/etc/raddb/preproxy_users"
    files: compat = "no"
    /usr/local/etc/raddb/users[216]: Parse error (check) for entry DEFAULT: Unknown attribute "Simultaneous-User"
    Errors reading /usr/local/etc/raddb/users
    radiusd.conf[1067]: files: Module instantiation failed.
    radiusd.conf[1853] Unknown module "files".
    radiusd.conf[1789] Failed to parse authorize section.
    E quando Executo o comando radtest
    radtest jason xxxx 127.0.0.1:1645 0 teste
    Re-sending Access-Request of id 17 to 127.0.0.1 port 1645
    User-Name = "jason"
    User-Password = "axxx"
    NAS-IP-Address = 255.255.255.255
    NAS-Port = 0
    User-Name = "jason"
    User-Password = "xxx"
    NAS-Port = 0
    radclient: no response from server for ID 17
  1. problema com freeradius no mandriva 2008
    Por guezth no fórum Servidores de Rede
    Respostas: 5
    Último Post: 02-04-2008, 13:19
  2. Problemas com o freeradius 1.05
    Por thilupas no fórum Servidores de Rede
    Último Post: 03-05-2007, 09:40
  3. Problemas com Freeradius 1.05
    Por japaeye4u no fórum Servidores de Rede
    Último Post: 15-09-2005, 17:42
  4. Problema com freeradius
    Por sarna no fórum Servidores de Rede
    Último Post: 29-04-2005, 14:52
  5. Problemas com FreeRadius e MySql
    Por TheHawk no fórum Servidores de Rede
    Último Post: 08-03-2005, 09:00
